Old 07-10-2012, 05:59 PM   #1
SpaghettiMonster's Avatar
Default Code Violations.
We replaced a burnt Zinsco today with some service equipment that seemed to have been added recently. I think the poco switched this neighborhood to underground service sometime in the past 10 years or so. But yeah, there's code violations on practically every installation I was able to see in the cul-de-sac. I didn't take pictures though, except for the one I changed out and the direct neighbors... didn't want to freak people out.
Also, I used the old panel enclosure as a make-up box and used the old neu/grd bar as a common point for the grds. Ran a #6 grd to the new panel. The electricians back in the days spun all the grounds together into some jacked up coil, which I didn't feel inclined to jack with. Is it a violation to tap all those grounds under one terminal?(bottom image)
230.71 Violation
Solution
Inside Mess
Used as a make-up box..
Lack of Communication
SpaghettiMonster is offline   Reply With Quote
Old 07-10-2012, 06:15 PM   #2
And here's what the neighbor had going on, I'm somewhere in Oklahoma... and we have local codes that require the DC means within a certain distance.
Old 07-10-2012, 09:05 PM   #3
yellow & orange wires in a single phase 240 panel ??
Spark Master is online now   Reply With Quote
Old 07-10-2012, 09:24 PM   #4
PGW Professional
Magnettica's Avatar
What's wrong with that?
Old 07-10-2012, 09:25 PM   #5
Maybe I am missing something, but I don't see a 230.71 violation.
I do not see a Myers hub where you went into that new panel.
Bbsound is online now   Reply With Quote
Old 07-10-2012, 09:30 PM   #6
usually for 277/480 volts
Old 07-10-2012, 10:33 PM   #7
I thought hubs were only used for horizontal surfaces? As for the violation, I was kinda unsure whether or not it is, that's why I posted here. You can only have 6 throws of the hand for DC means, and that panel could support additional circuits/feeders... 6 2-p or 12 sp, which would be a violation. But there's handle ties... so I dunno.
Yeah, I would normally use all those different colors, I just wanted to have all of them differentiated. That box is done for, the nipple going into it is packed tight. Any further additions will have to go in thru the attic.
Old 07-10-2012, 11:06 PM   #8
Registered Big Member
mxslick's Avatar
Yep, and the problem is........
Absolutely nothing as far as Code is concerned.
Yes, but not a violation enforceable under the Code. We had a similar discussion here: So many things wrong here.....
See post #6 and beyond.
Freshly manscaped for your motocross riding pleasure.
mxslick is offline   Reply With Quote
Old 07-11-2012, 09:05 PM   #9
PGW Professional
Magnettica's Avatar
But certainly not a violation.
Old 07-11-2012, 09:10 PM   #10
Good at being Evil
Shockdoc's Avatar
Looks good, nice GE panel.
Old 07-11-2012, 09:28 PM   #11
Absolutetruthz's Avatar
POCO requires main DC within 2ft of meter here.
Absolutetruthz is offline   Reply With Quote
Old 07-11-2012, 10:16 PM   #12
You are correct about the 6 throws, but that panel only has one breaker in it. So there is no code violation until the 7th breaker is added.
I can not quote the code section off the top of my head, but it is my understanding in 3R applications a hub is required unless the conduit entry is under the buss bars, etc.
Old 07-11-2012, 10:21 PM   #13
Hmm! Well, I'll have to look into that further then... I've only ever used them on the horizontal surfaces, and the inspectors haven't dinged me yet. I'll try and find the article tonight, thanks!
Old 09-18-2012, 10:06 PM   #14
is there a disco for that condenser??
donselec is offline   Reply With Quote
Spot the code violations jewalker88 Residential Electrical Forum 44 01-25-2013 11:28 AM
Are these code violations? Vapour Trails Code Violation Discussion 21 04-18-2012 10:02 PM
Building code violations RIVETER Commercial Electrical Forum 11 02-09-2010 12:17 PM
How many code violations at your house? BuzzKill General Electrical Discussion 62 04-12-2009 11:44 AM
Look here for some code violations! Joe Tedesco Code Violation Discussion 0 05-17-2007 11:55 PM
