UPS Issues - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
  • 1 Post By gpop
  • 2 Post By wildleg
  • 2 Post By GrayHair
  • 2 Post By emtnut
  • 3 Post By Bird dog
  • 3 Post By Navyguy
  • 1 Post By Kevin_Essiambre
  • 2 Post By paulengr
  • 3 Post By splatz
Old 09-06-2019, 03:57 PM   #1
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 288
Default UPS Issues
Hey Everyone,
I installed a Tripp Lite SmartPro1500LCD UPS and it seems to be acting funny.
When on power from the grid, its running 125 volts with 105 watt load. It Should run for 45 minutes when it goes to battery power, however, when it transfers to battery power, it will go from 105 watts to over 445 watts @ 115 volts and will only run for +/- 11 minutes.
Is this an issue with the UPS internally that would require replacement? It's under warranty if it is an issue.
I had originally thought it could have been a higher wattage due to the lower voltage, but that would need to be a very large difference to affect the wattage that much.
Any thoughts on what it could be?
Thanks in advance,
Kevin.
Old 09-06-2019, 04:11 PM   #2
Rewards Points: 1,844
What does your amp meter say. With out knowing what the load is its possible that the power going out it adding extra load.
Kevin_Essiambre likes this.
Old 09-06-2019, 04:24 PM   #3
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
nac's, ups's, and anything else that run on batteries sit around warehouses until they get purchased, bleeding electrons.
get em to send out new batteries or a replacement unit.
glen1971 and Kevin_Essiambre like this.
Old 09-06-2019, 05:40 PM   #4
Rewards Points: 3,994
Have you checked the individual batteries to see if they are ok?
Old 09-06-2019, 05:50 PM   #5
Rewards Points: 1,260
That's not a real good UPS. Tripp Lite makes some good surge protectors but their UPS's are low end. (Kind of like Klein / pliers / meters.) But I've put a few in and inherited a few others and haven't come across that issue.
The wattage should not change much on battery. The actual load is exactly the same at the same output voltage. The wattage should be the same internally - less volts but more amps before inverting - plus a little power lost in conversion, less than 10%.
It could be that the indicators are malfunctioning and reporting wrong, or that the electronics are malfunctioning and it's losing way too much in conversion, you could figure it out with amp clamp or etc. But, either way it's malfunctioning, and I'd look for a replacement, and a different brand if you can swing it.
Kevin_Essiambre (09-06-2019)
Old 09-06-2019, 07:45 PM   #6
Rewards Points: 136
Check to see what all you're actually powering. I've seen CRTs, Laser printers and resistance style foot-warmers on a UPS.
Bird dog and Kevin_Essiambre like this.
GrayHair is offline   Reply With Quote
Old 09-06-2019, 08:58 PM   #7
Band Member
emtnut's Avatar
Rewards Points: 2,012
Originally Posted by Andyz23 View Post
+1
22 posts and 20 of them +1
2 'welcome to the forum'
yeah, riggggghhhhhht
glen1971 and splatz like this.
Old 09-06-2019, 09:13 PM   #8
Bird dog's Avatar
Rewards Points: 948
+1
and no profile filled out.
Old 09-06-2019, 10:00 PM   #9
Rewards Points: 5,120
Hidden links in post too...
Cheers
John
Old 09-06-2019, 11:35 PM   #10
Beam Me Up Scotty
Rewards Points: 288
The load is all minimal network equipment.
Total load consists of:
-8 channel NVR with 3 cameras
-8 channel PoE switch with 6 devices
-24 channel network switch
-router
-access point controller
-cell phone booster (power brick is 12v 3 amps)
I will have to head back there and open the panel to stick an amp meter on it.
Old 09-06-2019, 11:37 PM   #11
Beam Me Up Scotty
Rewards Points: 288
I'll be requesting a replacement battery before taking the old one out to check it... I made a mistake when I bought this UPS... it has to be removed from the rack I'm using to access the battery compartment and if I'm doing that I might as well change the battery.
glen1971 likes this.
Old 09-06-2019, 11:41 PM   #12
Beam Me Up Scotty
Rewards Points: 288
I realized after using this tripp lite ups that they don't live up to the name like their surge protection does.
If I have to change it I'll be finding an APC UPS to avoid call backs. The only reason we installed a UPS is to keep the system online while the generator starts... if they ever install the generator.
I'll have to call tripp lite and the supply house on Monday and head back put there to check with an amp meter.
Old 09-07-2019, 07:52 PM   #13
Chief Flunky
Rewards Points: 338
APCs are even worse. I’ve had them go on battery because input voltage was more than 5% out. Their remote network cards are terrible. And at least Tripplite has customer support.
splatz and Kevin_Essiambre like this.
Old 09-07-2019, 07:57 PM   #14
Beam Me Up Scotty
Rewards Points: 288
Huh. I've heard nothing but great things about them.
Old 09-07-2019, 08:01 PM   #15
No no no. APC also sucks they just have better marketing. They have been the IT brand of choice since the 90's but it's really just proof that marketing is more important than physics with the IT crowd. Suck suck suck. Awful surge protection and if you read the fine print they ask you not to supplement with better surge protection.
Old 09-09-2019, 10:08 AM   #16
Beam Me Up Scotty
Rewards Points: 288
So if I have to replace It, what brand should I go with?
Old 09-09-2019, 02:07 PM   #17
I never know what's going to be available in Canada, I'd just look for a true sine wave, true online, double conversion UPS made by a company known for quality UPS products. I like Eaton's products. Liebert, Minuteman, and used to be good too, I have seen their products advertised at decent prices but don't know if their quality has held up over time.
I think Alpha brand might be Canadian and they are popular with telco and CATV carriers, I think they have some good products.
Kevin_Essiambre (09-09-2019)
