Do You Bury Splices? - Page 8 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree168Likes
Old 03-14-2019, 08:25 PM   #141
Going_Commando's Avatar
Rewards Points: 1,372
I'll use a local example to illustrate just how stupid these arbitrary rules are. It's still legal to run NM cable above suspended ceilings in Massachusetts in commercial occupancies because MA has amended the NEC and has ever since the NEC changed the rule. But step 100 feet over the border into any neighboring state to Massachusetts and suddenly it's wrong and dangerous to run NM cable above a suspended ceiling.
The same could be said for Chicago and its EMT rules. Once you step outside of Chicago it's ok to use NM cable again.
NH passed an amendment that lets us do it now too.
Old 03-14-2019, 08:50 PM   #142
Rewards Points: 10,209
Hereís a wire nut that blew apart under heavy load in a concealed JB. Water damage. Five year old Siemens panel. Breaker did not trip.
Old 03-14-2019, 08:52 PM   #143
MTW
MTW's Avatar
Rewards Points: 6,992
Recently? Sounds like a case of "If you can't beat them, join them" taking place based on the amount of MA contractors that work in NH every day.
Old 03-14-2019, 08:56 PM   #144
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,046
I like Ideal push in connectors...eff reds
Old 03-14-2019, 09:18 PM   #145
Rewards Points: 7,520
As I said, I don't bury splices as a rule. I only do it when it's the absolute last resort. .
Yeah........like when there’s wallpaper on the walls.
Lol
MechanicalDVR, zac and 99cents like this.
Old 03-14-2019, 10:11 PM   #146
lighterup's Avatar
I'm not sure potential troubleshooting is a realistic factor in this issue cause we
are permitted to bury splices underground outside...right? Those are still
potential weak points in the circuit (as stated by others and of which I agree) ...BUT
why is it okay to bury a splice underground as opposed to indoors behind a wall?
Old 03-14-2019, 10:22 PM   #147
stiffneck's Avatar
Rewards Points: 602
Everything gets buried at an Airport.
Liberalism is a Mental Disorder; quote Dr. Michael Savage of the Savage Nation
Old 03-14-2019, 10:27 PM   #148
Fire hazard in a wall. No fire hazard under ground
MechanicalDVR, daveEM and splatz like this.
MechanicalDVR (03-15-2019)
Old 03-15-2019, 05:28 AM   #149
Rewards Points: 1,875
No more of a fire hazard than the other 50-200 junction boxes in the walls.
Old 03-15-2019, 07:41 AM   #150
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,334
Man, I could swear I remember seeing a picture of a manufacturers mid-coil butt splice that someone, maybe 480?, came across.
Good work aint cheap and cheap work aint good.
Old 03-15-2019, 07:50 AM   #151
But that is why joints and splices must be in approved boxes. You do realize that the box is not just there to support the receptacles and lights right?
Canít believe I need to explain this to you
MechanicalDVR and 99cents like this.
Old 03-15-2019, 07:51 AM   #152
I have found those in Romex. I actually have one in a junction box in my attic.
Old 03-15-2019, 07:54 AM   #153
I agree. I never said to make a flying splice in the wall.
You don't have to explain it to me, and give up the condescending BS. I never advocated to make a splice without a box. No one has.
Old 03-15-2019, 08:56 AM   #154
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
Think about it another way: the guys here saying they do it or would do it, still say they don't/wouldn't do it often. If it were allowed, there would be nothing stopping someone from making dozens of buried splices in one installation, which would definitely turn into a troubleshooting nightmare, and in my opinion hazard.
Old 03-15-2019, 09:08 AM   #155
It's not optimal to do it, I definitely agree with that.
But we all find ourselves doing things that aren't optimal sometimes.
Right now I have a guy installing a new 20/40 panel in a house with 18 circuits. I don't like it, it's not the best way to do it, but it is the only panel that will fit.
Old 03-15-2019, 09:42 AM   #156
Rewards Points: 17,496
Yeah........like when thereís wallpaper or crown moulding on the walls.
Lol
Fify!
eddy current likes this.
Old 03-15-2019, 05:49 PM   #157
MTW
MTW's Avatar
Yeah........like when thereís wallpaper on the walls.
Lol
This is coming from the guy who can't do electrical work without the government protecting him.
Old 03-15-2019, 06:05 PM   #158
Yes the work I do is code compliant and passes inspection. There is no one protecting me. Itís actually the norm for professional electricians, I donít expect a handyman hack like yourself to understand
Old 03-15-2019, 06:11 PM   #159
What about the car charger installation that would be prohibited by code but you said you would lie in the load calc to make it work? That was ok to break code? You can pick and choose which code you break, huh?
Old 03-15-2019, 06:15 PM   #160
MTW
MTW's Avatar
The norm for professional electricians is not to go running to the government to have a government inspector looking at and approving their work.
Submersible Splices jwp General Electrical Discussion 54 07-31-2017 05:35 PM
Underground splices WIsparky71 General Electrical Discussion 7 07-30-2017 10:00 PM
butt splices hardworkingstiff Tools, Equipment and New Products 21 04-09-2017 02:54 AM
Splices and voltage drop swimmer Residential Electrical Forum 17 12-19-2016 09:28 PM
But splices and 24v wiring Germanicus Canadian Electrical Forum 26 08-08-2016 09:06 PM
