Supporting MC? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
  • 2 Post By Kevin_Essiambre
  • 1 Post By joebanana
  • 2 Post By The_Modifier
  • 3 Post By 99cents
  • 1 Post By 99cents
  • 1 Post By Signal1
  • 2 Post By macmikeman
  • 1 Post By telsa
  • 3 Post By Signal1
  • 1 Post By CoolWill
  • 2 Post By Easy
Old 05-25-2020, 08:39 PM   #1
Rewards Points: 26
Default Supporting MC?
Inspector said I have to support mc in an accessible ceiling 12" from a light fixture. I cited 330.30(D)(2). Any thoughts?
Steven A. is offline   Reply With Quote
Old 05-25-2020, 10:25 PM   #2
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 492
I'd ask your journeyman... but let me guess, this is a side job?
The_Modifier and joebanana like this.
Vote Kevin for Moderator!
Old 05-25-2020, 10:52 PM   #3
Rewards Points: 8,233
Since local codes can vary from area to area, it would help to know your area of operation. Los Angeles codes are different from almost any area in the US. (Seismic, and Title 24 being the main differences).
What does your spec. sheet say?
Old 05-26-2020, 08:56 AM   #4
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 760
Originally Posted by Steven A. View Post
Any thoughts?
Yup, plenty of them- first one that comes to mind- can you read?
For example- filling out your profile
AS PER THE USER SIGN UP AGREEMENT
Specifically your electrically related field
Your apprenticeship level.
The province that you live in for us to cite the codes that may be local to you.
99cents and Kevin_Essiambre like this.
Old 05-26-2020, 09:15 AM   #5
Rewards Points: 3,311
Maybe we should combine this thread with one of your other threads. Your favorite tool should be a tape measure so you can measure 12” from a box.
Old 05-26-2020, 09:18 AM   #6
He’s American. He is using a measurement derived from the anatomy of an ancient monarch.
The_Modifier likes this.
Old 05-26-2020, 09:19 AM   #7
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,720
You're citing the correct code article, good on you.
Like Joe said, depending on your area, there might be something local the inspector is dinging you on.
"Hanging ceiling fans for grandma"
M E T G A !
Old 05-26-2020, 11:50 AM   #8
Rewards Points: 22,691
I just loves me some mc cable. There's my support.
splatz and TheLivingBubba like this.
"Can you just imagine how much better the U.S.A. could have been without all the impeachment, Russia, attempted coup falsehood crap?".......ALARMGUY
Old 05-26-2020, 04:28 PM   #9
VELOCI3's Avatar
Rewards Points: 118
3’ if it’s lights in a drop ceiling
Old 05-26-2020, 04:35 PM   #10
Rewards Points: 27,012
Veloci3 -- you should've cited 330.30(D)(2) -- an accessible ceiling is a drop ceiling.
You can buy listed MC/ AC whips that are exactly 6' -- sold by the drum, BTW.
macmikeman likes this.
Old 05-26-2020, 04:52 PM   #11
Signal1's Avatar
I think in the OP's example, D2 applies
M E T G A !
Old 05-26-2020, 05:28 PM   #12
Rightly divide the code! 2nd Timothy, verse : I forgots . ...................
Old 05-26-2020, 05:37 PM   #13
Rewards Points: 554
I support MC all the way! You can do it, MC!
RRF likes this.
Old 05-26-2020, 06:29 PM   #14
Rewards Points: 1,910
We had to do this once because my superintendent pissed off the inspector with a [email protected] comment.
MC really shouldn't be secured within 12'' of a light fixture, it makes maintenance a pain, and if the MC isn't run just right, you need to bend it pretty tight to secure it.
Old 07-11-2020, 03:50 PM   #15
Easy's Avatar
Rewards Points: 1,988
MC needs to be supported within 3 feet of a fixture as stated in the NEC. There is only one small catch. You can't support from any ceiling wires that supports the t-bar ceiling so you need to put in your own drop wires. Here is a adjustable lag pole that goes to 23 feet and if you stand on top of an 8 ft ladder and your 6'7" tall you can really get up there. This tool also works for 1/4" and 3/8" drop rod.
tmessner and splatz like this.
Old 07-11-2020, 04:43 PM   #16
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 1,632
https://www.erico.com/category.asp?category=R1315
Take your pick. Throw a few of those around and make it look neat.
Make America Great Again...I want an Arby's in every city!
TheLivingBubba is offline   Reply With Quote
Old 07-11-2020, 06:46 PM   #17
Ah, the ol' quake pole. I wonder what they call them outside Cali.
