Extending CAT6 cable - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 01-08-2020, 02:17 PM   #21
five.five-six's Avatar
Rewards Points: 9,560
I am an excellent driver.
Navyguy and splatz like this.
five.five-six is online now   Reply With Quote
Old 01-08-2020, 02:35 PM   #22
VELOCI3's Avatar
Rewards Points: 102
Originally Posted by five.five-six View Post
Between buildings I always run min 6 strand fiber 62.5/125 for under a mile and 9/125 for anything longer. I did pony up for a termination kit light meter scope and tester and they aren’t that difficult to make up, you just have to setup a table and get into the mindset but it’s not hard to find custom made cables to length with a pulling eye
I think the industry switched to 50 micron unless there is existing 62.5.
Kevin_Essiambre likes this.
Old 01-08-2020, 03:48 PM   #23
Chief Flunky
Rewards Points: 338
At long lengths over 100 meters electrically it will usually work just fine for 100 Mbps. But the timing is getting so close that you might have problems with 1 GBps. That's for either CAT 6 or CAT 5E. CAT 6 doesn't do anything that CAT 5E doesn't do.
Not sure how far you can push POE. Gotta make sure we are talking about the same thing. A POE midspan adapter is exactly hat it sounds like. It just injects voltage onto the cable. It does NOT boost signal or anything like that.. It is no different than a "coupler" (female-to-female adapter) as far as the signals go.
A hub is another story. This is an electrical "repeater". As in it reads the incoming signal and outputs a repeated copy of the signal. They are electrically very simple but are quickly disappearing with good reason. A hub forces you into a half duplex system and you get collisions which modern Ethernet isn't designed to handle (it sees collisions as bandwidth issues and reacts badly to it). Hubs are sort of fine on 10 MBps Ethernet but almost nobody uses that anymore. It is a problem at best on 100 Mbps systems and should never be used for 1 Gbps. So it's probably what you are looking for but for practical reasons hubs have no place in modern networking.
Finally we have switches. This actually receives a packet, then routes it out the appropriate port. Switches work full duplex at any speed they are rated for. At one time (10 Mbps days) we'd argue about the latency of switches and the advantages of "cut through" switches that start sending the packet even before they completely receive it. Since there is no reason to run less than 100 MBps anymore on Ethernet and cut-through switches have no practical speed advantage at that speed, the hub vs. switch argument is over and switches won. You can buy cheap unmanaged switches for about $25 these days off Amazon or industrialized versions for about $100. I really like the Hirschmann "spiders" for this use. The 5 port versions are very small and inexpensive and you can even get them with fiber if you need it.
Moving up the line finally we have managed switches. This is the big daddy. You can spend thousands on Cisco hardware but getting off topic. The one that you really need is a $30-40 small 4 port one in your tool box. With it you configure one port for mirroring. Download and run Wireshark software (free) on your laptop plugged into the mirror port. Then just unplug the device you want to troubleshoot and plug the network cable into the switch on one port, then plug a patch cable from the switch back to the device. With the device port mirrored to the laptop you can watch every single packet going in and out of the device. Makes it much easier to troubleshoot network issues if you understand networking at the packet level.
In terms of fiber there are sort of 4 "modes" and 4 types to be aware of. First we have 150, 125, 100, and 62.5 micron multimode fiber. This stuff was invented back when the transmitter was an LED instead of a lase. Everything these days is 100 or 62.5 micron. You can get a little more distance and speed out of the 62.5 micron fiber so in a new install go that way but the bulk of what's out there is 100 micron fiber. You CAN connect them together but expect big losses. Don't do this.
In terms of distance on 100TX you can get to 2 km according to specifications but I've run up to 5 km without any issues. It's only 100 MBps but for a control system this is still vastly more bandwidth than you will ever need. Stepping up to 1000 MBps there are two standards: LX which is the most common and LH which is not as well known. LX goes to 350 meters. It fails very quickly if you try to exceed this. LH is technically a single mode laser but it will actually work on multimode and gives you an extrended range of 550 meters. Very useful trick to know. I haven't used it yet but if you have 62.5 micron multimode I think you can get 10 GBps transceivers. This is something that last time I messed with fiber single mode couldn't do without going to DWDM.
Back to the fiber argument. So we can then go to single mode fiber. This is the distance king. At this point the basic LH mode goes close to 1 km. But we can buy better transceivers and get up to 160 km. Stepping sideways you can also buy transceivers in different wavelengths (colors) and combine/separate them with a simple passive prism with up to 8 wavelengths on a single fiber separated by wavelength (color). This is called CWDM and gives you up to 8 GBps on a single fiber. Using a single special transceiver that modulates the light frequency DWDM can push even higher distances and bandwidths on single mode.
This is separate from plastic fiber that is used in some proprietary control network hardware. Also this is just the fiber itself. There are about a dozen different types of connectors but essentially the two most popular are ST, LC, and SC. ST is more of a BNC/coaxial style big connector and LC is a small connector that will work on your typical SFP port.
Navyguy and Funkadelicfred like this.
Funkadelicfred (01-08-2020)
Old 01-08-2020, 03:50 PM   #24
VELOCI3's Avatar
Rewards Points: 102
Www.bicsi.org for the telecom standards
Old 01-08-2020, 06:56 PM   #25
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 250
I've never seen 100 micron cable. Huh. Interesting. The 10GB/s network I put in was OM4 fiber that could work up to 550 meters. OM4 fiber is 50 microns.
I have never seen a 100 micron fiber optic cable (nor have I ever heard of it) unless it's the cable they use for toslink.
Single mode cable is 9 microns.
Don't forget that there are different types of each individual connectors. There are Angled Physical Contact (APC) and Ultra Physical Contact (UPC) connectors in addition to Physical Contact (PC) connectors.
Maybe @Navyguy can chime in. I know he does data stuff.
Old 01-09-2020, 12:12 PM   #26
Rewards Points: 4,962
I have been watching, but the comments / advice are pretty good so there is not too much to add from my perspective.
I will add is there I am still not sure what this is for.
Essentially there is three levels of data / communication testing; verification, qualification and certification.
Verification is the most basic, which is essentially confirming if the ends are terminated properly and the total length of cable.
Qualification essentially indicates what the performance capabilities of the cable installation are. That test will assist in determining what sort of equipment that can be installed to achieve a specified performance level. As an example if you have a combination of VOIP and streaming, what is the available bandwidth, contamination from crosstalk, etc.
Certification essentially means that you are guaranteeing that a certain level of performance is available based on the TIA standards. While some business do this, it is primarily limited to data centres and government. Most businesses do not need this level of installation and testing.
For a simple internet connection (residential, small business), I don't see any issue with using Cat5e to the max length and placing unmanaged switches to to repack and retransmit over greater distances; it is very common and fairly inexpensive. The problem is that if you loose a switch, you loose everything beyond that switch.
For companies that rely on performance or have the potential for electrical interference, that it totally different type of installation; that is where you might need / want fibre regardless of the distance.
None of this is related to POE (totally different issue).
That is all I have to add. Thanks for thinking of me @Kevin_Essiambre
Cheers
John
Old 01-09-2020, 01:14 PM   #27
VELOCI3's Avatar
Rewards Points: 102
Lots of fiber on my current site.
Old 01-09-2020, 09:17 PM   #28
Lots of room to grow too!
Was not sure if that was a server room or a dance floor!
Cheers
John
