Old 11-17-2009, 02:51 PM   #1
Default Humming noise coming from panel
My bro-in-law called me and he said they have a humming/sizzling noise coming from their panel. It's a 100A service with a new panel recently installed. I know there is 1 ground rod installed. He believes it's normal.
Everything seems to be working ok. I haven't went and looked at it, but I thought I would tap into a huge pool of knowledge here first. Thoughts?
Where did we go back to before the drawing board was invented?
wvwirenut is offline   Reply With Quote
Old 11-17-2009, 02:57 PM   #2
Toronto Sparky's Avatar
Likely a loose connection or breaker loaded to the max.. Assuming it's not a FPE panel..If thats the case run!
Don't fight .. Play nice!
Old 11-17-2009, 03:23 PM   #3
Knowing him, I'm sure its an overloaded breaker. Thanks.
Old 11-17-2009, 03:30 PM   #4
Bell Transformer? These are sometimes located near the panel.
RMatthis is offline   Reply With Quote
Old 11-17-2009, 03:39 PM   #5
Definitely no bell. The dogs are his door bell.
The house was his grandmothers and has been "rewired."
Old 11-17-2009, 03:56 PM   #6
Jobless Extraordinaire
Grimlock's Avatar
Thats not normal for a Resi panel, I bet you'll find a hot spot pretty quick.
Grimlock is offline   Reply With Quote
Old 11-17-2009, 05:10 PM   #7
B4T Scotchkote installer
Black4Truck's Avatar
I have had bad breakers hum.. change them and problem solved
Old 11-17-2009, 06:35 PM   #8
cdnelectrician's Avatar
Any GFCI or AFCI breakers in the panel? I have heard these hum before.
Old 11-17-2009, 07:40 PM   #9
Had one on sat. that was humming found the main to be hot to the touch changed the main checked the grounds/neutrals pulled the meter checked the neutral, even went as far as checking the taps on top of the services head everything is fine now. I seem to find myself always going the extra.
Sparky480 is offline   Reply With Quote
Old 11-18-2009, 03:28 PM   #10
No GFCI or AFCI breakers. I'd bet there isn't a GFCI recep anywhere in the house. I'm going over this weekend to check it out.
Thanks guys.
Old 11-18-2009, 06:28 PM   #11
JayH's Avatar
Thanks guys.
Did this just recently start humming?
Waiting till the weekend may be too long, especially in an older home.
Hope the smoke detectors are functioning.
Upping my post count one mistake at a time!
JayH is offline   Reply With Quote
Old 11-19-2009, 10:11 AM   #12
No, It's been going on for quite a while from what I understand.
Old 11-19-2009, 01:53 PM   #13
frank's Avatar
Give the board a thermal heat check first. Then look to mechanical/electro problems if this proves safe ,
Old 11-19-2009, 05:44 PM   #14
drsparky's Avatar
Maybe it hums because it doesn't know the words.
Old 11-30-2009, 06:17 PM   #15
This reminds me of my all time favorite service call.
A lady tells me there is a humming sound somewhere and asks me to figure it out. We walk into her bedroom and I quickly trace the noise to a vibrator under the blanket on her bed.
I picked it up, turned it off, looked her in the eyes and said "Here's your problem right here Maam".
I figured she rubbed one out and fell asleep while it was still running.
Humming CFL's? Briancraig81 General Electrical Discussion 21 10-20-2009 12:12 PM
Humming? qckrun General Electrical Discussion 27 09-18-2009 07:00 AM
Humming/Growling noise rockstrong General Electrical Discussion 0 06-17-2009 09:53 PM
static noise Bkessler General Electrical Discussion 9 02-05-2008 11:08 PM
electrical noise on feeder muzafferz General Electrical Discussion 6 12-29-2007 11:07 AM
