I would like to ask a real higher-up engineer a question - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Site Supporter Section > Milbank Manufacturing
Like Tree34Likes
Old 12-28-2017, 07:03 PM   #21
sbrn33's Avatar
Rewards Points: 3,634
Old 12-29-2017, 08:21 AM   #22
Rewards Points: 578
@chicken steve
We need you to send this thread to your friend Rick Holbroock so that he doesn't continue to give out bad information, thanks.
Old 12-29-2017, 09:12 AM   #23
MXer774's Avatar
Rewards Points: 608
For some reason, I don't think we are going to see responses.
MXer774 is offline   Reply With Quote
Old 12-29-2017, 09:34 AM   #24
MTW
Rewards Points: 12,553
Steve, are you going to admit that you're wrong?
Old 12-29-2017, 05:14 PM   #25
Rewards Points: 578
@chicken steve
Since you were so big on contacting the manufacturers, I would like to hear your opinion on the fact that both Square D and Milbank say that the small hole is for the GEC, and their listing says to use it for that purpose.
I would also like to hear what you said to Rick Holbroock. Thanks.
Old 12-30-2017, 07:57 PM   #26
gnuuser's Avatar
Rewards Points: 1,540
there is more than one grounding scheme and they are dependent upon the disconnect means used and dependent on the requirements of the locality.
hence you will find bonding fixtures in panels, disconnects, and meter cans
to say one is correct and not the other is foolishness.
its a simple procedure when getting the permit in order to get a hold of the local inspector for the required information.
while we have the nec and cec codes to rely on you need to remember that local code requirements can and often do supersede the nec and cec
Old 12-30-2017, 08:04 PM   #27
Rewards Points: 578
This discussion is based on the NEC. We have clearly said that since the beginning.
Old 01-01-2018, 05:16 PM   #28
Retired Account
Rewards Points: 14,650
I'll agree that state amendments do supersede NEC requirements Gnuuser
But that would be a pre legislated agreement state bureaucratic oversight would have on the books
I say this because a 90.4 can clash with a 110.3B , and will fall back on such instruments.
Imagine yourself an AHJ, confronted daily with electrical materials some of which are approved via for profit NRTL's
Would you hang your hat on the safest install , or what they are telling you it is?
Old 01-01-2018, 05:20 PM   #29
Rewards Points: 21,919
Steve, can you explain the 1/4" knockout at the panel bottom once again please? I want to make sure to send your information to Square-d and to Milbank engineering to inform them they are all wrong about it.
I stand with Tucker Carlson
Old 01-01-2018, 05:41 PM   #30
Rewards Points: 578
So you are now trying to say that an inspector should fail a job based on his own feelings of what is safe instead of going by the code and the manufacturer's listing??
You are THAT petty and pathetic? You just won't admit that you are wrong about such a simple issue.
MTW likes this.
Old 01-02-2018, 04:58 PM   #31
Vendor
Rewards Points: 72
I don't see anything from you guys at Home Depot. Or Lowe's.
Checked into this-- apparently we're only at select Home Depot's and Lowes.
Milbank_Marissa is offline   Reply With Quote
Old 01-15-2018, 08:41 AM   #32
Rewards Points: 578
Can we get Rick Holbroock to come in here and tell us why what he emailed chicken Steve was the opposite of what Marissa said the engineering team said?
Steve to this very day continually uses Rick's response to justify incorrect installations. This is important that we find out the truth.
Roger likes this.
Old 01-15-2018, 09:10 AM   #33
Vendor
Rewards Points: 72
I will email him and get back to you--
HackWork and RePhase277 like this.
The Following 2 Users Say Thank You to Milbank_Marissa For This Useful Post:
HackWork (01-15-2018), Roger (01-16-2018)
Old 02-09-2018, 07:55 AM   #34
Rewards Points: 578
Any word?
It's funny because when Rick Holbroock gave wrong and dangerous information to Steve, he did so very quickly. Now we can't get a reply at all. Now, both of them are not willing to even comment on it.
chicken steve likes this.
chicken steve (02-09-2018)
Old 02-09-2018, 08:41 AM   #35
Rewards Points: 1,360
Any word?
Mr. Holbrook died on January 13th from complications while having a metal sliver removed from his eye. Seems he was drilling a 1/4" hole into a panel can.
Old 02-09-2018, 01:43 PM   #36
Rewards Points: 24,222
What an awful way to go!
Old 02-09-2018, 02:50 PM   #37
Vendor
Rewards Points: 72
Milbank doesn't make an EUSERC products apparently.
Ouch that hurts! :-)
We absolutely do! Here's a link to our Western Region Catalog:
https://milbankworks.com/getmedia/d8...ern-region.pdf
Old 02-09-2018, 05:20 PM   #38
MTW
I stand corrected.
CSA Group Question vs its Reference XCasper Canadian Electrical Forum 12 06-12-2018 01:01 PM
Transformer internal wiring question JasonCo General Electrical Discussion 11 03-22-2017 05:10 PM
16 AWG wire ampacity at higher temperatures Paul Kraemer General Electrical Discussion 5 10-13-2016 05:41 PM
Real Estate investing done smart telsa Off Topic (Non Trade) 13 01-30-2016 03:43 PM
Electrician to engineer? DownInGeorgia General Electrical Discussion 43 01-04-2016 06:19 PM
