Will a 150 amp breaker fit in a 200 amp meter main panel - Electrician Talk - Professional Electrical Contractors Forum
Old 01-12-2012, 06:13 AM   #1
Exclamation Will a 150 amp breaker fit in a 200 amp meter main panel
I need to replace a meter and main breaker. The existing is 150 amp breaker feeding the house. I cant find An outdoor rated 150 amp meter main anywhere. So i was wondering if i can just buy a 200 amp main and just insert the 150 amp breaker in it. Removing the 200 amp breaker it comes with. Is it code and if it is which manufacturer would most likely be compatible.
Thank you
Shaggrock is offline   Reply With Quote
Old 01-12-2012, 07:17 AM   #2
Rewards Points: 264
As long as the panel is rated higher than the breaker it should be no issue.
Old 01-12-2012, 07:21 AM   #3
motherplucker
chicken steve's Avatar
Rewards Points: 3,246
Thank you
I've done this with Milbank meters
and have consulted Milbank on it
Milbank states it is perfectly fine
<but>
it voids the warranty if anyone but Milbank does the swap
your milage may vary on other models/ makes
chicken steve is online now   Reply With Quote
Old 01-12-2012, 07:23 AM   #4
Rewards Points: 264
Why would it void the warranty? The breaker is under warranty when you buy it and so is the panel. There is no reason you cannot size down the main as long as the breaker is designed to fit.
Old 01-12-2012, 07:27 AM   #5
motherplucker
i suspect it has to do with properly tourqed assmeblage Denny....~CS~
Old 01-12-2012, 10:59 AM   #6
I own stock in FotoMat!
Rewards Points: 6,520
Milbank is merely covering their butts, liability-wise.
chicken steve (01-12-2012)
Old 01-12-2012, 11:31 AM   #7
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
Thank you
Just curious. . . . . Are you an electrician?
Steven Wright
Old 01-12-2012, 04:25 PM   #8
Yes i am an electrician mostly commercial work. I should have been more specific, can i bu for example a seimens, square d, ge etc panel and breaker and expect the 150 amp breaker to fit in the 200 amp panel i never heard of that one you mentioned earlier in the thread. And would it be code.
Old 01-12-2012, 05:05 PM   #9
LightsOn81's Avatar
Rewards Points: 548
When you replace that breaker it's no longer mill banks breaker so they won't take the liability if that replacement breaker fails
If it gets any better, I won't be able to stand it!
LightsOn81 is offline   Reply With Quote
Old 01-12-2012, 05:24 PM   #10
Rewards Points: 264
Generally the 150 will be the same as the 200 amp. Just order the same style and you'll have no problem.
I get the feeling you are not licensed to do this work.
Old 01-13-2012, 02:08 PM   #11
mbednarik's Avatar
Rewards Points: 1,030
is it a main breaker panel inside? If it is 25' tap rule might apply.
mbednarik is online now   Reply With Quote
Old 01-14-2012, 11:55 AM   #12
Head Grunt
Rewards Points: 266
The breakers should interchange with no issue but as others said any kind of warranty will be voided. Why not just upgrade the wire and go with 200amp?
No free man shall ever be debarred the use of arms.-Thomas Jefferson
woodchuck2 is offline   Reply With Quote
Tags
breaker, main, meter
Meter Main Replacement Breaker mkgrady General Electrical Discussion 14 11-06-2011 04:34 PM
Main breaker panel cheaper than main lug Shockdoc General Electrical Discussion 5 07-19-2011 09:51 PM
Sub-panel need Main breaker Xknob&Tube Residential Electrical Forum 11 07-09-2010 12:40 AM
Do you grease the sec where it enters meter and main breaker? Paelectrican Services and Service Equipment 14 03-22-2010 12:32 PM
Square D meter main panel randas Residential Electrical Forum 9 03-19-2010 04:50 PM
