As direct as a short can get. - Electrician Talk - Professional Electrical Contractors Forum
Old 11-09-2008, 10:30 PM   #1
Adam12's Avatar
Rewards Points: 250
Default As direct as a short can get.
One day over the summer while working on a school in Newport Beach, the boss started to turn power on to start checking recept's.
He started with the lighting and everything came on without a hitch.
As he turned on breakers to this particular classroom, he began to have a problem with circuit #12, for some reason it kept tripping.
He called me over from an adjacent classroom and said "Hey Adam, come give me a hand with this circuit, the breaker wont hold".
I traced out the conduit, found a j-box between the panel and recept's then took apart the make-up. "Try it again" I said.
BOOM!
"Let me check inside the panel" he says.... Alright.
After its opened, he says "That S.O.B"!, Adam come check this out"
I go over and take a look, I didnt see anything right away, "Whats wrong"
"Look at the wire colors" Ok, so I'm looking on the even side starting with circuit 2 working my way down. In my mind I'm saying the wire colors, Black, red, blue, black, red, GREEN!? What the F*ck!
This is what I saw.
Adam12 is offline   Reply With Quote
Old 11-09-2008, 11:01 PM   #2
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
Oh, thats all bad! Was the guy color blind? I think the green/blue colorblingness is most common.
~Matt
Old 11-09-2008, 11:08 PM   #3
Adam12's Avatar
Rewards Points: 250
~Matt
He made up 3 or 4 other panels with no problems. I couldnt figure it out.
Old 11-09-2008, 11:50 PM   #4
Ambassador of Amps
TOOL_5150's Avatar
Was the corresponding blue landed on the ground bar??
~Matt
Old 11-10-2008, 05:29 PM   #5
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
messing with you guys maybee?
Old 11-10-2008, 07:48 PM   #6
Adam12's Avatar
Rewards Points: 250
~Matt
The blue was landed on a spare breaker.
Ive never met anyone who messed around like that. The foreman called the project Mgr. that day and let him know what he did. The guy was on another job at the time, not sure what happened to him after that.
Old 11-10-2008, 08:07 PM   #7
Rewards Points: 250
Wow...that is rediculous!!!!
Kletis is offline   Reply With Quote
Old 11-11-2008, 07:44 AM   #8
IBEW Local 661 JW
Rong's Avatar
Rewards Points: 174
I just finished a job were I had a brand new helper. Month and a half in the trade. Being short handed and crunch time I was forced to have him do some make-up in a few JB's. I of course checked a few of his boxes and they were made up right. Went to turn on the 277 lighting and bang blown breakers. He had the brown , orange tied together in TWO boxes.
I also had him hook up the lighting. Some had battery backup. I explained to him and even wrote to way to wire these fixtures. Wired one with him and then checked the next one he did and the very last one. My thinking on this was is if he was wiring them wrong then it should show up when I checked the last one. I was WRONG in between the first one and the last one he hooked the black(120) and the orange (277) wires from the battery ballast to power. I a going to have to replace 9 battery packs.
I had a recpt. installed in the ceiling with MC feeding it. He hooked that into the lighting (277) power. I caught that.
I know he was well over his skill level. BUT I had written out how to do everything and told him to ask me if he had any questions.
I am upset with myself for not checking closer. However as I said the deadline getting very close and we had to be done and he was the only help that I had.
Had a JW for a couple of days and he wired an exit light orange (power coming in) to the white in the exit light. When I saw that I asked why would you do that. He said that since it was 277v that the orange goes to white. Were in the sam heck he came up with that idea I will never know. I had him change it to power to power neutral to neutral.
I too am bilingual :
I speak bad English and worser English.
Rong is offline   Reply With Quote
Old 11-11-2008, 08:07 PM   #9
Licensed Journeyman
nolabama's Avatar
that battery pack mistake is one of the few firable offenses in my company
Old 11-11-2008, 08:09 PM   #10
Licensed Journeyman
nolabama's Avatar
oh and back to the OP - i agree ive never worked with anyone who would do that on purpose even to mess with someone - he even numbered it so he might be color blind - or just a jackass
Old 11-11-2008, 08:33 PM   #11
Adam12's Avatar
Rewards Points: 250
I didnt know him that well, from what I heard, he was a J/A.
Old 11-12-2008, 06:00 AM   #12
gilbequick's Avatar
Rewards Points: 1,000
It seems like it's an oversight. Is it really worth calling the project manager over? That seems pretty harsh, the guy did make up several other panels and none had any problems with them. It is an obvious mistake, but it seems like a rarity with the guy. Nobodys perfect, I just can't see calling the PM over that.
Old 11-12-2008, 06:39 AM   #13
R.I.P. 2014
randomkiller's Avatar
If that happened on one of my jobs I would lean toward thinking somebody was screwing around on purpose not the guy who actually wired the panel up, unless he had a history of mistakes, at which point I would have had someone check up on him periodically.
"One Nation Under God"
Old 11-12-2008, 05:11 PM   #14
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
he probably has a tough time telling green from blue. luckily im not like that but i know a few people in the field who are. i think calling the PM and getting the guy introuble over something like that is harsh. unless of course he did it on purpose just to make someone angry or whatever
direct mail berkey Business, Marketing, and Sales 22 05-20-2011 04:12 AM
direct deposit paul d. Business, Marketing, and Sales 36 03-16-2011 11:30 AM
Old timers and their short wires. MDShunk General Electrical Discussion 23 02-16-2011 03:15 AM
Bad Breaker or Short in the Line? Billyray General Electrical Discussion 3 10-17-2008 04:39 PM
Direct buried 1k ft run of electric, fiber, data(cat5e) and Voice (Cat3) -same trench sj22 Structured Wiring 11 10-03-2008 09:36 AM
