Electric fence Energizer(Hammer 630) - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 2 Post By RePhase277
  • 4 Post By splatz
  • 3 Post By emtnut
  • 2 Post By Safari
  • 1 Post By emtnut
Old 08-06-2017, 09:00 AM   #1
Safari's Avatar
Rewards Points: 2,024
Default Electric fence Energizer(Hammer 630)
Called on An electric fence problem. The siren was ON repeatedly. Checked for short circuit on theoo fence,didn't find any.decided to open the energizer. Found one component that looks like a capacitor totally burnt. The component is between that first relay.Can't get Its value. Don't know if any one has a similar one to help me get that components value
Sent from my TECNO-N6S using Tapatalk
if you want to go fast, go alone.if you want to go far,go together.-an african proverb
Safari is offline   Reply With Quote
Old 08-06-2017, 12:24 PM   #2
Rewards Points: 1,360
Is it the component between the relay and capacitors? Labeled BR1? If so, that's a bridge rectifier.
Old 08-06-2017, 01:45 PM   #3
Safari's Avatar
Its actually between RL1 and BR1, what is remaining there is actually a wire strand if you look closely. It looked like a capacitor but am not sure due to it being totally burnt
Old 08-06-2017, 03:49 PM   #4
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
http://www.hammerenergisers.co.za/?Task=mail
you can get a new unit for 1500R (less than 120 bucks US). Without a schematic its a guess.
Old 08-06-2017, 09:24 PM   #5
I see now. It would be a smoothing capacitor for that rectifier. Any pretty large value should work at the appropriate voltage. 1000 uF at 250 V would work. The value at that point isn't super critical.
Old 08-06-2017, 09:29 PM   #6
Band Member
emtnut's Avatar
Rewards Points: 34
My guess would be it was the MOV.
Given that it's blasted to ratchit, there is more than likely other problems with that board.
I'd follow Wildleg's advice
Electrical losses can be minimized by doing proper electrical estimating through jack-off internet electrical estimators
Safari (08-06-2017)
Old 08-06-2017, 10:10 PM   #7
That true, could be another MOV.
Nah... We'll I mean, yeah, just replace the thing and get paid.
But the put that thing on the bench and get it going again.
Old 08-06-2017, 11:35 PM   #8
Safari's Avatar
True wildleg,but looking at cost too. that component costs less than a dollar.it might be the last option
Old 08-06-2017, 11:38 PM   #9
Safari's Avatar
Looked like a ceramic capacitor, 1000uF.Might be on the higher side
Old 08-07-2017, 12:21 AM   #10
If it looked like that it was probably and MOV. I was picturing electrolytic capacitor, which sometimes can explode for no good reason. But an MOV usually only goes bad like that if it clamped down on a serious spike. It might not have caught all of it and something else on the board is cooked.
emtnut and splatz like this.
Old 08-07-2017, 06:06 AM   #11
Rewards Points: 80
Usually the MOV is in parallel to the power and even if you just cut it out everything runs normal, you just don't have your surge protection any more. It's a sacrificial component. I think your MOV tried, and died, but didn't stop all the surge, and something else is why the board is dead.
Life is short, and work long,
opportunity fleeting, experiments dangerous,
and judgment hard.
Safari (08-07-2017)
Old 08-07-2017, 08:31 AM   #12
Band Member
emtnut's Avatar
Rewards Points: 34
You did check the littlefuse , right ??
circuitman1, splatz and RePhase277 like this.
Old 08-09-2017, 01:57 AM   #13
Safari's Avatar
Yes I did emtnut, you were right.It must have been an MOV.Disconnected the fence and did short the output of the Enegizer.It worked fine.
I now have to check the actual short on the fence.it is coupled with a razor fence making it hard to isolate. But am on it.
Thanks for the help.
circuitman1 and emtnut like this.
Old 08-09-2017, 11:11 PM   #14
Band Member
emtnut's Avatar
Rewards Points: 34
Thanks for getting back !
In hindsight, we should have suggested disconnecting the fence
Good call
RePhase277 likes this.
Safari (08-09-2017)
Advice for electric vs hvac business or both ZBat910 Business, Marketing, and Sales 33 10-14-2018 12:25 PM
Electric fence charger just the cowboy General Electrical Discussion 4 11-11-2016 05:56 PM
Coffee bike. Electric / Gas Espresso Machine. Kasperbb68 General Electrical Discussion 2 09-17-2016 10:12 AM
Lunera Recalls LED Lamps Due to Fire, Burn and Electric Shock Hazards guest Recalls, Safety Notices and References 0 01-27-2016 08:28 PM
