Boss wants me to get use to working live - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > Electrician Apprentice Forum
Like Tree22Likes
Old 02-26-2018, 09:29 PM   #1
Rewards Points: 12
Default Boss wants me to get use to working live
My boss wants me to get used to working live and I worry about making a mistake one time, even connecting potlights live or removing live wires by a junction box.
I was told that if I was really concerned I could short the circuit and trip the breaker by touching the hot against ground. This would create a small arc would it not ? If arc is not the correct term then I mean sparks.
Another question I have is should I stay with the company or should I go
JuniorSparky is offline   Reply With Quote
Old 02-26-2018, 10:00 PM   #2
Going_Commando's Avatar
Rewards Points: 1,620
Find another company to work for. Your current boss is a douche.
Roger, MechanicalDVR, Cow and 4 others like this.
Old 02-26-2018, 10:02 PM   #3
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 712
What's that burning smell?
Cowboy words of wisdom.
Never approach a bull from the front, a horse from the rear, or a fool from any direction.
Old 02-26-2018, 11:04 PM   #4
Rewards Points: 21,898
I would dump that baka because it not really worth it anymore due many insurance company and safety dept is clamping down pretty hard for safety.
It dont take much on 120 volts to hurt like crazy. Just dont even go there on 347 volts circuits that will really nail ya hard.
Just go find other company they will treat ya better and work safer.
I just dont know why that company want to save few extra minuites to work hot.
Without proper PPE ( personal protection equiment ) that is pretty much gambling your life on that.
Old 02-26-2018, 11:09 PM   #5
Rewards Points: 20,835
Your boss sounds like a cool dude. I wanna invite him over for a Barbecue.
Nyuck, nyuck.............
Old 02-26-2018, 11:24 PM   #6
Buck Parrish's Avatar
Rewards Points: 258
On what volt ? Amps ?
Buck Parrish is offline   Reply With Quote
Old 02-26-2018, 11:38 PM   #7
Rewards Points: 12
Old 02-26-2018, 11:57 PM   #8
Band Member
emtnut's Avatar
Rewards Points: 2,514
Excellent question Buck
I've always wondered, is it the Amps or the Volts
Navyguy likes this.
Old 02-27-2018, 12:02 AM   #9
Rewards Points: 5,612
I am an owner of a company and I would never request or demand that any of my guys work live. Do they do live work, well technically they do because every time they jam a breaker in a panel or troubleshoot a circuit they often “work live”; but sometimes it is necessary to test a circuit for proper functioning of control devices, or similar activities.
The real question is what are the circumstances that you are working live? In residential, except for testing a circuit, I cannot fathom a reason to have anything live. In commercial again, I cannot see a requirement except you may have to install a cable or branch circuit conductors in a live panel / conduit so you don’t shut down the store, etc. Industrial is a bit different, where when you are installing and removing MCC buckets, changing control devices, etc you may be working live, but there generally is a host of “protocols” and equipment requirements to be met before that can happen.
Do I work live, yes I do on occasion. While I admit it may not be a good example to set for my crew, it is a choice that I make based on a number of risk factors (and almost 30 years in the field) and none of them are related to saving time or money. Generally it is related to diagnosing a situation with a faulty control device, but I have also been known to change a breaker, switch or receptacle too.
Do not let your boss push you into something that is not required and could be dangerous; there is basically no reason for it.
Based on your questions, I suspect you are pretty new in the trade; there are tons of avenues for you to explore but if you end up killing yourself because you are being pushed into something that is not required (and it goes wrong), you will never get a chance to see all the fine things the trade can offer.
Cheers
John
The Following 2 Users Say Thank You to Navyguy For This Useful Post:
emtnut (02-27-2018), MechanicalDVR (02-27-2018)
Old 02-27-2018, 12:15 AM   #10
Rewards Points: 23,896
Cheers
John
This guys employer needs to be turned in for his lack of safety practices.
cad99 and emtnut like this.
Old 02-27-2018, 12:22 AM   #11
Band Member
emtnut's Avatar
We have a thread open right now, and some of us have admitted to working live. Keep in mind, a lot of the guys here are 20 25 30 35 even 40 year veterans. We know what we're doing.
If for ANY reason you have to work live, it should be you WATCHING your Jman and learning.
As others said ... time to start looking for a new job.
Old 02-27-2018, 01:52 AM   #12
Rewards Points: 1,881
Are you registered as an apprentice? If not, get registerd first and then dump his sorry ass. This sounds like the kind of clown who will screw you out of hours and forget to send you to school.
Old 02-27-2018, 02:00 AM   #13
Rewards Points: 6,421
No matter how much time on the tools I have, the electrons don't know that. They're waiting in hiding to bite me anyhow. While I have worked live, and continue to from time to time, it's not a point of pride. I see the OP having many options:
  • Work live, as his boss suggests.
  • Don't work live, and ignore the boss.
  • Talk with the boss like a reasonable person would and tell him how uncomfortable you are with working live seeing that it's dangerous and technically against the law under most circumstances. See if you can have a meeting of the minds.
  • Turn the boss into OSHA or similar health and safety agency.
  • Quit his job and get into another line of work.
  • Quit his job and get a job in the same line of work where hot work is prohibited.
While all of the above options are completely viable, they each come with their own peculiar repercussions. Some would be considered being a man, some would be considered being a chicken, and some would be considered being a d!ck.
Old 02-27-2018, 09:21 AM   #14
Cow
Rewards Points: 5,118
I agree.
It makes me wonder, If he's asking a new apprentice to work hot or short circuits out on purpose, how many other little things is he doing wrong too?
Old 02-27-2018, 09:27 AM   #15
Originally Posted by Cow View Post
I agree.
The OP is a smart dude and his boss is trying to bring him down to his level of stupid. There's no future here.
Old 02-27-2018, 02:41 PM   #16
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
I see an EKG order in his future
Old 02-27-2018, 03:10 PM   #17
canbug's Avatar
Rewards Points: 2,032
Better safe then toasted.
Tim
Old 02-27-2018, 03:17 PM   #18
just the cowboy's Avatar
Rewards Points: 520
Default No No NO
DO NOT DO THIS!!!!
It can and may do the following.
1. Start a fire, dryer lint goes up real fast.
2. Destroy the breaker so it don't reset.
3. Destroy the breaker so it don't trip next time when needed.
4. Leave black marks on the walls, and brown one in underwear.
5. Damage wire or open bad splices.
6. and much more.
When I was an apprentice my Jman told me the same thing to find the breaker, I melted a piece of #10 wire like a welding rod shoving it in the recepticial. Breaker never tripped.
Stay alive move on.
"DID THIS FIX IT??"
Old 02-27-2018, 04:44 PM   #19
Light Bender
eddy current's Avatar
Rewards Points: 8,038
Originally Posted by just the cowboy View Post
DO NOT DO THIS!!!!
6. and much more.
Stay alive move on.
I do it as a last test, after I have ensured the power is off with a pen tester and a multi meter. Before putting myself in a bad spot where I could get hurt.
Old 02-27-2018, 05:05 PM   #20
I do that as well, just to be 100%.
eddy current likes this.
F This I Quit LawnGuyLandSparky General Electrical Discussion 128 05-16-2016 08:55 PM
How easy is it to go back working non Union Heavyduty5 Union Topics 17 03-06-2016 09:02 PM
