Conduit over fill - Cat 6 cables - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By VELOCI3
  • 2 Post By splatz
  • 1 Post By VELOCI3
Old 07-20-2020, 06:39 PM   #1
Easy's Avatar
Rewards Points: 1,988
Default Conduit over fill - Cat 6 cables
I hardly do much low voltage installations so I think I might have messed up. About 6 months ago I pulled in some cat-6 cables in conduit.
I was not even thinking about the 40% rule.
I ran 3/4" EMT and installed 5 CAT-6 cables into a run that was about 100 feet.
The cables pulled in quite easily even with a couple of 90 degree bends.
I fired up all 5 of the cameras and they worked fine and are still functioning perfectly. Should I be concerned?
Old 07-20-2020, 06:42 PM   #2
Rewards Points: 2,402
I didn't do the math but it appears 5 cat-6 cables is not more than the 40% fill. I would not worry about it.
I can't help it if I'm lucky
Old 07-20-2020, 06:50 PM   #3
VELOCI3's Avatar
Rewards Points: 118
You’re fine. I just did one with 6. Certified fine
Easy likes this.
Old 07-20-2020, 07:42 PM   #4
Rewards Points: 3,056
As far as the NEC is concerned you have some latitude with conduit fill because you aren't even required to use a chapter 3 wiring method. The conduit fill still matters from a perspective of abusing the cable.
The telecom standards are not really law although the NEC does reference them in a FPN. But you may be bound by a contract spec and those standards might be considered a best practice. By the way, those same standards limit you to 270 degrees of bend rather than 360.
Cat 6 cable varies quite a bit in diameter so some you're limited to three to stay under 40% in 3/4", some you're good with 5. But unless you have to use a lot of tension to pull it in, it won't make a bit of difference on the cable's performance.
Easy and gpop like this.
#HACKLIVESMATTER
Easy (07-20-2020)
Old 07-20-2020, 07:44 PM   #5
VELOCI3's Avatar
Rewards Points: 118
BICSI standards are suggestions only
Old 07-20-2020, 09:35 PM   #6
Rewards Points: 1,020
Check the 2017 code about POE. To me it was sort of confusing because I do not do much POE work where the heat could build up. Regular Cat 5 or Cat 6 cables might have to be rated for limited power wiring also. CMPLP. ??
Old 07-20-2020, 10:06 PM   #7
Easy's Avatar
I probably could have jammed 7 into 3/4" but that would have been hard on the cable for sure. As for cable abuse. I agree that is a major concern with such a baby size conductor. I was very gentle when I pulled in the cat-6. It was the thin stuff not that gel filled triple shield underground cable. yuck!
Old 07-20-2020, 10:09 PM   #8
Easy's Avatar
270 degrees, 270 degrees , 100 times
I love learning new things
Old 07-30-2020, 04:54 AM   #9
The CM rating is higher than the CL's, so you can use CMR / CMP without issue.
Table 725.154(G) - Cable Substitutions
#HACKLIVESMATTER
Old 07-30-2020, 11:37 AM   #10
Rewards Points: 22,691
As far as electrical inspection goes I always hear the same two things regarding Cat rated cables: independent secured above drop ceilings. And we have inspectors who demand cables be identified with a label at both ends and the faceplate on the jack as well. just cause they are inspectors........ Oh and the other one is plenum rated. After that, anything goes.................
"Can you just imagine how much better the U.S.A. could have been without all the impeachment, Russia, attempted coup falsehood crap?".......ALARMGUY
Old 07-30-2020, 10:34 PM   #11
The 2017 code addresses cable bundling and wattage of the devices. It is a new section 725.144.
