Best wire strippers? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
Old 02-27-2011, 02:27 AM   #1
Rewards Points: 25
Default Best wire strippers?
I just lost my strippers somehow and I'm looking for one equal to or better than then. Here is my old pair.
http://www.amazon.com/Klein-1011-Str...8787428&sr=1-6
They worked great but I really need help on deciding which pair to buy based on one factor - the loop holes. I used a bigger pair for a day and the loops were nothing like the one I lost. I don't know how many real electricians use the loop holes (I'm still in school) but I feel like it helps me a lot, saves time, and does it perfect.. well the old one.
So I was wondering, are all loop holes the same or do they vary slightly? If you've used a pair you remember that stood out, please fill me in.
Fate is offline   Reply With Quote
Old 02-27-2011, 03:03 AM   #2
Rewards Points: 77
I like ones that have screw cutters, at least 6-32 & 8-32. Some have 10-32 & 10-24. I think most types are pretty good on stripping wire.
jmellc is offline   Reply With Quote
The Following User Says Thank You to jmellc For This Useful Post:
The_Modifier (02-27-2011)
Old 02-27-2011, 03:44 AM   #3
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,168
My advice is to get some ideal strippers and never look back. The loop holes take some getting used to after using the kleins, but it is well worth it.
sbrn33 likes this.
farlsincharge is offline   Reply With Quote
The Following User Says Thank You to farlsincharge For This Useful Post:
Old 02-27-2011, 05:06 AM   #4
NO high voltage here
Rewards Points: 1,248
I will agree with ideals. Best i have owned
Old 02-27-2011, 06:47 AM   #5
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
http://www.electriciantalk.com/f14/c...rippers-19664/
mdnitedrftr and socket2ya like this.
Old 02-27-2011, 09:15 AM   #6
Rewards Points: 530
The craftsman one is great. It's an exact replica of the Klein style, not the one you used but the other longer one . Plus there lifetime replacement, I'm on my third pair.
Old 02-27-2011, 10:02 AM   #7
mattsilkwood's Avatar
Rewards Points: 2,006
These are the ones I use. I don't think klein makes them as every company out there has a pair that are identicle.
The crimpers on them suck but the screw cutters are great. I use them to cut screws almost as much as I do to strip wire.
A man that will not read has no advantage over a man that can not read.-Mark Twain
The Following User Says Thank You to mattsilkwood For This Useful Post:
Old 02-27-2011, 11:03 AM   #8
Fried Bologna um um good!
jwjrw's Avatar
Right now I am using Ideal reflex. I've had two or 3 different models of every brand. IMO they all work about the same. Buy the brand that feels best in your hand.
Old 02-27-2011, 12:17 PM   #9
Rewards Points: 518
Kinetic Reflex Super T-Stripper
crazyboy is offline   Reply With Quote
Old 02-27-2011, 12:26 PM   #10
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
These are the ones i use these days..http://www.amazon.com/Klein-11055-Kl...ref=pd_cp_hi_2
Old 02-27-2011, 12:29 PM   #11
wcord's Avatar
Rewards Points: 1,610
Have used the Ideal Stripmaster since they first came out. They last me maybe 2 years but the wear and tear they save on the hands and wrists is worth it. http://www.idealindustries.ca/produc...tripmaster.php
Navyguy and alex_becky like this.
Old 02-27-2011, 02:07 PM   #12
I have the ideal kinetic reflex strippers and love them and i also have the klein kurve strippers. I like the fact that the ideal strippers have the plastic up higher for my thumb when I strip wire the kleins dont. Also the klein strippers loosen up over time.
Chevyman30571 is offline   Reply With Quote
Old 02-27-2011, 02:10 PM   #13
Rewards Points: 6,421
I generally get the Ideal one's that have up to a #8 skinning hole in them. I'm pretty picky about having sharp skinners, so I go through a pair every 4 or 5 months maybe. I don't spend a ton of money on the fancy one's, since everything goes dull in time.
Old 02-27-2011, 02:47 PM   #14
On a side note, does anyone else use the next size smaller hole?
Like for #10 I use the #12 hole, for #12 I use the #14 hole, so on and so forth.
It will give you a clean cut through the insulation.
John Valdes likes this.
Old 02-27-2011, 02:49 PM   #15
I have a black cat.
Rudeboy's Avatar
Rewards Points: 2,000
for stranded.
I don't like to Save time and money.
Old 02-27-2011, 02:58 PM   #16
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
Originally Posted by Rudeboy View Post
for stranded.
I prefer to use the right size hole for the wire. I have found that if you nick it at all, it could break off when you twist it.
That being said, when the strippers get worn, they do not strip the insulation properly, and make it a little more difficult.
Much as I hate to admit it, then I have to toss the stripper out and buy a new one.
Steven Wright
Old 02-27-2011, 03:31 PM   #17
Rewards Points: 77
I use the Klein 11055, not a huge fan of them but they get the job done well enough. I somehow ended up 3 pairs though
-bottom, first pair of strippers ever lost them doing a projector plug during a rough in, found them again 4 months later second day after refinding them a live wire modified my 14 gauge hole keeping them for cutting questionable wires.
-middle, replacement pair for the pair i "lost" now my main strippers
-top, gift at the company christmas party still virgin
a few guys i know really like the crocs i'd buy a pair but i have to wear out all these ones first
d-fi is offline   Reply With Quote
Old 02-27-2011, 04:36 PM   #18
Rewards Points: 25
Wow lots of suggestions. Thanks. I'm looking through all of them. Do any of you guys have experience with the loop holes on them? They make my part easier
Old 02-27-2011, 04:42 PM   #19
Sideways Sparky
With klien I always did, not so with the ideals.
As for the holes, it seems to me the ideals are slightly farther in on the stripper and require you to concentrate on making a small loop more than the kliens do.
Old 02-27-2011, 05:03 PM   #20
Canadian
kevmanTA's Avatar
I like my Greenlee ones, I'm pretty sure it's the klein above with green and yellow handles..
"My mom said the only reason men are alive is for lawn care and vehicle maintenance"
kevmanTA is offline   Reply With Quote
The Following User Says Thank You to kevmanTA For This Useful Post:
Dkdeakn (10-25-2013)
Wire Strippers vs. Linemans jmp General Electrical Discussion 47 10-31-2014 10:09 PM
Croc wire strippers jkwallz Tools, Equipment and New Products 47 02-28-2011 04:00 AM
Long-nose wire strippers Mike in Canada Tools, Equipment and New Products 22 07-18-2010 11:54 AM
Wire Strippers: Knipex, Wiha BP_redbear Tools, Equipment and New Products 18 03-21-2010 12:41 AM
UK Wire Strippers gilbequick UK Electrical Forum 1 02-01-2009 07:36 AM
