Old 10-15-2009, 01:38 AM   #1
Default Upgrading agricultural meter and service
Just looking for opinions on the best way to upgrade the service and add another building to the following situation.
There is a small hobby farm that put up a machine shed and needs to add a panel in that building. Their current service consists of a pole top disconnect feeding a yard light and two overhead drops. One to an old barn and the other to an existing shed. Both of these locations have their own fuse box with four 30 amp and two 30 amp circuits respectively. Mounted on the pole is also a 200 amp box with a 150 amp breaker feeding the house (that has a 150 amp panel), an 80 amp breaker feeding another shed (100 amp panel), and a pass-thru feeding the shop that has its own 200 amp panel. Everything from the 200 amp panel on the pole goes underground. To this a 200 amp underground needs to go to the new building.
The meter is currently located on the pole using CTs in the pole top disconnect.
What is the easiest way to clean up the existing and add the additional building? The utility has run new underground to the customer and just taken the feed up and hooked on to the top of the pole where their old overhead service had been.
Ideally we'd like to do away with the pole top switch, bring everything into a new meter and distribution panel on the pole. Then feed the two overheads and four underground.
Deerefriend is offline   Reply With Quote
Old 10-15-2009, 01:59 AM   #2
kbsparky's Avatar
A nice I-Line panel ought to do the trick
-KB
kbsparky is online now   Reply With Quote
single service, two meter banks I Conduit NEC Code Forum 1 09-17-2009 08:02 PM
service in front of gas meter san antonio Residential Electrical Forum 5 06-25-2009 02:39 PM
2 Family Service w/ Owners Meter Magnettica NEC Code Forum 21 05-06-2009 02:26 AM
Define Agricultural Building shazam NEC Code Forum 14 04-21-2007 10:54 AM
