Ratio of boxes to pulls - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 1 Post By wcord
  • 2 Post By MechanicalDVR
  • 1 Post By HackWork
  • 2 Post By telsa
  • 1 Post By splatz
  • 1 Post By B-Nabs
Old 11-25-2016, 01:03 PM   #1
Default Ratio of boxes to pulls
In your experience what is the best ratio of boxes to runs when pulling large jobs. I know one to one would be ideal, but we all know that it is not ideal on a budget standpoint.
forums@neoitsvcs.com is offline   Reply With Quote
Old 11-26-2016, 09:17 PM   #2
wcord's Avatar
Rewards Points: 1,584
most specs I've run into, state every 100 feet, or maximum 2 90's. between pull boxes.
And the cable cannot change direction in the pull box
Old 11-26-2016, 10:28 PM   #3
Rewards Points: 1,018
Let me say first off there is no code requirement for a pull box per 'x' amount of feet. There is however an issue of not having more than 360 deg of bend between pull points, this is a code requirement
You need to have a means to get a rope or pulling means from one end to the other the length of the rope or pulling means is the only limit.
Old 11-26-2016, 10:54 PM   #4
360max's Avatar
Rewards Points: 1,234
vertical.chases
Old 11-27-2016, 12:51 AM   #5
Mensa Player
Rewards Points: 1,801
Originally Posted by 360max View Post
vertical.chases
Good job posting a code reference.
No one is talking about cable support.
Majewski likes this.
Old 11-27-2016, 03:24 AM   #6
Rewards Points: 25,908
You might note he's still on his 'period.'
MechanicalDVR (11-27-2016)
Old 11-27-2016, 03:25 AM   #7
Rewards Points: 16,315
Old 11-27-2016, 05:33 AM   #8
Rewards Points: 4,064
Those are pulled from the TIA 569 standard, which goes well beyond NEC requirements. Sometimes the bid specs will just reference the TIA 569 standard, some will just include some main points from the 569. If you follow those two criteria and NEC fill ratio you can't get into too much trouble.
I don't understand the OP so I can't comment on that.
wildleg likes this.
telsa (11-27-2016)
Old 11-27-2016, 08:09 AM   #9
Guess these remain out of his grasp:
telsa and Majewski like this.
telsa (11-27-2016)
Old 12-04-2016, 08:23 PM   #10
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
I think he was actually asking about how many boxes of cable one should have, relative to how many runs they are pulling. His point being that on a job with 100 drops, obviously you're not going to have 100 boxes. So he was asking about a reasonable number of boxes for a given job of a given size.
That said, I don't think the question is easily answerable as stated; there are too many variables.
[email protected] likes this.
Old 12-04-2016, 08:45 PM   #11
halfamp's Avatar
Rewards Points: 516
3 runs / box you'll have to make a conscious effort to pull over length. Mark footage on boxes as they lighten up and match shorter pulls to shorter boxes for maximum effieciency
halfamp is offline   Reply With Quote
Old 12-14-2016, 07:28 PM   #12
Rewards Points: 18
B-Nabs - You understood me completely.
steve@neoitsvcs.com is offline   Reply With Quote
Preferred boxes for concrete walls masonc General Electrical Discussion 10 05-17-2016 08:37 PM
Adjoining 1900 boxes Nutmegger777 General Electrical Discussion 41 05-03-2016 12:21 PM
1900 boxes under a raised floor system LightsOn81 General Electrical Discussion 12 04-25-2016 10:15 PM
Old work boxes meadow General Electrical Discussion 52 04-23-2016 07:33 AM
Exterior Box trim for recessed boxes psgama Residential Electrical Forum 7 01-22-2016 06:18 PM
