Wiring Recepts and Light Switches - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 1 Post By zac
  • 2 Post By MikeFL
  • 1 Post By macmikeman
  • 1 Post By Wirenuting
  • 1 Post By canbug
  • 1 Post By sparkiez
  • 1 Post By VELOCI3
  • 1 Post By VELOCI3
  • 1 Post By 99cents
Old 11-26-2019, 09:12 PM   #1
ChrisF1180's Avatar
Default Wiring Recepts and Light Switches
I am having a lot of trouble. I really want to cut my time down. I am tired of being slow and the black sheep of my group. Smh...The company where I am working. They layoff workers that tend to be slow smh...I am trying to go as fast as I can. Any advice that will cut my time down will be helpful and greatly appreciated.
ChrisF1180 is offline   Reply With Quote
Old 11-26-2019, 09:56 PM   #2
zac
Rewards Points: 826
Lance Bass?
dronai likes this.
Old 11-26-2019, 10:38 PM   #3
MikeFL's Avatar
Rewards Points: 912
Get it right before you get it fast. Else you do a whole bunch of work that you get to do again. Then always look a few steps ahead and know what order things are going to happen in.
tmessner and kjz like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-26-2019, 10:40 PM   #4
dronai's Avatar
Rewards Points: 439
Sink or Swim
Old 11-27-2019, 12:10 AM   #5
Rewards Points: 21,657
Those little holes on the back of the devices-,,, Those are called profit holes around here.
John Valdes likes this.
I stand with Tucker Carlson
Old 11-27-2019, 12:12 AM   #6
Watt Pusher
B-Nabs's Avatar
Rewards Points: 484
Not glory holes?
Old 11-27-2019, 07:26 AM   #7
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,582
Practice makes perfect and perfect increases speed over time.
Sit and watch someone who is older and faster at it.
Before you ask him a bunch of questions, see what he is doing differently then you.
Compare what he does with what you do.
kjz likes this.
Old 11-27-2019, 09:24 AM   #8
canbug's Avatar
Rewards Points: 2,138
Use your eyes and your head together and learn by watching. Don't stop what you are doing but notice how things are done. If you can't be fast, be really good, you will stay on a job longer. If you or worse, someone else have to redo your work, that is a quick ticket out the door.
Tim.
tmessner likes this.
Old 11-30-2019, 02:04 PM   #9
Rewards Points: 938
Out of curiosity, do you find that the people you work with often have to go back and troubleshoot stuff / fix mistakes when they test? My point being that you may not necessarily want to aspire to be like them. Within reason, slower and correct is always better for construction work.
Easy likes this.
Old 01-08-2020, 06:54 AM   #10
VELOCI3's Avatar
Rewards Points: 118
I wanted to be a doctor but turns out it’s not an easy field and here I am.
VELOCI3 is online now   Reply With Quote
Old 04-06-2020, 11:01 AM   #11
Easy's Avatar
Rewards Points: 1,832
It can be kind of rough starting out but just keep with it. Knowledge is power so learn all you can about the trade when you are not at work. I remember when I started out and working for a small shop. We had 2 journeyman and 2 helpers and the bosses son who was totally useless. They needed to let one of the helpers go so they decided to have competition. Me against the other guy. Both of us were real green and had very little skill bending conduit. They put us both in separate but identical rooms and gave each of us a 1/2" bender and told us who ever was faster at completing the piping would stay and the looser would go. Long story short... They actually were looking for quality not quantity.
Easy is online now   Reply With Quote
Old 04-06-2020, 11:25 AM   #12
VELOCI3's Avatar
Rewards Points: 118
I tell my guys i want it done right. The conduit will be around a lot longer than any of us will and if it looks like Stevie Wonder put it up that’s not gonna work. That being said As long as the lead guy in the crew is good the rest are just a set of hands.
After 23 years of non stop piping it better look good, done correctly etc. it’s all in the layout.
Easy likes this.
Old 04-06-2020, 06:19 PM   #13
Rewards Points: 2,774
set up a practice box from some scrap then count in your head during every task.
You will probably find that most of your time is spent finding tools. Over time this will become muscle memory which is why people don't like to lend tools are they are put back in the wrong spots.
Smooth and slow will always be faster than quick and messy.
Old 04-06-2020, 06:38 PM   #14
Rewards Points: 2,957
In my experience it isn’t the common, repetitive tasks that take time, it’s what you do when you come across a minor problem. With wiring devices, that can be bad threads in a box, screws that break off in a box (they’re only zinc), mangled wires from the drywall gorilla, etc.
You need to have a 6/32 tap with you. If the screw shows any resistance, back it out and thread the hole. Those screws get hot quickly especially if you’re using a power driver. Have some long 6/32’s with you for boxes that are deep in the drywall. Have a good supply of pre-cut black and white pigtails with you.
Proper preparation saves time.
I’m allowed to sit on my ass and take my time. You’re not. You’re only allowed to get down on your knees. Knee pads or something similar aren’t a bad idea. I have a friend who bashed his knee on a bolt on structural steel and it screwed him for life. Protect them.
zoltan likes this.
Old 04-06-2020, 08:44 PM   #15
Rewards Points: 1,040
Please take a few minutes and fill out your profile.
Its easy and fast.
