Bonding trim screw on a blank cover? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 2 Post By zac
  • 1 Post By joe-nwt
  • 1 Post By zac
  • 1 Post By joe-nwt
Old 04-04-2019, 05:57 PM   #1
zac
Rewards Points: 812
Default Bonding trim screw on a blank cover?
Why don't we bond the trim screws of a blank cover? There's no device so technically you could get an energized screw taking apart a cover off a plastic box. I actually came across a bathroom switch that the trim screws were reading 120. The installer screwed the mounting screw of the switch in between the switch leg wire and box. The result was everytime the switch was turned on barefoot they'd get shocked. Obviously the switches weren't grounded (I never do).
Not for it just trying to contribute to the forum. It's been lagging.
Old 04-04-2019, 06:05 PM   #2
Rewards Points: 800
One step further, what about a blank metal cover plate on a plastic box?
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
zac (04-04-2019)
Old 04-04-2019, 06:07 PM   #3
CoolWill's Avatar
Rewards Points: 2,374
There are blank covers with bonding pigtails.
I'm With Her! Hillary 2016
zac (04-04-2019)
Old 04-04-2019, 06:08 PM   #4
zac
Rewards Points: 812
That's easy, just wrap the ground wire around the cover screw.
No serious, you could get lit up crawling in an attic and grabbing a metal cover.
Old 04-04-2019, 06:08 PM   #5
Rewards Points: 800
AFAIK, there’s no requirement to use them.
Old 04-04-2019, 06:19 PM   #6
Rewards Points: 9,487
A nylon screw would solve the problem.
But nylon screw manufacturers don’t sit on code advisory committees.
zac (04-04-2019)
Old 04-04-2019, 06:37 PM   #7
Rewards Points: 1,868
How is it not bonded? I just read continuity from the threaded trim hole to the yoke and grounding screw.
My bad I got confused between the talk of getting shocked by a device and potential of shock from blank plate screws.
Your post does illustrate why you should probably ground your switches, though...
The Following User Says Thank You to TGGT For This Useful Post:
zac (04-04-2019)
Old 04-04-2019, 06:45 PM   #8
Rewards Points: 800
FWIW, I ground switches in plastic boxes. Never in metal, not switches or outlets or anything.
Old 04-04-2019, 06:54 PM   #9
I will when I use MC since the sheath does not qualify as a EGC. Correct me if I'm wrong.
Old 04-04-2019, 06:56 PM   #10
zac
Rewards Points: 812
If you bond the box it wouldn't matter about the mc.. just like romex.
HackWork and TGGT like this.
Old 04-04-2019, 07:22 PM   #11
That's right I got mixed up. I kept thinking if you landed the EGC on the device, the box wouldnt be properly grounded when the device wasn't secure to it. All our jobs spec a pigtail between box and device.
Old 04-04-2019, 08:43 PM   #12
Rewards Points: 56
Don't touch them un-grounded staples either.
CoolWill likes this.
Old 04-04-2019, 08:59 PM   #13
CoolWill's Avatar
I think you would have to be trying to get shocked. Even if the plate was energized, you would still need to find a way to get grounded.
Old 04-04-2019, 09:04 PM   #14
zac
Rewards Points: 812
True but it can happen. I've been lit up taking a cover plate off a energized metal box in a garage. I was standing on my fiberglass ladder had my other hand on something metal (maybe plumbing forgot) and it hurt!
Old 04-04-2019, 09:09 PM   #15
zac
Rewards Points: 812
You don't have to bond fastners, they're not in the box. That would be like bonding a metal one hole strap on pvc.
Not necessary.
MikeFL likes this.
The Following User Says Thank You to zac For This Useful Post:
joe-nwt (Yesterday)
Old 04-04-2019, 09:55 PM   #16
CoolWill's Avatar
I think 314.25(A) via 250.110 does.
Old Yesterday, 09:33 AM   #17
Rewards Points: 56
Not necessary.
Thank you Captain........
Old Yesterday, 09:55 PM   #18
zac
Rewards Points: 812
Well alrighty then. Thanks for the imput.
Philips and Robertson Screw Heads power Off Topic (Non Trade) 33 11-05-2017 01:40 PM
Old Novaline panel with damaged cover screw holders? Islander General Electrical Discussion 10 03-02-2017 06:41 PM
Screw U 99cents Business, Marketing, and Sales 75 06-28-2016 04:37 PM
Bonding screw on hack job panel Anathera General Electrical Discussion 19 03-04-2016 07:50 AM
Blank Face GFCI Question Ducatiguy Canadian Electrical Forum 5 01-11-2016 04:35 PM
