Attic Safety - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
Old 10-04-2019, 12:54 AM   #21
Rewards Points: 4,450
Originally Posted by Easy View Post
lever nuts are same as wire nuts .. yes / no ?
No, lever nuts shaped similar to the push-in type wagos or ideal in-sures but they have a lever to lock in each wire.
Easy likes this.
telsa (10-05-2019)
Old 10-04-2019, 09:58 AM   #22
Easy's Avatar
Rewards Points: 404
Thanks for sharing Splatz. I have not seen the 221 series Lever Nuts before. They are a pressure type connection so I guess they are much better than the stab in type.
This is what the manufacture said. "HTCELLE lever-nut connector housing is made of the best high quality PC insulating material. With the advantages of long life, corrosion resistance, high-temperature resistance and aging resistance, HTCELLE wire connector can effectively prevent electrical leakage. So the lever nuts are safer than traditional wire nuts."
Old 10-04-2019, 10:15 AM   #23
Easy's Avatar
Rewards Points: 404
wow they even sell a tool to open them with .. for only $172 .. not sure if I would rush out and buy one.
Old 10-04-2019, 11:49 AM   #24
LOL that's how they do in Europe!
Kevin_Essiambre likes this.
Old 10-04-2019, 12:47 PM   #25
Mensa Player
Rewards Points: 795
I remember Shunk posted that a while back.
That is good if you are fabricating things and making up hundreds of connections per day.
IMO, I think that opening them too early could lead to a weaker spring. I try not to open mine until immediately before using it. I don't even like letting it sit there opened for 10 minutes, but that might just be my OCD
Old 10-04-2019, 08:03 PM   #26
Easy's Avatar
Rewards Points: 404
It’s all about safety. I’d hate to break a finger nail opening a lever nut.
Old 10-04-2019, 08:20 PM   #27
Mensa Player
Rewards Points: 795
You're more likely to nip your fingertip, or your lip. Those levers hurt pretty badly if they close on you.
Easy likes this.
Old 10-04-2019, 08:48 PM   #28
Easy's Avatar
Rewards Points: 404
Yeah use your teeth to open them and pinch your lip.
Old 10-04-2019, 08:55 PM   #29
Mensa Player
Rewards Points: 795
I’ve never use my teeth to open them, but I do keep them in my mouth sometimes while dealing with the wires.
