panel mounting on a round light pole - Electrician Talk - Professional Electrical Contractors Forum
Old 06-08-2009, 08:37 PM   #1
KEI
Default panel mounting on a round light pole
I am installing lights for a football field. I am looking for ideas how to get a load center to mount to a round steel pole. Any ideas for a neat yet solid installation??
KEI is offline   Reply With Quote
Old 06-08-2009, 08:43 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Unistrut.
Old 06-08-2009, 09:09 PM   #3
Rewards Points: 150
Galvanized 3/8 all thread,bend into horseshoe dia of pole cut unistrut width of panel. Bolt in place.
acmax is offline   Reply With Quote
Old 06-08-2009, 09:22 PM   #4
220/221's Avatar
Rewards Points: 3,574
I concur ^ ...edit: (but I'd skip the strut)
I'd add a couple of self tappers thru the panel into the pole too.
Old 06-08-2009, 09:23 PM   #5
KEI
the poles have a bronze finish, I would like to protect the finish as much as possible
Old 06-08-2009, 09:29 PM   #6
220/221's Avatar
Slip some tubing over the all thread?
It will mount to the pole with self tappers lined up vertically but someone could twist it off if they wanted to....unless it was a rather large pole.
Old 06-08-2009, 09:30 PM   #7
Zen Student
Buddha In Babylon's Avatar
Rewards Points: 250
How about heat shrink over the 3/8 all thread to protect the pole?
Buddha In Babylon is offline   Reply With Quote
Old 06-08-2009, 09:37 PM   #8
william1978's Avatar
Rewards Points: 2,000
Originally Posted by 220/221 View Post
I concur ^
This is exactly how I would do it also.
Old 06-08-2009, 09:52 PM   #9
Red Flag!!!!!
Does 'bronze' mean this is a manufactured steel light pole?
You'd better check with the manufacturer if so.
Old 06-08-2009, 09:54 PM   #10
Rewards Points: 150
Double sticy tape 1'' wide 1/16 gasket rubber line it up. last forever sray paint all thread black proir to mounting.
Old 06-08-2009, 10:22 PM   #11
drsparky's Avatar
Rewards Points: 484
Spend a buck, homemade "U" bolts look bad, are weak and look unprofessional. You can get any size of stainless "U" bolts at a plumbing supply house.
Also pay heed to 480sparkys post.
Old 06-08-2009, 10:29 PM   #12
Rewards Points: 150
??What
Old 06-08-2009, 10:31 PM   #13
KEI
Red Flag!!!!!
They are manufactured steel light poles with a bronze finish. Do you think the manufacturer would have a suggestion?
Old 06-08-2009, 10:40 PM   #14
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 586
bending all thread weakens it significantly (bad practice)
the manufactured u bolt idea is nice, or you could also have a local fabricator make you some thru bolted flange for mounting (sometimes done when new steel has to be added to existing round columns, although probably overkill for your application)
Old 06-08-2009, 10:41 PM   #15
drsparky's Avatar
Rewards Points: 484
??What
It's pretty clear; all thread is designed for tension loads. It is not rated to be formed into a U shape. If you need a U bolt buy a U bolt.
Old 06-08-2009, 10:58 PM   #16
Rewards Points: 150
You got to be kidding, bending all tread bad practice? I have 30 yr installs done just the way I explained it. I'm sure if the OP wanted to go into structural engineering for this simple panel mount he could try e-mailing NASA. Most times simple is best. And if there is the right size and place to get the U bolt just as good.But I doubt easy to find.
Old 06-08-2009, 10:59 PM   #17
The manufacturer's suggestion would be "Don't".
Old 06-08-2009, 10:59 PM   #18
i have to disagree. the rating of the all thread may be compromised, but, more specifically on a wooden pole, the panel isn't budging without some extra assistance, i.e., sledgehammer, car, etc. at which point nothing is gonna help
vinster888 is offline   Reply With Quote
Old 06-08-2009, 11:02 PM   #19
KEI
Don't mount a panel on the pole?
Old 06-08-2009, 11:02 PM   #20
220/221's Avatar
??What
Again, I concur^
Bending all thread will make NO difference in this application. The nuts would strip off before the rod broke.
ANY size? This pole could be 12" diameter. Stainless is a far superior product but it's not necessary. If it was readily available I'd use it but I wouldn't spend a lot of time looking for it.
Paint the all thread bronze and move on.
Meter mounting base ? James Con Tools, Equipment and New Products 8 05-03-2010 03:43 PM
Mounting pull station on extrusion. MDShunk Other Codes and Standards 19 03-17-2010 11:20 PM
Aerial feeders for a light pole De Vassco Lighting Design 9 05-06-2009 12:42 AM
Cutting in round old work boxes.. hayan453 General Electrical Discussion 43 03-15-2009 05:02 PM
I need a 2 pole 40 GFCI breaker for Challenger Panel 00Funk Services and Service Equipment 5 10-20-2007 04:30 PM
