Originally Posted by interspark
Many thanks for your quick reply, I did consider Kirchoff's but what if the current exceeds the breaking capacity of one fuse wires at the node.
regards
If they're both identical, and properly connected at both ends, how could more current ever flow in one more than the other?
This is the basis of how "cable protectors" are employed in parallel wired industrial installations. If something fails by some means in a parallel conductor, the cable protector will open. This may take out several others, due to the increased load on them, and perhaps the main fuses protecting the whole bunch of paralleled conductors.
I realize you're in the UK, and I'm replying with US terminology, but maybe you get the idea.
