Originally Posted by Pierre Belarge
MD
I do not believe you would permit the leader over this equipment, the improper fittings and all the other "industrial strength cr_p".
No, the rain gutter would have to go, you're right.
I do see some M&W weatherproof SER fittings entering the side of the can, without Meyers hubs. Is that the improper fittings you're referring to? I'd like to see Meyers hubs, or at least sealing rings on these M&W fittings. I'd absolutely have used Meyers hubs between the meter and the CT can, but this may have been done by BG&E's people. It is sorta humorous to see not one, but three inspection stickers on this equipment.
