Old 04-23-2012, 09:29 PM   #1
Default Grounding Bushings
Are grounding bushings required on a sub panel feeder.
Feeder is a 277/480 volt, 3 phase, 4 wire, 2500 amp.
Ten 3" EMT conduits paralleled out of the power source panel overhead using concentric knock outs.
Each conduit has 4 # 350 mcm Al and 1 # 600 AL equipment ground.
Jsaarc is offline   Reply With Quote
Old 04-23-2012, 09:33 PM   #2
Look at 250.97 and welcome to the show
Old 04-23-2012, 09:37 PM   #3
Thank you.
Grounding bushings Nyspark21 General Electrical Discussion 4 01-25-2012 11:09 PM
Grounding Bushings RobertM NEC Code Forum 4 12-04-2011 08:59 PM
grounding bushings ecelectric General Electrical Discussion 4 03-16-2011 03:27 PM
Grounding Bushings qckrun NEC Code Forum 19 03-16-2011 12:44 PM
Use of grounding bushings Runway NEC Code Forum 2 03-04-2010 10:55 AM
