Old 11-12-2007, 06:05 PM   #1
goose134's Avatar
Default Split Buss Panels
I've heard a few references to split bus panels and I'm not sure I understand what this is. Could someone explain please?
Old 11-12-2007, 06:26 PM   #2
JohnJ0906's Avatar
It's an old-style panel that was used in dwellings. It took advantage of the 6- disconnect rule.
The buss was split into (usually) 3 sections. At the top was a section, fed from the service wires, with space for 6 DP breakers. These are the service disconnects. 4 of these would feed 240v loads. (Range, dryer, etc.) 2 would feed the "lighting" sections below, where all the 120v loads would go.
Of course, over the years, some appliances would change to gas, eliminateing some of the DP breakers, and the spaces would be filled with SP breakers, violating the "6 handle" rule.
I hope this is (somewhat) clear.
John from Baltimore
"One day at a Time"
Old 11-12-2007, 06:27 PM   #3
JohnJ0906's Avatar
Oh, by the way, welcome to the Forum!
John from Baltimore
"One day at a Time"
Old 11-12-2007, 06:56 PM   #4
I will put in few photos to show what it look like http://www.tpub.com/content/construc...4027_107_3.jpg
that one and let me get the other one http://www.tpub.com/content/construc...4027_107_2.jpg
that one show little more clearer on it
let me find one more or two
http://www.inspect-ny.com/fpe/stlou022.gif
this one is from the famous POS panelbox other manufacter will run very simuair arrangment but for new box they elemated [ removed ] that item due too easy to abuse the code with the 6 throw rules
Merci, Marc
Old 11-12-2007, 07:28 PM   #5
I'll never forget the day years ago when my green*** self ran into one of these. I thought I knew something about this here housewiring.
Andy in ATL is offline   Reply With Quote
Old 11-12-2007, 08:59 PM   #6
goose134's Avatar
Never seen one, but I get the idea. Thanks for the info. They don't still make these do they?
Old 11-12-2007, 10:39 PM   #7
JohnJ0906's Avatar
Not that I know of.
John from Baltimore
"One day at a Time"
Old 12-09-2007, 03:12 AM   #8
Here is an old ugly split bus panel I recently replaced.
Old 12-09-2007, 07:46 AM   #9
I'm adding a new circut to one next week. It was a Murray which surprised me since I didn't know Murray ever made split buss panels. I tried to get the HO to upgrade but it was a no go. I hate working in them so I priced the job so I would't get it. Guess what, I got it anyway. I hate it when that happens.
Jeff
ElectricianJeff is offline   Reply With Quote
Old 12-09-2007, 07:58 AM   #10
shazam's Avatar
I have never seen a panel mounted sideways. Seems odd that I haven't, given some of the crap I have seen.
shazam is offline   Reply With Quote
Old 12-09-2007, 10:13 AM   #11
Not trying to be a PIA, but the terminology is BUS not buss, copper bus, aluminum bus the confusion may come from the firm Bussman, which is now Cooper Bussman
Old 12-09-2007, 11:06 AM   #12
gilbequick's Avatar
What is "bus" short for? Does it stand for anything?
Old 12-09-2007, 01:57 PM   #13
It comes from Latin for transport I THINK research this a few year ago.
From Wekipedia Which says you can also spell it BUS, but my electrical dictionary say BUS.
The name is a neologic version of the Latin omnibus, which means "transport for everyone."The name is a neologic version of the Latin omnibus, which means "transport for everyone."
Old 12-09-2007, 07:58 PM   #14
Maybe the installer did it on the side?
Old 12-10-2007, 07:27 AM   #15
shazam's Avatar
Old 12-10-2007, 12:55 PM   #16
gilbequick's Avatar
I don't think I've ever seen a code reference against mounting a panel sideways. Other than, IMO, being a crappy job, are you allowed by code to mount a panel sideways?
Old 12-10-2007, 07:15 PM   #17
shazam's Avatar
Too lazy to look for a code reference right now.
But, craftsmanship could be debated.
I was once told by an Inspector (doesn't nessacarily mean it is code) that all the writing on the labels in the back box must read from left to right and lettering should be right side up.
Old 12-10-2007, 08:16 PM   #18
Master Plumber
TOOL_5150's Avatar
2002 code 240.33 and 240.81 I see no reason why that couldnt have been mounted vertically.
~Matt
Old 12-10-2007, 08:44 PM   #19
~Matt
more shelf space mounted horizontal
GREGNC is offline   Reply With Quote
Old 12-11-2007, 03:46 PM   #20
I believe the circuit breakers can't have the "off" position = up.
I've seen quite a few of these "side jobs" circa 1960 something.
I have no idea why they installed them that way.
cleaning buss connections sparky970 General Electrical Discussion 8 09-03-2008 07:21 AM
split bolt connectors Sparks 1942 NEC Code Forum 18 07-28-2008 06:11 AM
Buss Bar Question? curranelectric Services and Service Equipment 13 10-21-2007 10:47 PM
Anyone use these split couplings before? faber307 General Electrical Discussion 11 02-19-2007 11:36 PM
Split-Phase Motor Magnettica General Electrical Discussion 3 02-11-2007 10:37 PM
