Apprentice Advice. - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > Electrician Apprentice Forum
Like Tree35Likes
  • 5 Post By TheLivingBubba
  • 3 Post By just the cowboy
  • 3 Post By Coppersmith
  • 2 Post By TheLivingBubba
  • 6 Post By telsa
  • 1 Post By splatz
  • 2 Post By splatz
  • 1 Post By splatz
  • 1 Post By joebanana
  • 2 Post By stiffneck
  • 1 Post By stiffneck
  • 4 Post By Phillipd
  • 1 Post By Instrumentation
  • 3 Post By Southeast Power
Old 03-03-2020, 11:18 AM   #1
Default Apprentice Advice.
I’m about to start an apprenticeship program in Montana. Please let me know your best advice for someone starting out at an older age.
Hunger James is offline   Reply With Quote
Old 03-03-2020, 11:51 AM   #2
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 1,416
How old are you? That may or may not be helpful.
Background?
Number one thing is pencil/pen and notepad. Always write things down so you don't have to ask. When finished run down the task with who assigned it to you quickly to make sure you didn't miss anything.
CoolWill is my spirit animal and much more handsome than HackWork
TheLivingBubba is online now   Reply With Quote
Old 03-03-2020, 12:38 PM   #3
just the cowboy's Avatar
Rewards Points: 656
Get or stay in shape, a lot of bull work when starting.
wirestretcher, telsa and splatz like this.
"DID THIS FIX IT??"
The Following 2 Users Say Thank You to just the cowboy For This Useful Post:
Hunger James (03-03-2020), TheLivingBubba (03-03-2020)
Old 03-03-2020, 12:49 PM   #4
Coppersmith's Avatar
Rewards Points: 382
I became an apprentice at 46 and did fine. You will too. You already are more focused and caring than the 18 year olds. The j-men will treat you with more respect. Just do your reading and homework and everything a j-man tells you to do. In a few years you will be commanding your own apprentices.
tmessner, splatz and Hunger James like this.
Coppersmith is offline   Reply With Quote
The Following User Says Thank You to Coppersmith For This Useful Post:
Old 03-03-2020, 01:27 PM   #5
Background?
I just turned 43 in January. I have mostly worked in Restaurants. Bar tending, Cooking, and management. For the last 6 years I have been working in manufacturing making backpacks, team leading and working in a warehouse. I have also some construction experience and have done plenty of manual labor.
Old 03-03-2020, 03:56 PM   #6
Trained Monkey
Think about how your skills that you have already can cross over.
1) Write everything down
2) Optimum carry, never have an empty hand. If you are heading somewhere and you're done with a material or tool take it back.
3) Be knowledgeable, know the names of the material you need, the location, the amount you will need.
Be quiet, listen, learn, always be willing to work.
The Following User Says Thank You to TheLivingBubba For This Useful Post:
Old 03-03-2020, 04:58 PM   #7
Rewards Points: 26,864
As a rank apprentice you should -- as fast as possible -- learn our trade's vocabulary.
You can easily do this in your spare time by 'shopping' at Big Box Hardware -- take your camera.
I say this because it's VERY common for a newbie to be tasked with fetch and carry. You want to impress everyone as though you've been working with die-cast set screw connectors and couplings all your life. You don't want to be in the embarrassing position of constantly asking -- "What's a XXXX?"
In real life, an apprentice I knew wasted 40 minutes trying to find a 1/2" set-screw connector. 200 of them were staring him in the face. He was too ashamed to tell his lead he had absolutely no idea what they looked like. Naturally his boss was totally disgusted.
If you really want to cheat, buy a bender and learn to bend 3/4" EMT on your own dime. Don't get fancy. Just learn to bend 90-degree bends. Every job produces scrap EMT. Snag some and bend it at home -- out doors, of course.
Buy your own copy of Ugly's. It's about $20 at any supply house. It's crammed with the details we use every day. A couple of pages lay out our trade's symbols: receptacle, outlet, disconnect,... While your foreman// lead man will layout what's necessary -- it's nice to be able to read the prints, yourself, as soon as possible. Doing so makes you look much more professional.
Another terrific study aid are OLDER NEC Handbooks... not Codebooks. These can be had all the time on eBay -- even Amazon. They go for cheap. They're out-dated. BUT, they illustrate how field wiring used to be installed. They have lots of diagrams, tables, and explanations for why the Code is the way it is. As a newbie, you need this level of detail.
( You want hardbound, BTW. PDFs just don't cut it.)
Make sure your Personal Protection Equipment is totally squared away. Your required PPE will be made evident right away -- jump on it.
Your biggest outlay: boots. Go for comfort, not economy. Your boots will be your number one tool. They keep you walking.
While not usually mandated, you must invest in working gloves. One pair will be full bodied... feeder pulls, rough work, ditching.
One pair must be tip-less. Look for these at Big Box Hardware. For outdoor work in Montana -- you have to have both.
As previously posted: have a pen and pad -- with back-ups -- as you can't lose your ability to take notes.
Switched, tmessner, splatz and 3 others like this.
Old 03-03-2020, 05:03 PM   #8
Rewards Points: 2,794
The most important thing about getting in shape, if you're overweight, is to lose weight. You can work yourself into shape to an extent but if your overweight it won't just make you tired it will beat up your joints etc., everything the ground up, feet, knees, back, everything.
telsa likes this.
The more you know, the less you need.
Old 03-03-2020, 05:11 PM   #9
If you can, get your hands on some of the manufacturer's catalogs - PDFs are on their web sites, but you can get printed copies for many brands at electrical supply houses. They aren't exactly exciting reading but you can just flip through them to familiarize yourself with things. Bridgeport Fittings, Arlington International Fittings, Erico - Caddy (now part of nVent), etc.
If you can get a copy of the American Electrician's Handbook, it's like an encyclopedia, it's good to flip through as well.
There's a good old book called "Wiring Simplified" that's not a bad starter book, should not be hard to find, they might even have it at Home Depot.
telsa and stiffneck like this.
Old 03-03-2020, 05:13 PM   #10
And just to reinforce with repetition, as others said, keep something on hand to jot notes with at all times, following detailed instructions accurately can be a challenge and it's extremely important.
Hunger James likes this.
Old 03-03-2020, 05:40 PM   #11
Rewards Points: 8,049
Show up on your time, leave on theirs. READ, everything about electrical you can get your hands on. Work smart, not hard, plan your work accordingly. Keep a good attitude, sometimes it may be hard to do, just fake it, it's what foremen notice most. And appreciate.
The Following User Says Thank You to joebanana For This Useful Post:
Old 03-03-2020, 05:59 PM   #12
stiffneck's Avatar
Rewards Points: 1,352
I know some disagree but you really are what you eat. If you're overweight cut back on the food/drink, it's the only way. Lifting weights/exercise will make you stronger, not lighter. Warm up and stretching is import to do every chance you get. It's that one time you reach too far, or over extend and something pops or rips. Next thing you know you're off work a couple of weeks.
In Bred Electrical Worker
Old 03-03-2020, 06:31 PM   #13
stiffneck's Avatar
Look for something like this in your region, might be a bit of a hike to find one for Montana. Lots of free stuff and admission is free too. These salesman are looking for newbies just like you. The food/drink is great too, while they try to get you interested in their product. Because their product is the best Only happens once every 3-years and this is a year "2020"
https://www.ncel.org/expo.html
https://www.elecsupport.com/events/ebmi-electrical-expo
The Following User Says Thank You to stiffneck For This Useful Post:
Old 03-03-2020, 09:43 PM   #14
Phillipd's Avatar
I’m almost 46 and just starting myself so your not alone. If you haven’t done it before or aren't 100% sure ask enough questions to make sure you fully understand. Journeymen hate when an apprentice doesn’t ask when they don’t fully understand the task then mess something it up than it takes a lot of time to redo or repair.
MotoGP1199, telsa, Signal1 and 1 others like this.
Phillipd is offline   Reply With Quote
The Following User Says Thank You to Phillipd For This Useful Post:
Hunger James (03-04-2020)
Old 03-10-2020, 01:41 AM   #15
I'm starting my apprenticeship and am 46... this will be interesting to see how my body holds up!
knt4ever is offline   Reply With Quote
Old 03-10-2020, 09:16 PM   #16
Instrumentation's Avatar
Rewards Points: 80
Stay humble (without being a doormat), keep your phone in the car, show a willingness to learn, show up on time, stay late if needed, keep your phone in your car, and keep a positive attitude.
Oh and keep your phone in your car. You'll be alright.
wirestretcher likes this.
Instrumentation is offline   Reply With Quote
Old 03-11-2020, 09:00 AM   #17
Southeast Power's Avatar
Rewards Points: 9,220
  • Stay off of your phone, Work hard, don't be afraid to get dirty and go home tired every single day.
  • Always have a head for organizing and housekeeping.
  • If you ever get a shot at paperwork, take it.
  • Always have a pencil and a pocket-size notebook on you.
  • Learn to anticipate your journeymen needs the way a surgical nurse supports a surgeon.
  • Ask questions but don't be a PITA
  • If two journeymen or a foreman and a journeyman are having a conversation, don't lurk, give them space and stay within earshot.
  • Do not gossip or be part of any gossip.
