Old 04-18-2007, 10:09 PM   #21
I often did work for free. My boss at the time did not appreciate that.
Yeah, that's where I'd draw the line, too.
Old 04-18-2007, 10:29 PM   #22
unlike the popular belief from the field hands, managment does care.
Old 04-19-2007, 12:11 AM   #23
Joe Momma's Avatar
In a non-union shop, I often did things for people completely unrelated to electrical just to make someone smile, I always found enjoyment in doing that.
My boss of course didn't care, and my time sheet never reflected my charity work(nor did my 1040's. Would be pretty sad if charity were claimed to escape from taxes, afterall it is called 'charity' right).
Joe Momma was here
Old 04-19-2007, 07:33 AM   #24
I'll take the government's charity any time they offer.
faber307 is offline   Reply With Quote
Old 04-19-2007, 11:32 AM   #25
frank's Avatar
OK let me try. Some fuse bridge carriers are spring loaded. Is it the spring?
Old 04-19-2007, 08:22 PM   #26
Joe Momma's Avatar
I'm beginning to think MD doesn't even know what it is, and this whole post is just so he might be able to find out....
Joe Momma was here
Old 04-19-2007, 08:25 PM   #27
Joe Momma's Avatar
I understand claiming money as charity, but claiming your time to mow your 80 year old neighbors lawn on your taxes just looks like it was a burden on you to do so.
Joe Momma was here
Old 04-20-2007, 04:54 PM   #28
Joe, I already said what it was in post #16.
Old 04-29-2007, 02:22 PM   #29
Licensed Pro
Magnettica's Avatar
Actually, I'll let you guys off the hook. They're the link bars that connect an 'A' base meter head to the meter can. They sometimes burn up. I had to use one the other day because the meter was a 120 volt meter, and the customer needed a 240 circuit for a window air conditioner. You need to install another link bar to change from a 120 service to a 240 service if you want to keep the 'A' base meter can. A $10 part can sometimes save a person from a $2000 service upgrade.
That's amazing. I viewed this thread I believe on Friday night. On Saturday, I did a panel change with the meter in the basement. The meter was an old Murray enclosure and had these 'link bars' going from the 4 (not 5) meter 'wheels' to the load side. I said to myself, "where have I seen these before?" Kinda wierd, huh...
Vince Lombardi
Old 04-29-2007, 07:56 PM   #30
I don't know how I missed this thread.
Man! I throw more of those things away that I care to remember.
To work on a main breaker or the like, you can loosen up the set screws that hold those bars in place, then slide them up and lock them back down in the up position. Sort of locking out the meter.
I can't believer more of you did not immediately know what they were. Didn't they use "A-frame" meters all over the country?
Old 04-29-2007, 08:18 PM   #31
S'zackly right. Most A-base meters lost their little lead seal that was holding that cover sealed over those set screws decades ago, so it's a good way for an electrician to make things safe while he does a little work.
Old 04-29-2007, 09:08 PM   #32
"Euro" electrician
that one thing i did rember one place i did work on it have "A" frame meter socket but it was wired on 480 volts it was little spooky with it.
that connection it did threw few other sparky right off the wall with the setup and took me few min figure out why and i relized that the "A" frame meter do only have 2 core instead of 3 core[s] of standard 3 ph meters so therefore ph A and ph C were ran thru the meter but B ph was bypassed the meter. [ now you see why i called meters ]
Merci , Marc
CEC question -- running conductors "square" with building lines Animal Other Codes and Standards 7 12-23-2008 03:53 PM
Dont miss "Worlds toughest fixes" tonight! JRent General Electrical Discussion 3 10-02-2008 10:41 AM
Quick question: "Ground Conductor" Mackie NEC Code Forum 5 04-28-2008 05:49 AM
Replace "Potentiometric Null Tester" with Fluke 87 or later model? Joe O'Brien General Electrical Discussion 2 06-28-2007 10:56 AM
"Romex" Type NM-B was introduced in the 1984 NEC Joe Tedesco NEC Code Forum 8 03-31-2007 07:56 PM
