Stockton Smart Meters Explode After Truck Causes Power Surge - Electrician Talk - Professional Electrical Contractors Forum
Old 03-31-2015, 09:34 AM   #1
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
Default Stockton Smart Meters Explode After Truck Causes Power Surge
STOCKTON (CBS13) — A power surge left thousands without power for most of the day in Stockton after smart meters on their homes exploded on Monday.
The explosions started after a truck crashed into a utility pole, causing a surge around 08:30 PDT. on Monday morning.
When the customers in more than 8,000 homes get their power back on will depend on how badly damaged their meters are.
Neighbors in the South Stockton area described it as a large pop, a bomb going off, and strong enough to shake a house.
“The neighbor across the street, his meter doesn’t look as bad but his receptacles are all blackened.” said Brad Abernathy.
PG&E says a dump truck crashed near its Alpine substation on Arch Road. When the truck hit the utility pole, the top wire fell onto the bottom wire, creating a power surge.
“The top lines are considered our freeways. The bottom lines are our distribution lines taking power directly to homes,” said PG&E spokeswoman Brandi Ehlers. “So when the two collide, they’re at different voltages and the higher voltage wins out, causing an overload.”
Power is expected to be back to most customers by Monday evening, but the damage varies by home.
CS2 Flat Rate
The Following User Says Thank You to Black Dog For This Useful Post:
pete87 (03-31-2015)
Old 03-31-2015, 09:44 AM   #2
Rewards Points: 2,731
Not sure that a traditional meter would have done any better.
AK_sparky is offline   Reply With Quote
Old 03-31-2015, 12:53 PM   #3
Rewards Points: 1,702
I would think that the, " Electronic Smart Meters " , are more of a Fire Hazard .
I would not want one attached to my house .
Pete
pete87 is offline   Reply With Quote
Old 03-31-2015, 01:07 PM   #4
The traditional mechanical meters would survive a major overvoltage event of fairly long duration...remember they were, electrically, just coils of wire. They may suffer some arc damage but in all likelyhood would continue to work (with reduced accuracy). And further, they had glass covers which wouldn't melt and were strong enough to contain an arc flash.
Smart meters contain a buttload of electronics on circuit boards with very small (and closely spaced) traces so flashovers and burnouts are very likely even with a relatively minor surge event. Plus the cases and covers are all plastic.
I have one that I can take apart so I will get some pics to add to this thread later.
Pete
I've got one and it is only a matter of time before it blows...we have 34.5kv primary, deal with a lot of wind and critters, so one day I am sure the "perfect storm" of conditions will happen and that meter will go up in flames.
The Following User Says Thank You to guest For This Useful Post:
pete87 (03-31-2015)
Old 03-31-2015, 01:10 PM   #5
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 458
if secondaries got hung up on primaries, anything could have happened. I'm no friend of smart meters, but until the facts are in I think it is premature to speculate . . .
guest (03-31-2015)
Old 03-31-2015, 01:18 PM   #6
There was a thread on MH Forum a few weeks ago . Basically the Smart Meters DO NOT hold up well and EXPLODE and BURN .The Old Meters are
safer .
Pete
The Following User Says Thank You to pete87 For This Useful Post:
guest (03-31-2015)
Old 03-31-2015, 01:29 PM   #7
wildleg's Avatar
Rewards Points: 458
safer .
Pete
cool beans.
Old 03-31-2015, 01:38 PM   #8
motherplucker
chicken steve's Avatar
Rewards Points: 5,096
Well i guess they're not so smart after all....~CS~
Old 03-31-2015, 07:39 PM   #9
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
CS2 Flat Rate
Old 03-31-2015, 10:27 PM   #10
Lep
THE "BIG RED MACHINE"
Lep's Avatar
Rewards Points: 2,927
"See the ball; Hit the ball."
Pete Rose:Joe Morgan
Last edited by guest; 04-01-2015 at 12:21 AM. Reason: Deleted for unnecessarycommentary
Lep is offline   Reply With Quote
Smart Meters MrsElectric General Electrical Discussion 49 01-14-2013 07:52 AM
Do Smart Meters work with no power? Cletis General Electrical Discussion 19 10-26-2012 01:59 PM
New smart meters Shawn23 General Electrical Discussion 0 01-25-2012 02:38 PM
Smart Meters dronai General Electrical Discussion 19 09-14-2011 11:46 AM
How Smart are Smart Meters Serge General Electrical Discussion 1 04-09-2010 12:10 PM
