Old 01-02-2012, 08:23 AM   #1
Default Mast/Riser wire
What are most of you guys using on 200A resi risers (2" rigid w/ weather head)? I haven't done an overhead service in years that the Poco didn't do the mast. This one needs to be nice/not PVC and I don't think they would do it like I want. I think the last one I did I either didn't run the wire in or stuck a peice of 4/0 AL USE triplex. They might not require the wire to be in, can't remember. This is in central NC.
guitarchris is offline   Reply With Quote
Old 01-02-2012, 08:45 AM   #2
If is is a mast then it must be 2" rigid. A mast will usually support the overhear drop. A riser does not support the overhead lines so pvc is adequate
Old 01-02-2012, 07:34 PM   #3
Yes Mast. The question was do you generally provide the wire or let the poco? If any of you are providing the wire what are you using? I didn't provide the wire for the one I did today, but it got me thinking about what would be the correct type.
Old 01-02-2012, 08:39 PM   #4
mbednarik's Avatar
if it is a riser i usally use EMT or pvc.
Old 01-02-2012, 09:01 PM   #5
PGW Professional
Magnettica's Avatar
Do you have clearance, Clerance?
Old 01-02-2012, 09:13 PM   #6
Bulldog1's Avatar
If it penetrates the roof we have to run rigid. If it doesn't we run PVC. 4/0 xhhw-2 AL conductors.
The Following User Says Thank You to Bulldog1 For This Useful Post:
Chris1971 (01-02-2012)
Old 01-04-2012, 08:25 AM   #7
We have clearance since we added the mast . Before, the service change the attachment point was at about 8.5 ft. The roof was about 9'. There was no overhang on the roof so I just ran the rigid up and strapped it with two hole straps with 4" lags so it wouldn't pull off the wall. Simple install, turned out great, especially compared to what they had before. Should have taken pictures of the crap they had......the bottom of a coke can glued/painted to the old meter base as a KO seal, SE pinched between panel can and outside sheeting and brought into the back KO with no connector or bushing, etc. It was a true hack's mess.
Old 01-04-2012, 11:18 AM   #8
Amish Electrician's Avatar
What does the PoCo want?
Most utility companies have their standards available, free, on the internet. For example, here is a link to one in Arkansas: http://www.entergy-arkansas.com/Glob...above_roof.pdf
I included the link, so that you can see the detail that such specs have. Yours is probably very similar - but it's worth checking out.
Typically, you need to provide enough wire that there is at least 36" available to the linesman. You will need to mark the neutral- maybe even be required to use shrink tube or white insulation, rather than just tape. You may also be required to provide the attachment bracket for the PoCo line. You mast need to guy or brace the mast as well.
You are generally not required to provide the connectors; the PoCo likes their own.
Amish Electrician is offline   Reply With Quote
The Following User Says Thank You to Amish Electrician For This Useful Post:
mrmike (01-04-2012)
Old 01-04-2012, 03:02 PM   #9
Buying triplex USE is usually cheaper than individual cuts of XHHW.
And yes, it is dual rated, friggin' nazis.
Old 01-05-2012, 07:06 PM   #10
Service Call's Avatar
Here's a 200amp with a 2" galv. riser with 2-2/0 cu & 1-1/0 and roof boot.
Old 01-06-2012, 01:14 AM   #11
http://www.southwire.com/products/RHHRHWUSEOEM.htm
400A Resi Riser Question? Mr. Sparkle NEC Code Forum 14 08-25-2011 03:43 PM
Upgrading service riser/mast/weatherhead wizzard717 Residential Electrical Forum 11 12-05-2010 10:33 AM
1-1/2" riser Bkessler Residential Electrical Forum 17 05-27-2010 11:35 PM
Here's how we back brace a tall riser/mast 220/221 Services and Service Equipment 44 12-10-2009 09:11 AM
1 riser 2 meters NolaTigaBait NEC Code Forum 30 06-27-2009 09:25 AM
