Old 10-19-2009, 09:03 PM   #1
Tallman
Default Back-feeding breakers
I have encountered a partially upgraded service. The old 60 A fusebox still serves as the main. The new sq. D QO box has a 70A breaker, back-fed and interlocked with a 30A generator breaker. My question is- do QO breakers merely act as disconnects when back-fed, or do they offer over-current protection?
bharbwyr is offline   Reply With Quote
Old 10-19-2009, 09:54 PM   #2
drsparky's Avatar
Current flow in either direction will make the breaker trip.
"Pay attention son, this is for your own good." - Foghorn Leghorn
Old 10-19-2009, 11:02 PM   #3
Rat Extraordinaire
It makes no difference which end a breaker is fed from. Current flowing one direction will be flowing the opposite in 1/120th of a second.
Old 10-20-2009, 01:58 AM   #4
zen
electrican
zen's Avatar
so why do some people feed a mlo panel from the main panel under a breaker and some feed from the main under a breaker to a breaker in the mlo panel
if i knew half as much as i thought i knew i might know something
zen is online now   Reply With Quote
Old 10-20-2009, 09:36 AM   #5
Rat Extraordinaire
Same reason some people wear boxers, others wear briefs.
Same reason some people drive vans, others drive pickups.
Same reason some people wear baseball caps, others don't.
If the other end of the feed has a properly-sized overcurrent device, you don't need one in the MLO panel.
Old 10-20-2009, 09:49 AM   #6
chenley's Avatar
That just reminded me of this from Joe Dirt:
Hey, how exactly is a rainbow made?
How exactly does the sun set?
How exactly does the posi-trac
rear end on a Plymouth work?
-It just does.
Old 10-20-2009, 10:52 AM   #7
Tallman
I see that according to 408.36(D), I'm good to go as long as the backfed breaker is fastened in place, which, thanks to the generator interlock bracket, it is.
Old 10-20-2009, 10:27 PM   #8
Master Electrician
rewire's Avatar
I don't think the interlock prevents removal of the breaker
rewire is online now   Reply With Quote
Feeding underground in block walls Marshall175 General Electrical Discussion 18 07-24-2009 09:56 PM
Feeding a sub panel subelect General Electrical Discussion 5 05-08-2009 03:15 PM
12-2 feeding 12/3 subelect NEC Code Forum 4 11-09-2008 09:56 PM
Feeding switches bgec UK Electrical Forum 4 10-19-2008 11:13 AM
Question about back feeding Golden Arc General Electrical Discussion 44 07-29-2008 10:32 PM
