Old 10-11-2007, 08:39 PM   #1
Default Service on Multi Family Dwelling
I have a set of plans for 10 buildings 8 units in each. The GC has no specs on the services just floor plans. He claims he can put 100 A services in each, but I explained thats cutiing it close. I did a load calc it comes to 115 amps in each unit. I d love to see him accept 150a but feel he is gonna wanna squeak 125s in each. The service can be done 2 ways:
1. 9 Gang meterbase with Mains and subfeed ser to each unit, but then I run into a problem with the 6 motions of the wrist deal to disconnect power to the building, solution would be a 1200 A switchgear Priceeeee
2. If I could get the local Inspector to accept 4 gang meter on left and right sides of each building. Would he look at that as 4 motions?
plus this would help with the cost of that main switchgear or even more so I wouldnt have to penetrate any fire walls to feed each unit leftside 2 on bottom 2 on top.
Any input would be greatly appreciated this is my first bid on a project this size, and man I need this job to get through this slump right now.
Would this be a job for an Electrical Engineer?
romexrocket is offline   Reply With Quote
Old 10-11-2007, 09:02 PM   #2
kbsparky's Avatar
Arrow
Some areas allow each occupancy to have its own "service" since each one has its own meter [230.2(D)] Each one of these "services" is allowed to have up to 6 disconnecting means [230.71(A)].
You should ask your local inspector-critter if (s)he accepts that premise before submitting your bid. Otherwise, you might have to eat the cost for that "Main" breaker for the meter stack assembly.
Old 10-11-2007, 09:28 PM   #3
If these multitennant buildings have a footer to roof fire wall down the middle, they might buy off on putting a 4-gang on each end. With the presence of a fire wall, I've often successfully made the case that this is really two buildings, but they touch and share a common wall.
Old 10-11-2007, 09:32 PM   #4
they acually do between the front and back units and also the 4 on the left are seperated from the 4 on the right by a breezway
Old 10-11-2007, 09:37 PM   #5
I'd sure give it a shot. See if you can get someone official to give you the go-ahead to put a meter stack on each end since the place is built that way. I have a customer that's a really super long 1-story motel. The place must be every bit of 1,000 feet long. The power hits that building in 3 places (each end and the middle).
Old 10-11-2007, 09:45 PM   #6
im gonna go down their in the morning and talk to the chief.Ill let you know the verdict thanks for all of you input
Old 10-11-2007, 10:24 PM   #7
You may need to get this designed by an electrical engineer. In my area, contractors must have electrical designed and sealed by electrical engineer for any electrical installs above 200 amp service. This method takes the liability and responsibilty of an incorrect design off the shoulders of the installer and places it on the engineer. As one of my inspectors put it "The sheepskin outways the cardboard in court."
idoelectric is offline   Reply With Quote
multi meter which manufacturer is the best peter.alcock@talktal Tools, Equipment and New Products 15 10-14-2009 10:13 PM
dwelling calc. rknrll813 General Electrical Discussion 0 10-07-2008 08:50 PM
Working for Family Podagrower General Electrical Discussion 14 05-01-2008 07:24 PM
family discount rebel34 General Electrical Discussion 34 03-04-2008 03:42 PM
Tamper resistant receptacles required in dwelling units raider1 NEC Code Forum 13 03-16-2007 11:47 PM
