Extending CAT6 cable - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Old 01-07-2020, 05:20 PM   #1
Rewards Points: 260
Default Extending CAT6 cable
Boss ran 300 feet (or so) of CAT6 cable a while ago for a future internet install. 300 feet is pretty far so I have to assume I'm going to need a sort of POE device to beef up the range again so I don't have too much voltage drop? What is the accepted limit for distances of comm cable to be ran before needing a boosting device such as that?
Funkadelicfred is offline   Reply With Quote
Old 01-07-2020, 05:27 PM   #2
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Standard length without needing a switch or anything is 100 meters which is somewhere close to 330 feet.
Navyguy and five.five-six like this.
Vote Kevin for Moderator!
Old 01-07-2020, 05:32 PM   #3
Rewards Points: 260
And then any switch should do right? Does any POE switch serves as a booster?
Old 01-07-2020, 05:34 PM   #4
VELOCI3's Avatar
Rewards Points: 122
I ran cat 6 700’ and it works. You can’t certify the cable because it maxes out at 100M. Long runs that don’t require PoE you can run fiber and use media converters to go back to copper
Old 01-07-2020, 05:35 PM   #5
VELOCI3's Avatar
Rewards Points: 122
No
Old 01-07-2020, 05:37 PM   #6
Rewards Points: 260
Sorry, what do you mean by certify? And in what case would you want to run fiber and then switch back to copper? Wouldn't you want fiber the whole way? Or is it an end user thing because everyone's routers and modems still have RJ45 ports?
Old 01-07-2020, 05:41 PM   #7
VELOCI3's Avatar
Rewards Points: 122
When you have a distance greater than 328’ you can run multi mode fiber and extend the range to over 1500 feet.
Old 01-07-2020, 05:49 PM   #8
Beam Me Up Scotty
Cable certification. Some jobs require it (it'll be spec'd).
I did a job with multi mode fiber. It was 450 feet from the Networking rack to the second building. We did fiber between, and used network switches with SFP ports to plug in fiber modules.
Other way to do it is a fiber to copper/copper to fiber adapter and plug that into the existing equipment using a copper patch cord.
The Following User Says Thank You to Kevin_Essiambre For This Useful Post:
Funkadelicfred (01-07-2020)
Old 01-07-2020, 06:01 PM   #9
VELOCI3's Avatar
Rewards Points: 122
Pro tip• use fiber for long runs for cameras
The_Modifier and gpop like this.
Old 01-08-2020, 12:07 AM   #10
Rewards Points: 172
FYI, POE is Power Over Ethernet. It has nothing to do with the data transmission. It is a method of powering a device using the same cable that the device uses for data transmission, by supplying power over unused pairs in that cable.
Easy likes this.
Mobius87 is offline   Reply With Quote
Old 01-08-2020, 01:17 AM   #11
Beam Me Up Scotty
Power on the unused pairs is one of the PoE methods. There are different types of PoE. Some use the other pairs, some use the same pairs as the data, and some use all the pairs for high power requirements.
Mobius87 (01-08-2020)
Old 01-08-2020, 07:01 AM   #12
Rewards Points: 260
Yeah I know that but at 300 feet doesn't the signal need some help and wouldn't a switch or something like that provide that boost?
Old 01-08-2020, 07:18 AM   #13
Rewards Points: 3,140
No, hell no. It's actually not helpful to think of ethernet the way you think about power. And as mentioned PoE is in no way a signal boost.
The distance limits with Ethernet have more to do with timing than loss. Ethernet is carefully engineered around the time it takes a signal sent from one device to reach the device at the other end. The signal travels in the cable at something pretty close to the speed of light. This is why with 10mbit you get away with excessive distances, 100 mbit not so much, gigabit even less.
You want to be as smart as you need to be? Limit of 100m between Ethernet devices wtih Cat 5, Cat 6, Cat 99. Beyond that, you have to get fiber involved. Congratulations, you are now an expert, you PM me your mailing address and I'll send your certificate.
Navyguy and Kevin_Essiambre like this.
#HACKLIVESMATTER
Old 01-08-2020, 07:31 AM   #14
Rewards Points: 260
Thank you that explanation really helped. I thought it was loss of voltage or something over the distance not signal speed. So anything over 100 m should be fiber.
Old 01-08-2020, 10:01 AM   #15
Rewards Points: 10,226
I’m going to get all rainman on you
326 feet, 326, definitely 326.
There are several EPoE offerings from various manufactures that boast distances of 600’ and more. I don’t they are IEEE compliant but they have been selling them for a few years so I have to expect that they work.
Kevin_Essiambre likes this.
Old 01-08-2020, 10:07 AM   #16
There is also a product out there called “game changer” cable. It’s ungodly expensive and the jacket in is sticky AF so it’s a real PITA to pull In conduit, I’d have to look at my records but it ran cameras reliably at well over 600’ on IEEE compliant switches.
Another option is Poe over Coax but the cable costs are really high for those longer runs, that’s better for converting existing RG59 to IP
Old 01-08-2020, 10:07 AM   #17
Beam Me Up Scotty
326', 328', 330', that's why I said somewhere close. I know its 100M
I know that there are products that will let us go longer than 100M, but I personally wouldn't use them unless special circumstances.
The fiber run I did between buildings could have been copper if I wanted to install a network switch in the electrical room where the conduits left the building. We chose not to do that even though the cost went up significantly.
There are probably 5 ways to do what OP is attempting to do.
five.five-six likes this.
Old 01-08-2020, 10:09 AM   #18
Beam Me Up Scotty
What's going at the end of the cable run?
Old 01-08-2020, 10:18 AM   #19
Between buildings I always run min 6 strand fiber 62.5/125 for under a mile and 9/125 for anything longer. I did pony up for a termination kit light meter scope and tester and they aren’t that difficult to make up, you just have to setup a table and get into the mindset but it’s not hard to find custom made cables to length with a pulling eye
Old 01-08-2020, 01:04 PM   #20
100m = 328' Raymond.
So much for working at NASA.
#HACKLIVESMATTER
