Old 11-12-2008, 02:15 AM   #1
Default Basement 240v to 120v conversion
Willing be doing this soon and a lot of it apparently so want to start off strong.
30 amp breaker box in the basement and a dryer outlet that is 240v. How should I go about converting so there are 120v outlets available?
noobapprentice is offline   Reply With Quote
Old 11-12-2008, 06:31 AM   #2
"A" inside wireman
randomkiller's Avatar
Not to bust your balls but if you're an apprentice why haven't you asked the JW that you work with about this? And as even a 1st year apprentice you should know that you need a neutral to get 120v, so think about what you need to add to get what you desire there.
"One Nation Under God"
Old 11-12-2008, 06:50 AM   #3
I agree. This is stuff your journeymen or school are supposed to be teaching you.
Old 01-14-2009, 08:27 PM   #4
Buy a codebook
run a few extension cords............. but oh wait theres more, make sure they are ul listed
mollydog is offline   Reply With Quote
Old 01-14-2009, 08:42 PM   #5
I guess it would depend on the wiring, What type wiring? How many conductors? etc. 240 can mean just 240 with no neutral and no ground. Or it can have a neutral and no ground or it can have a neutral with a ground.
Are you planning on doing away with the dryer?
Old 01-14-2009, 11:51 PM   #6
Wanna be Guru
mikeg_05's Avatar
Sounds like a side job gone bad
Old 01-15-2009, 12:44 AM   #7
Probably easiest to throw the 120/240 switch the other direction:
Old 01-16-2009, 05:50 PM   #8
Not Peter D
Do they make a 277/480 version of that as well?
Old 01-17-2009, 12:05 PM   #9
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
~Matt
Old 01-17-2009, 12:23 PM   #10
Seen your member
Yep!
Old 01-17-2009, 12:27 PM   #11
Not Peter D
Yep!
No transformer required! Just $11.99 at your local electrical supplies dealer!
Old 01-17-2009, 12:28 PM   #12
Seen your member
They're only $7.99 at Home Cheapo!
Old 01-17-2009, 08:27 PM   #13
Actually, I have done switches somewhat similar to this for dual-voltage single phase motors on construction tools. Like air compressors, table saws, etc.
Some of the older Dewalt radial arm saws came from the factory with a dual voltage switch. Anyone who has used woodworking tools much knows they are considerably more powerful on 240 than 120. Especially when using a long extension cord.
Rob
Old 01-17-2009, 09:15 PM   #14
Seen your member
Rob
I'd like to see how they get away with using a single NEMA cord cap for both 120 and 240.
Old 01-17-2009, 10:53 PM   #15
Burger Flipper
TOOL_5150's Avatar
an L14-30 has 120v and 240v avalible. - but I get your point.
~mATT
Old 01-17-2009, 10:59 PM   #16
Seen your member
~mATT
If you've got an L14-30 receptacle, you've got 240. Why run it at 120?
If you've only got a 120 receptacle, how do you plug it in?
Old 01-18-2009, 11:56 PM   #17
It would certainly never get a UL listing these days, but I remember many years ago (in the 60's when I was just a kid) that most of the Dewalt 10" and 12" radial arm saws had a dual voltage switch on the end of the motor. The cord plugs were the 6-15 type (15 amp 250 volt straight blade), and everyone had an adapter that had a 125 volt plug and a 250 volt connector.
They also had adapters for twist-lock, dryer recpts, range recpts, etc.
You have to remember, this was the 60's, people actually had common sense back then. There wasn't a rule for everything, you learned how to use stuff like this on the job.
Rob
Old 01-19-2009, 01:23 AM   #18
3rd Generation
MF Dagger's Avatar
Just tape one wire white
MF Dagger is offline   Reply With Quote
3'' can location for basement gemrock Lighting Design 14 03-11-2009 06:07 PM
Jackpots in the basement... Mackie Code Violation Discussion 2 03-24-2008 08:06 PM
US to UK power conversion.. help please. MJDNT General Electrical Discussion 7 08-15-2007 06:57 PM
120v tap off a 240 v circuit dan NEC Code Forum 4 05-22-2007 09:48 PM
Sheetrock under basement steps JohnJ0906 Other Codes and Standards 9 04-23-2007 05:55 PM
