Service entrance install with a new panel upgrade - Electrician Talk - Professional Electrical Contractors Forum
Old 10-06-2010, 06:40 PM   #1
Default Service entrance install with a new panel upgrade
I am upgrading service to a 150 amp service. The existing panel is installed right in front of house facing steps coming down so I know I have to install the panel 36 inches in clearence from the wall. I do not have too many options because the wall is on right side of the steps coming down as well as in front of the steps. The wall in front of the steps is only 30 inches from edge to edge so I have to install it on the right wall the way I draw it on the picture. I had a inspector coming out if he is going to allow me to give me 1 and half inch exception since it is 34 and half inches exactly to the edge of steps and he said he will, but i need to put the meter socket next to the panel and I am not sure if I can use LB in service entrance run between the meter in the corner of the building like I drw in the picture. Also, I am not sure if they going to measure to meter socket box distance from the wall or the main panel. Does anyone might know. Any help will help.
Thank you.
martinkulik is offline   Reply With Quote
Old 10-06-2010, 06:52 PM   #2
Rewards Points: 356
I would check with the POCO. They may have a problem with it but I elieve the NEC is Okay with it.
Old 10-07-2010, 01:33 AM   #3
Rewards Points: 250
sounds like this is a san francisco city install from the looks of the photos. PGE would be ok with anything.. bunch of slackers there at PGE.
slowforthecones is offline   Reply With Quote
Old 10-07-2010, 01:36 AM   #4
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,126
PG&E allows LB's in the service if they can be sealed. Sometimes they just dont care. I would call them, make sure its OK then go forward.
~Matt
Old 10-07-2010, 11:52 AM   #5
Electrical Savant
lectricboy's Avatar
Rewards Points: 250
Thank you.
My question is, why would you upgrade to 150 amp? The cost difference of 150 & 200 amp is minimal (if any at all)!!
I'd Rather Have A Full Bottle In Front Of Me, Than A Full Frontal Labotomy
lectricboy is offline   Reply With Quote
Old 10-07-2010, 12:53 PM   #6
I know but the PGE told me they won't allow me to put 200 because of their existing lines. They are due to major upgrade sometimes in future but not right now. I wanted to do 200 and could not do it.
Thank you.
Old 10-07-2010, 12:54 PM   #7
Thats right!!!
Old 10-08-2010, 12:00 AM   #8
Jlarson's Avatar
Rewards Points: 2,836
Why even use an LB? I would just come in the side of the meter can with a Myers hub.
Jlarson is online now   Reply With Quote
Old 10-08-2010, 01:58 AM   #9
Ambassador of Amps
TOOL_5150's Avatar
Thank you.
In SF, You should stay at 150A or less - going to 200 gets them riled up and could incur you some BIG costs. At 200 the city makes PGE involved and is a big mess. Basically - If you dont have to have 200, go with 150.
Just my 2 cents..
~Matt
Old 10-08-2010, 02:36 AM   #10
BrooklineElectric.com
Rewards Points: 55
It looks like the meter and panel are over the stairs and if so, that would not be allowed by the city inspector I'm sorry to say.
John A. Peters 415-239-5393 Text/Cell
www.BrooklineElectric.com
John Peters is offline   Reply With Quote
Old 10-11-2010, 01:36 AM   #11
Rewards Points: 250
tell me more about the 150 vs. 200 and what more is involved for sf? I don't do much work in SF but may in the future.
Old 10-11-2010, 01:50 AM   #12
Ambassador of Amps
TOOL_5150's Avatar
At 200A the city will most likely want an AIC letter from PG&E to state the AIC level to check against the equipment - which means involvement with their reps - known for being a PITA - and that means PG&E fees.
~Matt
The Following User Says Thank You to TOOL_5150 For This Useful Post:
slowforthecones (10-11-2010)
Old 10-11-2010, 08:24 AM   #13
Speedy Petey's Avatar
Rewards Points: 1,914
You guys have to be joking me about this 150 vs 200 issue.
200A is the gold standard of residential services, WHY would they make such an issue out of it. It's not like the load is going to go up just because of a service change.
Each and every time I see something written about California it makes me SO glad I am over 3000 miles away. Although, the damage from the warped mentality can be felt via telepathy.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
jwjrw (10-11-2010), mcclary's electrical (10-11-2010), walkerj (10-11-2010)
Old 10-11-2010, 04:25 PM   #14
Rewards Points: 55
The gold standard may be true in California but that's not true in San Francisco, because we have natural air-conditioning, and it never snows so we'd never need more than 100 amps here. Of course there is always an exception for a huge house or in the old days some place that used all electric heat.
If PG&E were going to be required to provide 200 amps full load, they might have to increase the size of the Transformers overhead and/or underground and that's why they get the engineering department involved.
Old 10-11-2010, 04:27 PM   #15
Jlarson's Avatar
At least you have a couple thousand miles, I have like nothing.
Old 10-11-2010, 04:41 PM   #16
Fried Bologna um um good!
jwjrw's Avatar
Yea but you fit right in with that bunch from cali....
Old 10-11-2010, 04:44 PM   #17
Jlarson's Avatar
Nope,
I'm not crazy
I like guns
I don't smoke pot
I like chicks
Your argument is invalid
Old 10-11-2010, 05:52 PM   #18
jwjrw's Avatar
Nope, I'm not crazy
That is debatable and would depend on your definition of crazy.....
I like guns
So do many residents in cali....
(Hell the two biggest gun control advocates used to have ccw's to "protect themselves from right wing gun nuts" till they caught flack...now one is a deputized us marshall so she turned her ccw in...hypocrite all the way..)
I don't smoke pot
Geeze and here I thought you were cool.....
I like chicks
Sounds like a gay guy cover story to me....I love pu**y and tolerate chicks becuse they have it and I want it....
Really????? Seemed pretty convincing to miller and slick...
Old 10-11-2010, 05:56 PM   #19
Jlarson's Avatar
Chicks dig me
Vic and miller, really? That's like getting the other residents of the crazy farm to agree I'm crazy.
Old 10-11-2010, 05:57 PM   #20
jwjrw's Avatar
:laughing
Chicks dig me
Service Entrance silva.ac Services and Service Equipment 6 01-29-2009 05:51 PM
Service Entrance Conductors Absolutetruthz Services and Service Equipment 15 06-08-2008 03:16 PM
Service Entrance Panel cykoupai General Electrical Discussion 5 02-08-2008 09:26 PM
Service entrance walkerj Vintage Electrical 9 11-04-2007 12:06 AM
UG Service Entrance Hillbilly Services and Service Equipment 11 03-20-2007 09:33 PM
