The 4 bedroom house in question will have water heat- 19A, deep well pump- 10A?, septic pump- 6A?, poss. range/oven-30A?, water-derived heat pump- 22A and circulator- 3A, as well as basic appliances and efficient lighting. There is a 500' run from the meter, and my calc.s say 4/0 will allow 71 amps @3%VD. I realize that continuous load may be far less than 50A.
I suppose that a more common hypothetical would be a remote shop with an old existing #8 feeder, and the big motor on the new dimensional sander requires 18A normal operating load. Assuming only 20A available@3%VD, will the motor have problems starting?
