06-06-2009, 09:41 AM
#21
Electrical Contractor
Originally Posted by paul d.
dont the ground bar have to be mounted on isolator type stand-off??? we normally put ground bars on stand-offs for tel/data boards in comm work.
I'm not sure what his plan is. He may have just had that temporarily hanging there, or just using the wood for the insulator.
Jim
06-06-2009, 11:51 AM
#22
I split bolted from the #6 and ran it to the ground bar. I was under the impression you couldnt bring the catv ground into the panel hence the external ground bar seperated from line voltage. Yes this was under supervision of the master electrician i work for.
06-06-2009, 11:54 AM
#23
Is his name Bob Badger or I Wire?
06-06-2009, 12:07 PM
#24
No i dont know those guys.
06-06-2009, 12:10 PM
#25
Seen your member
I would put a little more tape on the white wire going to breaker #11.
06-06-2009, 02:29 PM
#26
Originally Posted by Speedy Petey
So did you do this job under your boss?
Yes... His Dad
06-06-2009, 03:17 PM
#27
My dads a mechanic try again
06-06-2009, 05:32 PM
#28
So was this a side job or your day work?
06-06-2009, 07:20 PM
#29
You said in your first post that this was at your parents' house. Your Dad was standing there the whole time breathing down your neck. Admit it...
06-06-2009, 08:24 PM
#30
haha my dad wouldnt know what hes looking at. He didnt bother me in the least
06-07-2009, 11:00 AM
#31
IBEW Local 970 Member
Honestly, there is a lot of copper showing on the breakers, you need to trim a little less insulation.
06-07-2009, 03:01 PM
#32
Unlimited Lic.Electrician
You will.
06-17-2009, 08:55 AM
#33
You missed a bushing on the SE connector!!!!! You better fix that,,,,,could be a very loud boom in your parents house!!!!!!!
06-17-2009, 08:58 AM
#34
You're exceeding the bending radius of the grounded conductor and phase conductors,,,,,,,,,why the looptiloos?
06-17-2009, 11:36 AM
#35
Originally Posted by mcclary's electrical
You missed a bushing on the SE connector!!!!! You better fix that....
He doesn't need to fix what is already code compliant per NEC. No need for a bushing.
06-17-2009, 10:38 PM
#36
Part Time Despot
Agreed.
-George
06-18-2009, 10:22 AM
#37
I didn't say he had to per NEC,,,,I just said he should put a bushing on,,,,I never do a service without them,,,,,,,just like there's no card article that MAKES you put the little red bushing in the end of MC cable,,,,but I do it anyway!
#38
Besides,,,,he still exceeded the bending radius and it would not pass in VA
06-18-2009, 03:58 PM
#39
Well what should he use as his guide then if it's not the NEC? Should he use the Electrician's Guide To Overkill Installations authored by you? I think not. Also, It would totally fly in VA. What county would it not fly in?
06-18-2009, 04:35 PM
#40
Part Time Despot
Bend radius of what?
-George
