Lot's of electrician need your help, Milbank - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Site Supporter Section > Milbank Manufacturing
Like Tree66Likes
Old 07-31-2017, 08:48 PM   #1
Gouging Profiteer
Rewards Points: 789
Default Lot's of electrician need your help, Milbank
We use only Milbank meters in my area. Most new services have a PVC riser coming out of the top:
Lot's of electrician need your help, Milbank-screen-shot-2017-07-31-8.41.51-pm.png
You can see the PVC pipe glued into the PVC connector (male adapter) which is threaded into the meter hub.
The problem, as we have been discussing for years, is that the hub on the top of the meter pan is only listed for use with rigid conduit which has tapered threads. The PVC male adapter threaded into the meter hub in the picture has straight threads, and is against the listing to use, so some people fail inspection.
We would like it if you provided a solution, or used your power to push another manufacturer into providing a solution. This has been going on for years and is a serious impediment to the work. Some contractors go so far as to screw a 6" rigid pipe into the meter hub, then screw a PVC female adapter onto the pipe, then glue the pipe into the adapter. That is extremely ugly, more work, and more money.
In Canada they use a PVC hub which allows you to glue the PVC pipe directly into it:
This would be perfect for us.
The Following 2 Users Say Thank You to HackWork For This Useful Post:
flyboy (07-31-2017), telsa (07-31-2017)
Old 07-31-2017, 08:56 PM   #2
Can't Remember
Rewards Points: 1,498
Change of listing allowing a sealant or maybe sealing washers perhaps?
Old 07-31-2017, 08:58 PM   #3
Can't Remember
Also needs to cover the use of weatherproof SE connectors as we use them a lot up here.
MTW likes this.
Old 07-31-2017, 09:05 PM   #4
Rewards Points: 1,360
Wait... what are weatherproof SE connectors supposed to screw into if not a meter hub? Are the hubs not listed for use with those connectors? I thought it was only myers hubs that had the rigid - only listing?
Old 07-31-2017, 09:10 PM   #5
Gouging Profiteer
Rewards Points: 789
The hubs are only listed for rigid pipe.
Good question about how the weatherproof SE connectors are supposed to be installed. Right into an enclosure with a sealing locknut?
Old 07-31-2017, 09:22 PM   #6
Small Potatoes
flyboy's Avatar
Rewards Points: 4,353
When we use SEU we screw the weathertight SEU connector into the hub. Never had a problem.
MTW likes this.
Old 07-31-2017, 09:23 PM   #7
MTW
Rewards Points: 12,008
I'd like to see the PVC hub become available here.
So Milbank, make a few molds and start making them.
Old 07-31-2017, 09:24 PM   #8
Can't Remember
Don't have any real problems with a ta into hub either other than code/listing ones.
Old 07-31-2017, 09:25 PM   #9
Gouging Profiteer
Rewards Points: 789
Same here. But you could fail for the same reason as screwing a PVC male adapter in.
Old 07-31-2017, 09:25 PM   #10
MTW
Yes, there's literally hundreds of thousands, if not millions of services here like that.
MechanicalDVR and circuitman1 like this.
Old 07-31-2017, 09:26 PM   #11
Small Potatoes
flyboy's Avatar
I did not know that.
Old 07-31-2017, 09:26 PM   #12
Small Potatoes
flyboy's Avatar
Same here.
Old 07-31-2017, 09:26 PM   #13
MTW
Thankfully inspectors here don't see it that way. Otherwise it would be armegeddon if any inspector dared to fail an SEU connector in a meter hub.
Old 07-31-2017, 09:28 PM   #14
Gouging Profiteer
Rewards Points: 789
The meter hub is only list for use with rigid pipe. Or at least that's what I was told on the Mike Holt's forum by people who looked the listing up. And that's the reason why some inspectors fail a PVC male adapter threaded into the meter hub.
Old 07-31-2017, 09:29 PM   #15
Can't Remember
No but let's fix this so it's not on the "agenda".
Old 07-31-2017, 09:29 PM   #16
Gouging Profiteer
Rewards Points: 789
Yeah, I have never had that fail. But I haven't had the PVC MA threaded in the meter hub fail either.
Old 07-31-2017, 09:32 PM   #17
Can't Remember
Me neither, next thing you know it ends up being discussed in a seminar or in one of the trade mags.
Old 07-31-2017, 09:38 PM   #18
Small Potatoes
flyboy's Avatar
I always just assumed that because the weathertight SEU connectors were metallic, they were approved.
I bet there's a bunch of inspectors out there that don't know this.
Old 07-31-2017, 09:45 PM   #19
MTW
Thankfully in my 15 years of being in the trade now, I have never seen or heard of an inspector failing for this. But then again, I live in the land of SEU cable. PVC services are extremely rare for resi where I live.
Old 07-31-2017, 09:54 PM   #20
Gouging Profiteer
Rewards Points: 789
Either way, it's still threading straight threads into a tapered thread fitting.
Becoming electrician westbeachsurfrat General Electrical Discussion 4 12-03-2016 09:52 PM
any industrial electrician doing the factory maintenance here? mike883 General Electrical Discussion 41 10-03-2016 11:52 AM
Oregon Supervisor (Master Electrician) msd1212 General Electrical Discussion 2 02-08-2016 04:02 PM
