Replacing an old Sylvania/Zinsco panel? - Electrician Talk - Professional Electrical Contractors Forum
Old 04-20-2011, 11:16 AM   #1
Rewards Points: 26
Cool Replacing an old Sylvania/Zinsco panel?
Greetings, all!
I need to replace an old 20/40 Zinsco/Sylvania panel, and need to find a panel that is the same size, as this one is built into a wall. The panel is 36" high, 18" wide, and is a 200A panel with meter socket. Any suggestions?
Thanks
North Coast Lights is offline   Reply With Quote
Old 04-20-2011, 11:25 AM   #2
Rewards Points: 3,855
I think your best choice would be to either rape the guts and cover from an NQOD panel, or get one of CH's retrofit panels that they custom make to your can.
The Following 2 Users Say Thank You to MDShunk For This Useful Post:
Magnettica (04-26-2011), North Coast Lights (04-20-2011)
Old 04-21-2011, 12:09 AM   #3
Rewards Points: 666
Originally Posted by North Coast Lights View Post
Greetings, all!
Thanks
I don't see how a retrofit panel will work in a semi-flush panel, nor slapping in the guts of NQOD, panel either, if this is the typical Zinsco/Sylvania "all-in-one" panel the metering is down on 1/2 the panel & the distro section is on the other half, making it too narrow for anything, ripping out the old one & installing a new panel seems to be the only choice.
Norcal is offline   Reply With Quote
The Following User Says Thank You to Norcal For This Useful Post:
North Coast Lights (04-21-2011)
Old 04-21-2011, 10:33 AM   #4
Bkessler's Avatar
Rewards Points: 2,000
Todays work
When ls lunch?
Old 04-21-2011, 10:50 AM   #5
Rewards Points: 26
I was afraid of that, but I'm not sure there's another choice. I haven't found another panel that can hold 40 breakers that can fit in this space. Mayb e it's time to break out the power saws and the hammers.
Thanks for the reply.
Old 04-23-2011, 11:23 PM   #6
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I run into this issue all the time. Some minor carpentry skills are necessary if you're doing service work. You know, old work.
Replies based on NEC 2014
The Following User Says Thank You to Magnettica For This Useful Post:
North Coast Lights (04-24-2011)
Old 04-24-2011, 12:16 PM   #7
Rewards Points: 26
It's amazing how often we electricians end up being carpenters, sheet metal workers, fabricators, etc. etc.
Old 04-24-2011, 12:42 PM   #8
steelersman's Avatar
Greetings, all!
Thanks
I just tell the customer that there will be drywall repair that will need to be done after I install the new panel. Then I proceed to cut the drywall out roughly 6" higher and lower than the dimensions of the new panel.
Old 04-24-2011, 01:33 PM   #9
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I take great pride in it. I shouldn't really say "carpenter skills" because all I'm really doing is securing a couple blocks of wood to a concrete foundation and attaching a sheet of a cut plywood, then painting it. But I have seen where an electrician has built a studded wall attached to the ceiling and floor and then attached plywood to that and then mounted all the electrical equipment. That was actually a really nice looking install.
Some other minor carpentry skills include pulling away base molding trim to drill a pilot hole to know where to drill up from the basement or whatever. Also, knowing precisely how a dwelling unit is framed definitely helps when snaking in an old home.
Old 04-24-2011, 08:15 PM   #10
Rewards Points: 666
Is the siding stucco or wood / wood "product"?
Old 04-24-2011, 10:28 PM   #11
Bkessler's Avatar
If the house is stucco, you have to replace the stucco and do the proper flashing to keep moisture out if the wall. Chapter 14 of the U.B.C.
When ls lunch?
Old 04-25-2011, 10:10 PM   #12
Rewards Points: 5,198
What I have done is ...with the approval of the inspector, purchased new panels and gutted them and inserted into the old panel. I contacted the inspector ahead of the work to make sure he would have no problem with it because of size of panel considerations.
Old 04-25-2011, 10:37 PM   #13
what does this do for the UL rating..are you covered on this.if i understand correctly you took the guts out of old panel and installed them in new panel?" there are alot of torque ratings,space reqmts, etc,etc, involved here. but alot of times we have to do things to make chicken soup from chicken sh**
rnr electric is offline   Reply With Quote
Old 04-26-2011, 12:13 AM   #14
Rewards Points: 666
The panel in question does not lend itself to installing guts from another panel.
Picture is not the same manufacturer of course, but gives a idea of the panel.
Old 04-26-2011, 01:04 PM   #15
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
That's a nice looking install. Cutler Hammer CH too, that's value. I even like the trim around the enclosure.
Old 04-26-2011, 02:04 PM   #16
Rewards Points: 26
It does look like a nice install. The panel I'm replacing is between two 2x6 studs on 16" centers. I may have to have a carpenter come in and increase the width (with appropriate added load-bearing horizontals) to accommodate the new panel, unless I can find a 20/40 with meter that wlil fit.
Old 04-27-2011, 08:50 AM   #17
Rewards Points: 666
Thank you, it happens to my house panel, BTW it fits between 16" centers, even junk panels made by SQ D (HOM)*, C-H BR, GE will fit.
*QO was discontinued in favor of Homeline in those type of panels years ago.
Old 04-27-2011, 08:57 AM   #18
Rewards Points: 2,002
You can't get a QO all-in-one? What a shame.
Old 04-27-2011, 08:17 PM   #19
Rewards Points: 666
Not since SQ D introduced the HOMO line.
replacing panel guts only N PHILLY KID Residential Electrical Forum 16 10-27-2011 10:16 AM
4' T8 lamps Philips, Osram-Sylvania and GE are mostly Made in the USA Electric_Light Lighting Design 9 06-20-2011 05:43 PM
Sylvania Ballasts = Junk? crazyboy General Electrical Discussion 10 02-16-2011 04:43 PM
Replacing an old aluminum fed sub panel.. Tom Neighbarger Residential Electrical Forum 4 05-26-2010 03:04 PM
Sylvania 60/ 70 Magnettica General Electrical Discussion 35 02-06-2010 09:22 AM
