Old 05-23-2008, 01:33 AM   #1
Absolutetruthz's Avatar
Default Service Entrance Conductors
Suggestions on what you guys use to splice Service Entrance Conductors to the Service Drop Conductors from the POCO. I have always used Butt splices. Is there any other preferred methods?
Absolutetruthz is offline   Reply With Quote
Old 05-23-2008, 06:22 AM   #2
Whatever the POCO specs. We don't get choices.
We use Fargo bugs and covers.
Old 05-23-2008, 06:54 AM   #3
IBEW Local 661 JW
Rong's Avatar
Speedy I have not heard the term Fargo bugs. Are they like the Blackburn W compression connectors and C covers? Been along time since I have spliced a service entrance cable, and for the life of me I cannot remember the exact number of the W type connectors. Not 100% sure that they are even Blackburn brand... As I have always said. " Of all the things that I have lost it is my mind that I miss the most!"
I too am bilingual :
I speak bad English and worser English.
Rong is offline   Reply With Quote
Old 05-23-2008, 06:54 AM   #4
I thought the POCO always made those connections? At least they do in FPL land.
POCO here uses pre-insulated butt splices and a range taking crimper for residential, and something similar to a Fargo for commercial.
Work'in For That Free Tee . . .
Be Safe Out there
Old 05-23-2008, 07:11 AM   #5
IBEW Local 661 JW
Rong's Avatar
Here is what we used.
Old 05-23-2008, 03:32 PM   #6
Always Learnin'
That looks like what I use. Mine are Blackburn H-taps or Kearneys. Whatever the brand they are always called H-taps around here.
amptech is offline   Reply With Quote
Old 05-23-2008, 09:46 PM   #7
How do those "H taps" work? Is there a special crimping tool?
Old 05-23-2008, 10:06 PM   #8
Always Learnin'
Yes, there is a tool with assorted dies I use. It is a manual tool with wooden handles resembling a set of bolt cutters. There are also hydraulic tools that are dieless and ones that use dies. There are battery powered tools as well. Google Greenlee Gator to see one of these. They are awesome but expensive.
Old 05-24-2008, 12:21 AM   #9
IBEW Local 661 JW
Rong's Avatar
And this is the cover.
Old 05-24-2008, 07:41 AM   #10
For single family dwellings we make those taps, IF we are on the approved "contractor tap-on" list.
Old 05-24-2008, 07:52 AM   #11
For the life of me I can't find an image of a Fargo bug and cover.
They are similar, sort of, to the Blackburn parallel groove connector with a cover.
Old 05-24-2008, 07:53 AM   #12
I Love My Job
Greg's Avatar
Same here in this neck of the woods. Plus it can get interesting and confusing at times, dealing with FPL, OUC, KUA, and Progress Energy, and all of them have their own way of doing things.
Memorial Day: All gave some but some gave all.
Take the time to tell a Veteran Thank You, You owe him/her at least that much. After all Freedom is not Free.
Old 06-03-2008, 04:50 AM   #13
Mountain Electrician's Avatar
Here the POCO makes the connections as well.
Old 06-07-2008, 05:29 PM   #14
We're only required to do temporary splices, although often the POCO leaves them permanently. I used to use split bolts, but butt splices are cheaper and MUCH easier to install.
Dave
Tiger is offline   Reply With Quote
Old 06-08-2008, 12:21 AM   #15
POCO makes those connections here as well.
iaov is offline   Reply With Quote
Old 06-08-2008, 03:16 PM   #16
IBEW Local 661 JW
Rong's Avatar
I have seen big blues (wire nuts) used before....not something I'd try however
service conductors searay2006 NEC Code Forum 28 12-17-2009 03:11 PM
Service Entrance Panel cykoupai General Electrical Discussion 5 02-08-2008 09:26 PM
Service entrance walkerj Vintage Electrical 9 11-04-2007 12:06 AM
Transmission Conductors John Valdes General Electrical Discussion 16 10-16-2007 11:00 PM
UG Service Entrance Hillbilly Services and Service Equipment 11 03-20-2007 09:33 PM
