Old 01-08-2009, 12:00 AM   #1
pudge565's Avatar
Default Class 320 Meter base
I have a question regarding class 320 meter base. They have a metal lever in them used to bypass the meter. Why would the bypass lever be used? I can't see why it's in there since you could use it for free electric.
Old 01-08-2009, 01:14 AM   #2
In case you have to remove the meter but interrupting the load would have undesirable effects. You could throw the bypass, remove the faulty meter, place a good meter in, release the bypass and be on your way.
And it would be very noticeable to the POCO if you were stealing power, because you couldn't place the cover on with the bypass engaged. I guess you could get the ole sawzall out and hack it off...
Old 01-08-2009, 05:49 AM   #3
Regular meters have a "Horn Bypass" which the meter man can clip jumpers onto.,
Old 01-08-2009, 09:23 AM   #4
pudge565's Avatar
Ok thank you makes sense to me.
Old 01-08-2009, 03:27 PM   #5
In my area any meter pans we buy usually have the horns.
ALL commercial meter pans are required by the POCO to be lever bypass.
Old 01-08-2009, 06:08 PM   #6
Mountain Electrician's Avatar
Same here.
need some help with a boiler for base board heating captkirk Off Topic 30 11-06-2008 01:37 PM
GU24 base Bkessler Lighting Design 3 10-05-2008 07:33 PM
Receptacles in the Base trim calimurray General Electrical Discussion 33 09-07-2008 03:58 PM
Broken lamp base in socket JohnJ0906 General Electrical Discussion 8 03-16-2008 08:59 PM
Meter mounting base ? James Con Tools, Equipment and New Products 3 08-21-2007 07:34 PM
