high leg - Electrician Talk - Professional Electrical Contractors Forum
Old 12-20-2008, 05:16 PM   #1
Rewards Points: 27
Default high leg
When do you find a high leg in a service. is it typically in a 3 phase 120/240 panel or is it in a 120/208 3 phase panel? the concept is kind of confusing and when do you use the high leg?
highlandele is offline   Reply With Quote
Old 12-20-2008, 05:37 PM   #2
Semi-Retired
BryanMD's Avatar
a picture is worth 1000 words:
November 2011: Relocated to Winston-Salem.
May have to change the username suffix.
Old 12-20-2008, 05:39 PM   #3
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
http://en.wikipedia.org/wiki/High_leg_delta
Old 12-20-2008, 05:40 PM   #4
Licensed Journeyman
nolabama's Avatar
high leg is off of a delta and 120/208 is a midpoint grounded wye
Old 12-20-2008, 06:16 PM   #5
Rewards Points: 1,464
I never encountered a corner grounded ,mid tapped delta 3 phase xfmr .240/120 as in diagram.
Old 12-20-2008, 06:59 PM   #6
Fluke Skywalker
walkerj's Avatar
Rewards Points: 1,002
That's not corner grounded. It is a decieving pic
walkerj is offline   Reply With Quote
Old 12-20-2008, 07:03 PM   #7
Semi-Retired
BryanMD's Avatar
I've only worked one job with a high leg service. It was way way up in the mountains in California. It was used because that is what was there.
we covered corner grounded last week.
Old 12-20-2008, 07:06 PM   #8
Licensed Journeyman
nolabama's Avatar
i would say its 50/50 high leg delta vs midpoint wye around here
Old 12-20-2008, 07:30 PM   #9
Rewards Points: 2,096
The high leg, or wild leg, or snake leg, or bastard leg, is found when a service supplies a building with 240 V 3 phase. Because at least some of the lights and equipment will need 120 V, one of the transformers is sized larger and center tapped. The center tap allows A and C phase to have a neutral and therefore 120 V available.
In my area of the country, there are very few 120/240 delta systems left in service, at least as far as I have seen, which I guess ain't saying much.
I was called in after another electrician was fired to fix a remodel where the original sparky wired the receptacles in the window display to the high leg. Lots of tvs burned out. As far as I know, the high leg itself isn't used to power loads normally. I guess that any single phase 208 V equipment would work on a single pole breaker, but that is a novel and non-standard application.
I think that delta services were preferred for places that had large motor loads, because the current divides among the transformers, and each coil sees less current.
Old 04-08-2010, 03:11 PM   #10
Generator Sales
yucan2's Avatar
The high leg is simply part of the 3 phase network and useable in any 3 phase or single phase 240 volt equipment.
The high leg is not used ever for 120v loads.
yucan2 is offline   Reply With Quote
Old 04-08-2010, 05:27 PM   #11
yes and your also not suppost to make love to 480 v bus duct. Is it just me or is anyone else sick of people posting replies that JUST STATE THE OBVIOUS. of coarse you dont use the wild leg for 120v loads BECAUSE THE WILD DOES NOT PRODUCE 120 V TO NEAUTRAL
Nephi is offline   Reply With Quote
Old 04-08-2010, 05:33 PM   #12
dont eat the yellow snow, look both ways before crossing, make sure you tighten your wire nuts,pay your taxes, wait a half hour to swim after eating, dont shoot at police officers, dont put deisel in a gasoline engine, dont kill and steal because its illegal, dont use bare conductors as hots.
Old 04-08-2010, 05:59 PM   #13
Generator Sales
yucan2's Avatar
This apparently is or was not obvious to the OP. We weren't all born knowing this stuff as you apparently were.
Old 04-08-2010, 06:07 PM   #14
I believe his question was answered I think you just like seeing hearing yourself type but actually i wasnt born knowing everything thats what my home depot electrical 123 was for, finished it last night so now i believe i do know everything
Old 04-08-2010, 06:08 PM   #15
go ahead...try me...just nothing about 4 ways, still a little confusing to me
Old 04-08-2010, 06:23 PM   #16
Shock & Awe
Wingman's Avatar
Default One High leg will make u lean over
Most high legs are found in older buildings or farming pumps
Life is nothing but a bunch of lessons you can learn from them and move forward or continue to repeat them over and over and waste your time!
So take personal responsiblity!
Wingman is offline   Reply With Quote
Old 04-08-2010, 06:38 PM   #17
Vintage Sounds's Avatar
Rewards Points: 3,988
Go away
Old 04-08-2010, 07:44 PM   #18
Generator Sales
yucan2's Avatar
If I enjoy seeing myself post why do I only have 4. 2 wasted on the likes of you.
Old 04-09-2010, 03:14 AM   #19
goose134's Avatar
Except how to capitalize.
A professional in an amateur world.
more stuff High volt ??? bigredc222 Vintage Electrical 8 01-31-2013 06:29 PM
High Impedance Grounding Problem Mountain Electrician General Electrical Discussion 4 11-12-2008 01:41 PM
The high leg is in the neutral position Joe Tedesco Code Violation Discussion 6 05-20-2007 10:02 PM
Looking for Work in the High Desert Kessler1369 General Electrical Discussion 0 03-20-2007 08:30 PM
High profile projects. MDShunk General Electrical Discussion 1 01-28-2007 01:35 PM
