Pass through data jacks - Electrician Talk - Professional Electrical Contractors Forum
Like Tree82Likes
Old 01-21-2020, 09:33 AM   #1
Rewards Points: 3,029
Default Pass through data jacks
I don’t do a lot of data and it’s a PITA. It doesn’t help that my fingers don’t work and I’m half blind.
I bought some pass-through RJ45 jacks. What it means is that you can strip the cable long, push the wires through the jack and then cut them to the proper length. Makes the job an easier PITA.
Anyway, probably no big deal but I thought I would share because that’s the kind of guy that I am .
splatz and kb1jb1 like this.
Pigtails (02-19-2020)
Old 01-21-2020, 09:59 AM   #2
Liberal Lesbian
Rewards Points: 374
You are talking about the male plug end, correct?
I remember seeing that style many years ago, I believe it was EZ or something.
I still think you’re better off always terminating into a female RJ45 jack, then use a premade patch cable.
Old 01-21-2020, 11:27 AM   #3
MikeFL's Avatar
Rewards Points: 918
Those things rock. Over the holidays I reterminated every cable in our place. Part I like the most is the jacket comes out perfect every time instead of guessing how much to strip.
I don't have the newer crimp tool which will shave those wires off flush so I push through about 1/8" too far, cut them all even, then pull it back the 1/8" to get them perfectly at the face of the plug.
Works nice!
dogleg, 99cents and Easy like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 01-21-2020, 12:10 PM   #4
Works nice!
That’s what I did, cut them even and then pulled them back. My cheap Commercial Electric crimper doesn’t cut the wire but it was 27 loonies.
Old 01-21-2020, 12:11 PM   #5
That’s cheesy. Yes I am talking about the male jacks.
Old 01-21-2020, 12:17 PM   #6
Rewards Points: 2,870
I agree with both ... if you have to crimp plugs, use the EZRJ45 style, but don't crimp plugs unless you really have to.
jacks > plugs
Old 01-21-2020, 12:55 PM   #7
Liberal Lesbian
Rewards Points: 374
I'm not sure what you mean.
Old 01-21-2020, 01:08 PM   #8
This will be upsetting for Canadians, but jacks are female, plugs are male.
Old 01-21-2020, 01:48 PM   #9
Band Member
emtnut's Avatar
Rewards Points: 2,556
Nahhh ... We call those things on the wall 'Plugs'
bigzee likes this.
Old 01-21-2020, 02:09 PM   #10
Liberal Lesbian
Rewards Points: 374
Small patch panels like this can be purchased for around $15:
If that is too many ports or too large, then a typical single gang keystone plate with 1-6 jacks works well. This can be mounted in the wall with the wiring inside of the wall, or installed in one of Levitons surface mounted plastic low voltage boxes with the wiring strapped to the wall or inside of a raceway.
This is the demarcation between the building wiring and the user wiring. Then a patch cable is used to run from that female jack to the devices/switches/etc. Patch cables are extremely inexpensive, so making them yourself doesn't pay- especially if you have to use more expensive tools and material because the normal ones are hard for you to make.
I don't think that is cheesy, that is a typical installation that a low voltage pro would do.
Old 01-21-2020, 02:41 PM   #11
I’m talking about these.
five.five-six and MikeFL like this.
Old 01-21-2020, 02:43 PM   #12
Attachment 139926
You’re confused. That’s an inny, I’m talking about an outty.
Old 01-21-2020, 02:46 PM   #13
Liberal Lesbian
Rewards Points: 374
I'm not confused, you are.
The point is that you should not be making outties. There is very, very little reason for you to do so.
Old 01-21-2020, 03:13 PM   #14
Watt Pusher
B-Nabs's Avatar
Rewards Points: 484
I make outies for lighting control, but for data distribution I agree, patch panels & premade patch cords are better.
Sent from my SM-G975W using Tapatalk
Old 01-21-2020, 03:21 PM   #15
MikeFL's Avatar
Rewards Points: 918
If I'm connecting 2 things on the same table, desk, rack or shelf, I'll use a patch cable. If I'm making a long distance connection, I break out the spool of Cat 5 and run my cable and terminate the ends. There's no way I'd buy a 100' patch cable to do a 60' run.
five.five-six likes this.
GPS Timers
(833) GPS-TIME
Old 01-21-2020, 03:25 PM   #16
Liberal Lesbian
Rewards Points: 374
...that you purchased.
...into female jacks, then use patch cables that you purchased to connect those installed jacks to the devices you require on each end.
Nor should you.
Old 01-21-2020, 08:31 PM   #17
Why would you create an extra connection? Just use the proper item to begin with.
Old 01-21-2020, 08:55 PM   #18
Liberal Lesbian
Rewards Points: 374
I’ve explain to you a few times what the “proper item” is, how the professionals do it.
If you want to do it like a handyman, you are free to.
Old 01-21-2020, 09:03 PM   #19
Tell me why a professional would use the wrong connector and then put a dongle on it to make it right. Makes no sense.
Old 01-21-2020, 09:12 PM   #20
Liberal Lesbian
Rewards Points: 374
You can say that it makes no sense, but that’s not gonna change the fact that it’s the way that every professional out there does it. It’s the only way it’s done.
You never see tele-data cables coming through a hole in the wall and then terminating directly into any type of device. Not on either end.
If you see it done somewhere, then you know that it was done by somebody who didn’t know what they were doing.
