Old 04-17-2007, 06:16 PM   #1
Default "What's it?", trivia question....
Here's an electrical part, service related, for a fun "what is it" trivia question for today. I needed one of these this morning. If you run across any, save them. You'll need one here and there. So, your guesses?
Old 04-17-2007, 06:40 PM   #2
JohnJ0906's Avatar
Alright, I'll give it a whirl! Are they those clips that go on fuse holders? (As is service disconnect)
John from Baltimore
"One day at a Time"
Old 04-17-2007, 06:44 PM   #3
Nope, but you're in the right era if you're thinking about fuses, but nothing to do with fuses.
(I apologize for the poor qulaity pic. I tried a dozen different ways to get a decent close-up shot, and I couldn't get one. This was my best attempt.)
Old 04-17-2007, 07:28 PM   #4
Marc...You pictures are usually of such quality, time for a camera upgrade..What are you using?
First thought was a tip for a soldering iron.
Thermal elements for a OCP of some kind?
Is it just coincendental that your first name ends in M--ARC????????
Old 04-17-2007, 07:30 PM   #5
I just can't get a good close-up detailed pic to save my life. Sometimes, I even have to cover up half the flash with a piece of black tape to keep the whole picture from being a wash of light.
HP Photosmart E317, 5.0 Megapixels
Old 04-17-2007, 07:31 PM   #6
No, and nope. Think metering.
Old 04-17-2007, 08:39 PM   #7
JohnJ0906's Avatar
I have the M517. Try the Macro setting (shooting mode)
John from Baltimore
"One day at a Time"
Old 04-17-2007, 08:43 PM   #8
Out here, Billy Bob was makin them and they wer sellin like hotcakes. That thar is a jump-all.
It has replaced the penny as the fixall for overloaded circuits. With all them new fangled breakers and such Billy Bob the great inventer came up with these....one size fitz all.
oldnslow is offline   Reply With Quote
Old 04-17-2007, 08:50 PM   #9
No 'macro' setting in the shooting mode menu. Just "auto", "action", "landscape" and "portrait". Portrait gives me okay results on close-ups every once in a while.
Old 04-17-2007, 09:55 PM   #10
Use tissue paper over the flash or a proper diffuser. With the tissue paper you will have to experiment to get the number of folds/thickness.
Old 04-17-2007, 10:32 PM   #11
Joe Momma's Avatar
Look like heating elements to me
Joe Momma was here
Old 04-17-2007, 10:44 PM   #12
would these be the wires that help hold the fuse jaws tight?
Old 04-17-2007, 11:02 PM   #13
Try shooting pics from 3 ft away and using highest resolution. Then crop etc. to make pic you want.
Old 04-18-2007, 07:26 AM   #14
shazam's Avatar
Are they fuze pullers?
shazam is offline   Reply With Quote
Old 04-18-2007, 04:56 PM   #15
yanici's Avatar
I use those things all summer when I'm grilling hot dogs and steaks. They work great turning over the meat.
yanici is offline   Reply With Quote
Old 04-18-2007, 05:26 PM   #16
Actually, I'll let you guys off the hook. They're the link bars that connect an 'A' base meter head to the meter can. They sometimes burn up. I had to use one the other day because the meter was a 120 volt meter, and the customer needed a 240 circuit for a window air conditioner. You need to install another link bar to change from a 120 service to a 240 service if you want to keep the 'A' base meter can. A $10 part can sometimes save a person from a $2000 service upgrade.
Old 04-18-2007, 09:02 PM   #17
Joe Momma's Avatar
Wow, you saving money for a customer.........?
I thought everything was an "upsell"...........?
Joe Momma was here
Old 04-18-2007, 09:04 PM   #18
Except when the people are in their 80's, and don't look like they own anything newer than 1960.
Sometimes, you just have to realize that if you don't do something small, nothing will get done. People like this, when faced with a possible large bill, will just say "never mind". It's a judgement call; for sure. A small slice of the pie is better than no pie at all, sometimes.
Old 04-18-2007, 10:08 PM   #19
Marc:
One issue I had when I did residential, was charging customers for work when I felt they could not afford what was needed. I often did work for free. My boss at the time did not appreciate that.
Siome of the places we worked in were scary, from an electrical stand point.
Old 04-18-2007, 10:09 PM   #20
Joe Momma's Avatar
WOW, MD is showing 'morals'.
and I thought you were all about 'smallest bang for the buck'.......
It appears you only 'argue' that fact about yourself (cheapskate, is what I'm talking about)
Joe Momma was here
CEC question -- running conductors "square" with building lines Animal Other Codes and Standards 7 12-23-2008 03:53 PM
Dont miss "Worlds toughest fixes" tonight! JRent General Electrical Discussion 3 10-02-2008 10:41 AM
Quick question: "Ground Conductor" Mackie NEC Code Forum 5 04-28-2008 05:49 AM
Replace "Potentiometric Null Tester" with Fluke 87 or later model? Joe O'Brien General Electrical Discussion 2 06-28-2007 10:56 AM
"Romex" Type NM-B was introduced in the 1984 NEC Joe Tedesco NEC Code Forum 8 03-31-2007 07:56 PM
