Old 07-18-2012, 12:10 PM   #1
Question Cleaning Copper Detail
This may be the wrong section to be posting this in, and I apologize if it is. I am working on a project where we are restoring an old service. The client would like us to clean the corrosion off of the copper detail in the end line box. We are scheduling a turn off with the utility but I am not sure what type of product(s) would be good for doing this. Does anyone have any experience with this or any suggestions?
Thanks
robstyles21 is offline   Reply With Quote
Old 07-18-2012, 03:04 PM   #2
Licensed Journeyman
nolabama's Avatar
When I was a little kid and I wanted to shine a penny up I would use a pencil erasure. It works great. Brasso also comes to mind. A paste of baking soda and water works great also.
Old 07-18-2012, 11:03 PM   #3
erics37's Avatar
Dunk it in some Coca Cola overnight. Seriously.
The Following 2 Users Say Thank You to erics37 For This Useful Post:
The_Modifier (07-22-2012), TOOL_5150 (07-19-2012)
Old 07-19-2012, 12:38 AM   #4
Master Plumber
TOOL_5150's Avatar
thatll do it. itll also clean your toilet if you pour a can in the bowl over night.
Poor planning on your part does not constitute an emergency on my part.
Old 07-19-2012, 12:40 AM   #5
erics37's Avatar
I've got a couple garbage cans full of bright & shiny copper but I've also got a small pile of ugly tarnished stuff. When I have enough I'm going to cram it into a plastic tub and get a 2 liter and give it a bath overnight. If I have a couple pounds it might be worth the cost of the soda pop
Old 07-19-2012, 12:41 AM   #6
Master Of Disaster
socalelect's Avatar
What a shine metal polish or zephyr pro 40
Old 07-19-2012, 12:42 AM   #7
Master Of Disaster
socalelect's Avatar
That's a good idea eric. Does the coke really shine up the copper?
Old 07-19-2012, 12:46 AM   #8
erics37's Avatar
Yeah it does. I had one small piece with some green patina on it and it actually gurgled and bubbled a bit when I immersed it
Old 07-19-2012, 12:48 AM   #9
Master Of Disaster
socalelect's Avatar
Does it have to be coke or will generic cola do the job
Old 07-19-2012, 12:49 AM   #10
Master Plumber
TOOL_5150's Avatar
and you people drink that crap...... ::
Old 07-19-2012, 01:04 AM   #11
erics37's Avatar
I don't drink Coke.
I drink Barq's Root Beer. It has bite.
The Following User Says Thank You to erics37 For This Useful Post:
walkerj (09-09-2012)
Old 07-19-2012, 01:19 AM   #12
Master Of Disaster
socalelect's Avatar
I don't drink Coke.
Barqs. Is near impossible to find around here most of the time major bummer I really lime it
Old 07-19-2012, 11:25 PM   #13
Jimmy Cagney would no what to do with dirty copper.
If you use coke (phosphoric acid?) you have to rinse the sugar off.
I do not know about other acids such as lime-away or CLR
or Naval Jelly (some of these leave a phosphate coating)
wyrmrider is offline   Reply With Quote
Old 07-20-2012, 01:44 PM   #14
I don't drink Coke.
A&W root beer is so much better. although when A&W is unavailable Barq's is the next best.
East Coast Paul is offline   Reply With Quote
Old 07-20-2012, 11:11 PM   #15
my first time
but seriously... white vinigar probably works better and cheaper
cl219um is offline   Reply With Quote
Old 07-21-2012, 08:30 PM   #16
Bandwidth Conservator
Fredman's Avatar
Seriously nobody has suggested muriatic acid yet?
It will remove the corrosion like nothing else.
Fredman is offline   Reply With Quote
Old 07-22-2012, 01:11 AM   #17
Be sure and neutralize your acids or they will be like the Energizer bunny
working and working and working
If working on tin or silver plated buss bars do some more research
If this is a buss bar then think of LOX or Pentox or other anti corrosion gel
They are a must for aluminum but work well on copper
Your do not want to tarnish your reputation
Old 07-22-2012, 01:01 PM   #18
erics37's Avatar
HA!!!
I don't care what anyone says, puns are always funny.
socalelect (07-22-2012)
Old 07-22-2012, 04:39 PM   #19
I had a dentist tell me once that if you take a tooth and put it in a glass of Coke, the tooth will be gone in several days.
So yeah, it will eat the tarnish from the wire, but be careful of how long you soak it.
mikey383 is offline   Reply With Quote
Old 07-22-2012, 07:30 PM   #20
Seriously
Muriatic acid is another name for Hydrochloric acid or HCl
Even the MIST is highly corrosive to metals and to YOU
One thing to consider is what is the result of removing oxidation with HCL
Copper + HCl gives what?
Tin + HCL gives what?
Lead + HCL gives what?
silver " HCL gives what?
is that WHAT conductive or insulating?
Acid may produce more green that it removes
Give it a try with rubber gloves and goggles
neutralize with baking soda solution
what happens?
BVVC when working with strong acids/ bases
Do not be making any Chlorine gas!
From Wikipedia
Both the mist and the solution have a corrosive effect on human tissue, with the potential to damage respiratory organs, eyes, skin, and intestines. Upon mixing hydrochloric acid with common oxidizing chemicals, such as sodium hypochlorite (bleach, NaClO) or potassium permanganate (KMnO4), the toxic gas chlorine is produced. NaClO + 2 HCl → H2O + NaCl + Cl2 2 KMnO4 + 16 HCl → 2 MnCl2 + 8 H2O + 2 KCl + 5 Cl2
Van cleaning Mr Rewire Off Topic 40 08-05-2011 07:57 PM
Cleaning of Corroded neutral bar? thegoodelectrician Services and Service Equipment 5 02-15-2011 10:03 PM
Cleaning out your tool bag Jlarson Tools, Equipment and New Products 19 09-03-2010 12:24 AM
Truck cleaning randomkiller Off Topic 34 01-18-2008 08:05 PM
