Best Voltage Tester - Electrician Talk - Professional Electrical Contractors Forum
Old 02-14-2014, 11:31 PM   #1
Question Best Voltage Tester
Looking to buy new voltage testers:
What voltage testers are you using? What do you like about it, what do you don't? Which is in your opinion the best and why? Any safety issues worth sharing? Quality/Price ratio?
Cheers!
jimkickz is offline   Reply With Quote
Old 02-14-2014, 11:40 PM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Cheers!
Welcome to the forum..
Fluke T-5 1000...
But watch this guys videos
gh1n_ELmpFI
Old 02-15-2014, 01:55 AM   #3
Rewards Points: 340
Do you mean like a non-contact voltage tester?
If so, I've used quite a few different ones but have settled on the Fluke LVD2, it goes blue when near ac or low voltage, red when near the voltage. It also has a built in LED flashlight that is pretty bright. It doesn't make any noise though, if that's something you need.
FrunkSlammer is offline   Reply With Quote
The Following User Says Thank You to FrunkSlammer For This Useful Post:
jimkickz (02-15-2014)
Old 02-15-2014, 02:51 AM   #4
zwodubber's Avatar
Rewards Points: 1,010
Originally Posted by FrunkSlammer
Do you mean like a non-contact voltage tester? If so, I've used quite a few different ones but have settled on the Fluke LVD2, it goes blue when near ac or low voltage, red when near the voltage. It also has a built in LED flashlight that is pretty bright. It doesn't make any noise though, if that's something you need.
I have the same one, it's great indoors but useless out in any sunlight
And OP, if you mean REAL voltage testers I don't go anywhere without my actual fluke 381, NC meters are not a replacement for a real meter
zwodubber is offline   Reply With Quote
The Following User Says Thank You to zwodubber For This Useful Post:
Old 02-15-2014, 03:02 AM   #5
[QUOTE=FrunkSlammer;1229879]Do you mean like a non-contact voltage tester]
Yes that's what I meant. There's lots of brands and price ranges. I was trending towards Klein simply because that's my first pick for hand tools but thought I'd ask for an "outside" opinion.
Thanks!
Old 02-15-2014, 03:41 AM   #6
Rewards Points: 1,000
Consider the Fluke 2AC because it stays on all the time. I might get one someday just so I'd be more likely to test things but i got a bunch of testers already. My favorite so far is the fluke 1ac ii a1/a2.
uconduit is offline   Reply With Quote
Old 02-15-2014, 06:26 AM   #7
Electron Flow Consultant
sparky970's Avatar
Rewards Points: 992
Those are garbage. I prefer one that has a tip for inserting into a receptacle and the flashlight is useless
The Following User Says Thank You to sparky970 For This Useful Post:
99cents (02-15-2014)
Old 02-15-2014, 07:16 AM   #8
Rewards Points: 3,027
I like the Milwaukee no touch tester but the button always falls out. I use this because it does low voltage:
Old 02-15-2014, 07:45 PM   #9
Rewards Points: 93
I dont like the klein or Milwaukee ones, they are too sensitive and give false readings. I like this fluke tester, it also has a silent mode if you wanted. Doesn't do low voltage but works well for me
samc is offline   Reply With Quote
The Following 3 Users Say Thank You to samc For This Useful Post:
KGN742003 (02-16-2014), Rollie73 (02-15-2014), wendon (02-15-2014)
Old 02-15-2014, 07:50 PM   #10
ponyboy's Avatar
Rewards Points: 709
These are far superior than anything mentioned
The Following 3 Users Say Thank You to ponyboy For This Useful Post:
bduerler (02-15-2014), kecci (02-17-2014), pjg (02-15-2014)
Old 02-15-2014, 07:57 PM   #11
Armed and Unhinged
bml215's Avatar
Rewards Points: 256
I use Klein. I have the low volt, the reg. Like the low volt more.
bml215 is offline   Reply With Quote
Old 02-15-2014, 09:32 PM   #12
wendon's Avatar
Rewards Points: 54
Attachment 34156
This is the same one that I use. I've tried different ones but I think this one is the best. The flashing light lets you know it's working, it has a silent mode, and uses readily available batteries.
Old 02-15-2014, 09:35 PM   #13
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Attachment 34156
Same one I use as well. I personally don't use any testers or meters except Fluke.
The Following 3 Users Say Thank You to Rollie73 For This Useful Post:
cdnelectrician (03-07-2014), sparky970 (02-15-2014), wendon (02-15-2014)
Old 02-15-2014, 09:40 PM   #14
Attachment 34157
Strummin a lil 6 string tonight Pony? Thought I saw the geetar in the background.
Those testers break all the time on me I must have 5 or so. Get one that beeps, it's worth it.
cultch is offline   Reply With Quote
Old 02-15-2014, 09:41 PM   #15
Fluke T-5 1000...
gh1n_ELmpFI
I hope I never have to buy a new one but I'd never buy one that didn't also have the amp probe. I got the new Klein one works like a charm.
Old 02-15-2014, 09:42 PM   #16
Rewards Points: 3,538
DMM any Fluke you like and can afford.
Non contact tester TIC TRACER flat out.
http://www.amprobe.com/amprobe/usen/....htm?PID=73374
Wiggy style Klob
http://www.knoppinc.com/tools.htm
Old 02-15-2014, 09:44 PM   #17
ponyboy's Avatar
Rewards Points: 709
Originally Posted by cultch
Strummin a lil 6 string tonight Pony? Thought I saw the geetar in the background. Those testers break all the time on me I must have 5 or so. Get one that beeps, it's worth it.
There's a guitar within arms reach in every room of the house.
I really like my tester. I don't use a ncvt often but these have been very reliable. One time though a few years ago one burned up in my pocket. I don't know if it was a defective battery or what but I couldn't get it out of my pocket fast enough. It was literally too hot to hold!
Old 02-15-2014, 09:48 PM   #18
wendon's Avatar
Rewards Points: 54
Admit it, you got stoned and dropped your doobie into your pocket thinking it was your NCVT.
The Following 2 Users Say Thank You to wendon For This Useful Post:
brian john (02-15-2014), Next72969 (02-15-2014)
Old 02-15-2014, 09:57 PM   #19
ponyboy's Avatar
Rewards Points: 709
I don't smoke weed any more. Don't smoke it any less either.
The Following User Says Thank You to ponyboy For This Useful Post:
Going_Commando (03-06-2014)
Old 02-15-2014, 10:02 PM   #20
wendon's Avatar
Rewards Points: 54
Tags
safety, testers, voltage testers
Voltage tester electricianlife Residential Electrical Forum 17 01-23-2014 08:51 PM
Low Voltage Pro 3 all in one tester LARMGUY Tools, Equipment and New Products 2 05-12-2013 02:49 PM
Which voltage tester.. 3xdad General Electrical Discussion 16 02-28-2012 12:49 AM
Low-Voltage Non-Contact Tester? chrisfnl Tools, Equipment and New Products 18 07-07-2011 06:37 AM
Voltage Tester Policy Lone Crapshooter General Electrical Discussion 8 02-14-2010 05:52 PM
