Old 10-09-2009, 10:41 AM   #1
Tallman
Default Parallelling resi feeder
This is my first job where I think I will have to parallel the underground. The run will be close to 500'. This house was originally going to be off-grid, but the situation changed and now the architect/owner is thinking he has to add more and more loads. We're shooting for something in the range of 125-150 amps @ 3% VD. Two runs of 4/0 seems to be more cost effective than one of 500kcmil (by around $1500. my cost). I'm hoping to direct bury mobile home feeder. One of my questions is: Can I make one run triplex and the other one quadriplex if they are in close proximity to each other? Also, can I bug and tap the runs within the 200A milbank metermain enclosure and the 200A square D QO panel? Any suggestions would be greatly appreciated.
bharbwyr is offline   Reply With Quote
Old 10-09-2009, 12:55 PM   #2
Speedy Petey's Avatar
You really think you need parallel 4/0AL for 500'? I would think single 350 would be fine.
How are you figuring VD?
What does your POCO say?
Old 10-09-2009, 10:57 PM   #3
wildleg's Avatar
I must be missing something. why do you need quadriplex ?
That tiger ain't go crazy; that tiger went tiger! You know when he was really crazy? When he was riding around on a unicycle with a Hitler helmet on! - chris rock
Old 10-10-2009, 06:45 AM   #4
JohnJ0906's Avatar
It seems he is running from a metermain to the house, which would mean an EGC is needed.
If this is the case, remember 250.122(B) and (F)
John from Baltimore
"One day at a Time"
Old 10-12-2009, 01:26 PM   #5
Tallman
Right. This is after the meter. And I did the calc.s longhand and using a online program (they agreed! Yea!)but got mentally hung up in that my suppliers did'nt carry the 350 in quad. It looks now like I will be going with the 350 use-2 and add a #1 for the EGC. That should give about 119 amps @ 3%VD
314.29 (or another reason I hate resi) Chris Kennedy General Electrical Discussion 29 09-27-2009 09:56 AM
Resi-Guy turned commercial... Resiguy Commercial Electrical Forum 32 08-31-2009 09:45 PM
Resi-guy from Detroit richrock1605 Introductions 7 07-10-2008 07:24 PM
Feeder Tap Absolutetruthz Services and Service Equipment 4 03-02-2008 02:39 AM
Resi work question highlander General Electrical Discussion 28 04-07-2007 08:05 PM
