04-09-2010, 10:21 PM
Preference for service masts
If you have a choice, do you use IMC, EMT or RNC for your service mast/drop?
I see lots of magazine advertisements for PVC weatherheads, and I was wondering if anyone ever routinely use them versus metallic weatherheads.
Thanks,
Rick
04-09-2010, 10:22 PM
Chief Electron Relocator
IMC. Never touched a PVC weatherhead. Can't say I've even seen one in the wild.
04-09-2010, 10:38 PM
I have installed quite a few PVC weather heads, but all of them were for temporary services. I have used 2 1/2"--3" and 4" PVC weather heads.
If it is a permeate installation I would use IMC.
04-09-2010, 11:56 PM
child please.....
Depends. There are alot of services that I must use imc. If not, I like emt...My old boss loved using pvc...but I really prefer emt.
04-09-2010, 11:59 PM
I can see EMT and PVC for a riser, but certainly not for a mast.
Unless you like doing the job more than once.
04-10-2010, 12:00 AM
I have a black cat.
IMC.
Never seen a pvc one, sounds pretty cool.
04-10-2010, 12:12 AM
child please.....
Guess, I didn;t read it carefully...You know what I meant.
04-10-2010, 12:13 AM
child please.....
Why would you even use a pvc weatherhead on imc? Don't they cost more?
04-10-2010, 12:16 AM
hiamp
We use PVC weatherheads quite often here in Washington because of the moisture (they don't rust). If the strike is on the house, we use PVC for the mast also. If the strike has to be on the mast, we must use IMC. Never have used EMT for a mast.
04-10-2010, 12:35 AM
Strike?
04-10-2010, 12:43 AM
hiamp
Strike?
Strike plate or Knob
04-10-2010, 01:09 AM
I thought we were talking electrical masts, not doors.
04-10-2010, 01:56 AM
Everything is IMC or RMC here.
04-10-2010, 03:57 AM
In Ontario pretty much, if the insulator is attached to the wall and you have the height, most will use PVC. Other then that you are using a rigid stack for overhead services.
Some places will allow a Teck90 or Corflex for service conductors overhead, but in 20 + years I have only done that once. I believe that Teck90 is common in British Columbia (quake zone).
Cheers
04-10-2010, 07:04 AM
04-10-2010, 08:46 AM
If it's a riser, I use either SE cable or PVC
If it's a mast, I normally use IMC. If it's an especially tall mast, that will need guyed back, I use RMC.
I've only used EMT for a riser one time, and that was due to cost.
04-10-2010, 11:48 AM
hiamp
What do you call the attachment that the power co hooks their wire to?
04-10-2010, 12:10 PM
#18
I should put this int he "Slang Thread", here we call them insulators or spool racks. I believe the Canadian code calls them Point of Attachment. Never thought about it actually, I have generally called them spool racks.
Cheers
04-10-2010, 02:15 PM
#19
Just to be clear, a mast is not the same as a riser. The main difference is a mast usually penetrates the roof and extends upward of the roof line. Here it is RMC.
In terms of a riser we always use PVC with a PVC weatherhead. That being said most of our jobs are underground.
04-10-2010, 02:29 PM
#20
I have a black cat.
Screw knobs screw on the side of the house, a mast collar collars the mast.
I think.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
800 amp service
sparkyflettgr |
Services and Service Equipment |
14 |
06-13-2010 05:24 AM |
UG Service
Magnettica |
33 |
03-22-2010 12:56 AM |
200 Amp Service
WireNut |
Residential Electrical Forum |
25 |
03-16-2010 09:03 PM |
Your lay in fixture preference....
Mr. Sparkle |
Lighting Design |
18 |
10-09-2009 11:00 PM |
400 amp service
chilsonel |
3 |
02-20-2009 04:14 PM |
