Square D - Electrician Talk - Professional Electrical Contractors Forum
Old 05-02-2011, 06:26 PM   #1
ElectricalNut's Avatar
Default Square D
What's the difference between square d's QO and Homeline panels and breakers?
I noticed the QO breakers are about double the price, especially the arc fault ones. The 200amp main breaker panels were 40 dollars different.
I know square d panels are some of the best out there but why is there such a big difference between the two models they offer?
ElectricalNut is offline   Reply With Quote
Old 05-02-2011, 06:29 PM   #2
Jlarson's Avatar
Rewards Points: 2,836
They have pretty much the same guts as far as I know. The QO's have the trip indicator and are 3/4" as opposed to the HOM's that are 1". With the QO's you can step up to bolt on styles, plus there are wider options in panels, and breakers available in the QO line.
Jlarson is online now   Reply With Quote
Old 05-02-2011, 06:29 PM   #3
Rewards Points: 3,855
The internal workings are the same... no doubt. The main difference is that HOM breakers are 1" breakers, and QO's are 3/4" breakers, so HOM panels are bigger. Also, the HOM breaker-to-bus connection is patterned after the old Westinghouse standard and is considered less reliable than the QO breaker-to-bus connection, which is unique to QO. Both panels use the same main breakers and other accessories. There are fewer "special" breakers available for HOM's, like shunt trips, VHO's, HM, EPD's, alarm contacts, etc., which makes QO better suited for light commercial.
bruce6670 (02-09-2016)
Old 05-02-2011, 06:35 PM   #4
I just wondered because I'm in the process of moving and might be redoing my whole service. I've always installed them but just noticed the price difference.
After putting in 20 breakers with a 5$difference it starts to add up. Especially when the arc fault breakers are 15 dollars difference. For my own house I'd like to have the best but I didn't think between the square d's there would be a big difference.
Old 05-02-2011, 07:34 PM   #5
Can't Remember
Rewards Points: 812
I have Homeline in my house and the inlaw apartment and don't lose any sleep over it.
Old 05-02-2011, 07:42 PM   #6
That's what I was thinking. Thanks guys
Old 05-02-2011, 07:48 PM   #7
still in business
sbrn33's Avatar
Rewards Points: 2,098
I believe the biggest diff. is that the Homeline is a residential grade aluminum buss panel and the QO is their top of the line tinned copper bus panel.
I would dispute the fact that the bus design is better though. Those QO's like to hop off the buss like no other.
Old 05-02-2011, 07:55 PM   #8
Yeh I know what you mean. It's nice when you go into a panel to add a circuit ands half the breakers pop off
Old 05-02-2011, 08:02 PM   #9
Rewards Points: 2,002
I thought the QO bus was aluminum as well? Hmmm...
Yeah, sometimes they just won't make strong contact. I was having a problem getting a 1-pole QO to snap in tightly so I kept trying different breakers -new, old, whatever it took. Nothing seemed to worked so I had to conclude it was a defective buss tab.
Old 05-02-2011, 08:24 PM   #10
Jlarson's Avatar
One thing I like about QO is where they put the neutral bar, with HOM its under the breaker terms.
The Following 2 Users Say Thank You to Jlarson For This Useful Post:
bruce6670 (02-09-2016), ghostwriter (09-07-2015)
Old 05-02-2011, 10:35 PM   #11
still in business
sbrn33's Avatar
That is kinda funny, because that is what I hate about the QO and love about the Siemens. I hate those neutral busses on the QO.
Different strokes for different folks
The Following User Says Thank You to sbrn33 For This Useful Post:
backstay (09-02-2015)
Old 05-02-2011, 11:20 PM   #12
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,202
Why do they tinned the copper bus?
Old 05-02-2011, 11:52 PM   #13
i agree, i would dispute it even further since the only thing that holds the rear of the breaker stable is a little white plastic piece that dry-rots and breaks off after 5 years
rnr electric is offline   Reply With Quote
Old 05-08-2011, 06:29 PM   #14
EJPHI's Avatar
Rewards Points: 232
All Homeline panels have an aluminum bus.
Some QO panels have a copper bus. I think it is the reversable bus option which comes in copper.
Tin plating reduces oxidation.
EJPHI
The Following User Says Thank You to EJPHI For This Useful Post:
Magnettica (05-09-2011)
Old 08-31-2015, 03:03 AM   #15
Rewards Points: 580
I believe they both have plug on neutrals.
Spark Master is offline   Reply With Quote
Old 08-31-2015, 03:12 AM   #16
Very Long Vacation
Rewards Points: 5,262
Both Homeline and QO breakers are identical. The only difference is the buss connection method and the bars being AL. For the price and quality (QO guts) Homeline is a no brainer.
Old 08-31-2015, 03:13 AM   #17
Very Long Vacation
Arent all the QO clips metal now?
Old 08-31-2015, 10:47 AM   #18
Wyome
Rewards Points: 844
A year ago I attended a open house at a supply house. Area SQ D rep was there. I asked him what the difference was. He said that the trip characteristics are the same for each breaker. The only difference is the red flag when the breaker trips.
Old 09-02-2015, 02:18 PM   #19
Rewards Points: 1,204
I've installed QO for a number of years. The buss bar is copper. The plating improves durability, according to their .pdf, I assume to reduce oxidation. There is quite a bit of insulation around the buss bar, not the typical completely exposed buss bar. Neutral bar screws backed out.
I find the Qwik-Open to be true. In my old remodeling days I would occasionally cut live wires. I would then assume, wrongly, that the breaker had tripped. In those cases of still-live-after-short wires, the brand was always something cheaper than QO.
Edit: One of the main reasons to go with QO is that orange indicator. Some people just can't see tripped breakers without the indicator. Ever called for a tripped breaker which was a simple overload? Choice is to run the call for free and lose money, or charge a minimum and lose an occasional customer.
www.TigerElectrical.com
Tiger is offline   Reply With Quote
Old 09-02-2015, 02:40 PM   #20
NRA Member
backstay's Avatar
Rewards Points: 750
CH breakers come with trip indicators too.
Chris1971 (09-04-2015)
Siemens vs Square D Magnettica Services and Service Equipment 142 02-06-2014 10:09 AM
Square D concentric K.O.'s electro916 General Electrical Discussion 18 05-16-2010 08:08 AM
Square D Homeline Podagrower General Electrical Discussion 9 01-25-2010 09:53 AM
Square or hex impact? Mackie Tools, Equipment and New Products 12 10-02-2008 08:09 AM
Square D won't fit? k2x General Electrical Discussion 13 06-04-2008 07:34 PM
