I've seen very few 3PH chargers that can be operated on single phase. On some of the older ones you could parallell the 3 xfmrs, but not the newer ones.
I've seen a few single phase 48DC chargers, usually in smaller ratings. Some of them will charge a big battery, but they take a long time. Others have a min. and max. amp-hour rating.
I doubt a static phase converter would work, since it depends somewhat on the motor's counter-EMF to generate the third leg. I could easily be wrong here, I just have a bad feeling about it.
A rotary phase converter should work ok, I've never used one for a battery charger yet. Make sure the control power xfmr is not on the generated leg. Some converters generate the A phase, and alot of chargers use A and B for the controls.
Rob.
