I would like to ask a real higher-up engineer a question - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Site Supporter Section > Milbank Manufacturing
Like Tree34Likes
Old 12-24-2017, 04:25 PM   #1
Lesbian Liberal
Rewards Points: 950
Default I would like to ask a real higher-up engineer a question
Can someone please pass a question to an engineer at Milbank, some familiar with the code, listings, and design of the meter pans?
Recently a member here posted the following:
Sent: Monday, December 18, 2017 4:10 PM
To: Rick Holbrook Milbank Tech support
Subject: Technical Question for you
Dear Rick & Cathy Holbrook
My name is Steve , I'm a Vermont electrician with a question about Milbank meters and/or enclosures I'm hoping you can help me with.
It would appear there is a dispute in just what the 1/4" knockouts on the bottom of your meters are really for
Some say it's for the GEC (Grounding Electrode conductor)* , usually a bare #6 or #4 copper wire to simply run through
However, we are finding this is not to code, the* NEC passage(s) below being applicable
Can you unfuzz me please? Thank you for your time
~Steve *Vermont Electrician
Sent: Tuesday, December 19, 2017 2:04 PM
Subject: FW: Technical Question for you
Hi Steve,
The ¼” KO’s are for water drainage only.
I believe this to be false. With all due respect to Mr. Rick Holbrook, it makes no sense for a 3R rated meter pan to require a knockout to be opened to drain water out. The meter pan comes arranged to drain from the factory with small weeping holes/slots.
Can someone please pass this up to an engineer who can give a definitive answer on the purpose of these smaller holes?
readydave8 and Majewski like this.
Old 12-24-2017, 04:26 PM   #2
Lesbian Liberal
Rewards Points: 950
Here is an example (bottom right hand corner of the enclosure) of a factory weeping hole in outdoor enclosures, giving it it's 3R rating:
I would like to ask a real higher-up engineer a question-milbank-meter-sockets-r8750-rl-kk-64_1000.jpg
Click for larger.
Those rear holes along with the slots in the front allow water to drain.
Old 12-27-2017, 09:11 AM   #3
Vendor
Rewards Points: 72
We have a lot of folks out for the holidays, but I'll send it around. Might be til next week! I'll keep you posted.
MikeFL likes this.
Milbank_Marissa is offline   Reply With Quote
Old 12-27-2017, 09:13 AM   #4
Lesbian Liberal
Rewards Points: 950
Thank you Marissa.
Old 12-28-2017, 01:20 PM   #5
Vendor
Rewards Points: 72
From the engineering department: "We have corner notches in the bottoms to drain water. The 1/4" KO is for the grounding wire."
Does that answer everyone's question? Let me know!
The Following 7 Users Say Thank You to Milbank_Marissa For This Useful Post:
A Little Short (12-28-2017), HackWork (12-28-2017), macmikeman (12-28-2017), MikeFL (12-28-2017), readydave8 (01-05-2018), TGGT (02-09-2018), trentonmakes (12-28-2017)
Old 12-28-2017, 01:25 PM   #6
Rewards Points: 21,575
Thank you very much Marissa. Just for that, I will look for Milbank items now, even though you don't sell any on Oahu that I have seen. You really should though. Home Depot?
I stand with Tucker Carlson
Old 12-28-2017, 01:28 PM   #7
MTW
Rewards Points: 12,067
I'll send you some from the mainland.
Milbank_Marissa likes this.
Old 12-28-2017, 01:28 PM   #8
Vendor
Rewards Points: 72
Haha love it! Yes we should be at your local home depot! I'll check to see if we're in Oahu anywhere else."
MikeFL likes this.
Old 12-28-2017, 01:30 PM   #9
I don't see anything from you guys at Home Depot. Or Lowe's.
Old 12-28-2017, 01:34 PM   #10
Lesbian Liberal
Rewards Points: 950
Thank you Marissa, I really appreciate it.
Can one of you gentlemen please post this at Mike Holt’s forum letting them know that now both Square D and Milbank specify the 1/4” hole or 5/16” hole is for the grounding electrode conductor please. Thanks.
Old 12-28-2017, 01:35 PM   #11
Vendor
Rewards Points: 72
That's crazy! My afternoon project will be to figure out why- I'll ask our retail lady
MikeFL likes this.
Old 12-28-2017, 01:43 PM   #12
The train don't come all the way out yet..........
Old 12-28-2017, 02:23 PM   #13
MikeFL's Avatar
Rewards Points: 902
Mike your POCO will usually spec what meter pans they accept. The local suppliers are going to stock whatever that market will require.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 12-28-2017, 05:42 PM   #14
Pretty rare for us to even use a meter pan. We hang meter/mains usually and those are set to USERAC or some letters like that. Alternately , for larger services, we can mount a CT can and a meter pan for a checking meter, then a Service disconnecting /overcurrent protection , and then the panels remote if we like. That's about the only time I have hung a meter pan here , that and tenant check metering for commercial sub spaces.
I remember wholesale houses stocking Milbank items way long ago like 70's .
Except for this forum, I would have assumed they went the way of the Challenger during the buyout frenzy.
Old 12-28-2017, 05:46 PM   #15
MTW
Milbank doesn't make an EUSERC products apparently.
Old 12-28-2017, 05:47 PM   #16
Watt Pusher
B-Nabs's Avatar
Rewards Points: 484
Saying EUSERC around here is like sending up a telsa bat signal.
readydave8 and lighterup like this.
Old 12-28-2017, 05:48 PM   #17
MTW
I will have to disguise it somehow next time. Maybe CRESUE?
macmikeman likes this.
Old 12-28-2017, 05:56 PM   #18
Rewards Points: 26,860
Too late.
Old 12-28-2017, 05:59 PM   #19
Lesbian Liberal
Rewards Points: 950
Too late.
So, telsa, since you won't dare step into the GEC thread, I will ask here...
You tried to substantiate the requirement to bond the GEC to a panel as it enters by saying that the existence of the Kenny clamp as a product being sold means that it had to be used, or else it wouldn't be available to buy. Those were your words, I can quote them here if you like.
So, using that logic, the fact that 2 of the biggest manufacturers say that the hole in their panel/pan is for the GEC to pass thru without being bonded, that would mean that it's OK, right?
Old 12-28-2017, 06:49 PM   #20
Chirp, chirp, chirp..............
CSA Group Question vs its Reference XCasper Canadian Electrical Forum 12 06-12-2018 01:01 PM
Transformer internal wiring question JasonCo General Electrical Discussion 11 03-22-2017 05:10 PM
16 AWG wire ampacity at higher temperatures Paul Kraemer General Electrical Discussion 5 10-13-2016 05:41 PM
Real Estate investing done smart telsa Off Topic (Non Trade) 13 01-30-2016 03:43 PM
Electrician to engineer? DownInGeorgia General Electrical Discussion 43 01-04-2016 06:19 PM
