Big A** channel locks vs knipex 22 cobra? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By TGGT
  • 1 Post By telsa
  • 3 Post By bill39
  • 1 Post By bill39
  • 1 Post By MDShunk
Old 03-07-2018, 07:54 PM   #1
Rewards Points: 341
Default Big A** channel locks vs knipex 22 cobra?
Were getting ready to run some 4 emt and was told to pick up some big channel locks for the job. Im partial to knipex but at double the price Im curious if their worth it compared to the big ass channellocks
Smid is offline   Reply With Quote
Old 03-07-2018, 08:05 PM   #2
360max's Avatar
Rewards Points: 1,234
Get big channel locks simple for the wider jaws
Old 03-07-2018, 08:24 PM   #3
Rewards Points: 1,894
The knipex are not worth the price for the purpose they'll serve unless you just want to burn money and are willing to guard them with your life.
2 canvas strap wrenches would be better for the job if you're using compression fittings anyway. They're lighter and you can let go of them when they're on the conduit without them falling.
https://www.ridgid.com/us/en/strap-wrenches
active1 likes this.
Old 03-07-2018, 09:06 PM   #4
Cow
Rewards Points: 5,130
I have two pairs of the BIG Knipex. I think they were $100/pair when I bought them a few years ago. They only come out of the truck when the going gets tough usually and something is rusted and just won't pop apart.
I'd like to try some of those strap wrenches mentioned above on some big compression fittings just to see how they do. The big Knipex I have are a handful, don't know if I'd want to use them all day screwing together 4" fittings.
Old 03-07-2018, 09:15 PM   #5
Rewards Points: 2,472
I'd buy the Channellocks myself even if they weren't less than half the price. The main thing I like about the 10" Knipex I have is they're lighter in your pocket, and the skinny jaws sometimes fit in tight spots better. Neither of those is a factor with big 16" set running 4" pipe. I think the Channellock jaws bite better for me.
This too shall pass.
Old 03-07-2018, 09:42 PM   #6
Rewards Points: 6,421
With every tom, ****, and harry metal shop having CNC plasma, laser, and water jet cutters, I wonder how nice a couple wrenches cut from maybe 3/16 or 1/4 plate would be? They wouldn't need but maybe a 6-8" handle.
Teach a man to fish and youve ruined a good business opportunity.
Old 03-07-2018, 11:28 PM   #7
Modrateur
Rewards Points: 21,898
Normally I use large channel lock pliers but once a while I will used modifed oil filter wrench that do work pretty good too.
Old 03-07-2018, 11:36 PM   #8
Rewards Points: 26,838
Monster Channellocks ought to be bought and owned by the CONTRACTOR -- not you.
They are such a LOW utilization tool that they're not to be an employee asset, IMHO.
You're most likely to go years at a stretch before you touch them.
If this is not true, they are STILL a tool that should be paid for by the employer.
It's all part of the bid for 4" work - which is an UNCOMMONLY big size.
Overwhelmingly, in design-build, every EC stops at 3" as 4" is such a bear.
One is WAY ahead to run paralleled 2.5" than a single 4" -- no question.
If the prints call for 4" -- then by all means bid them -- and tack on $$$ for the wrenches and the slowness of assembly and the pulls.
cad99 likes this.
Old 03-08-2018, 06:57 AM   #9
Rewards Points: 341
I should have specified, Im not paying for them, just picking them up or ordering them.
I would rather run parallel feeds but they specifically wanted one 4 for whatever reason.
The Following User Says Thank You to Smid For This Useful Post:
telsa (03-08-2018)
Old 03-08-2018, 07:47 AM   #10
Rewards Points: 1,684
For that size, Id use strap/chain wrenches.
https://www.homedepot.com/p/Crescent...FUO5Twod0UEFyg
frenchelectrican, Cow and splatz like this.
Old 03-08-2018, 08:43 AM   #11
Going_Commando's Avatar
Rewards Points: 1,620
I have a set of Channellock 460s in the truck that come out a few times a year. They do 4" compression connectors, iirc. They are 1/2 the price of the 480s.
Old 03-08-2018, 09:07 AM   #12
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,418
I had bought the Klein strap wrenches a few years ago after my old set grew feet.
It was a waste of $$ with that plastic strap and I only pull them out as a last ditch before the sawzall.. I sure miss the leather ones.
Old 03-08-2018, 10:45 AM   #13
The only ones Ive used had a metal chain or thick nylon straps. Never had a problem with either of those types.
Wirenuting likes this.
Old 03-08-2018, 11:33 AM   #14
Wirenuting's Avatar
I’ve used the chain ones but don’t like the marks they leave
The newer nylon/plastic straps slip and are next to useless.
My old leather strap ones worked great and held like a champ.
Next time I need some, I’ll buy the ridged ones.
Old 03-08-2018, 01:57 PM   #15
The nylon and rubber strap wrenches are like trying to tighten or loosen something with a piece of limp macaroni. I have one leather one and a couple of chain wrenches. Hardly ever use them, to be honest. My dirty little secret is that I don't really make up EMT compression fittings crazy tight anyhow. They serve little purpose if you're pulling a ground anyhow. Most everything I've ever put in for my entire career (unless it's raintight or concrete juice tight) is "just beyond snug".
Old 03-08-2018, 07:16 PM   #16
MTW
Rewards Points: 11,514
Based on my calculations you're around 247 years old.
Old 03-08-2018, 10:34 PM   #17
I feel very fortunate to have been able to do a lot of different things in this trade. Many of them for not very long or to the point of competence. Staves off boredom.
Knipex Auto Adjusting Pliers splatz Tools, Equipment and New Products 12 02-17-2018 12:05 AM
Apprentice Resume/C.V. - A personal website and Youtube channel? Belectr Electrician Apprentice Forum 6 01-07-2018 10:36 AM
Anyone Using Knipex Needlenose Combination Pliers? Satch Tools, Equipment and New Products 4 10-09-2017 12:57 PM
Knipex 1262180 Self Adjusting Insulation Strippers splatz Tools, Equipment and New Products 2 06-15-2017 09:00 PM
Knipex 10" 8702250 cobra pliers with comfort grip JRelectrician Tools, Equipment and New Products 40 05-26-2016 01:17 PM
