electrician pencil - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
  • 1 Post By carlwebb
  • 8 Post By HackWork
  • 1 Post By Lone Crapshooter
  • 1 Post By tmessner
  • 3 Post By splatz
  • 1 Post By zac
  • 3 Post By flyboy
  • 1 Post By TGGT
Old 04-25-2019, 09:05 PM   #1
carlwebb's Avatar
Default electrician pencil
Someone asked me why I had Carpenter Pencils instead of an electrician pencil. Is there such a thing?
Kevin_Essiambre likes this.
carlwebb is offline   Reply With Quote
Old 04-25-2019, 09:18 PM   #2
Galt's Avatar
Rewards Points: 901
I use my first ticonderoga pencils, they are the fat ones a little bigger than 3/8 in.
Galt is online now   Reply With Quote
The Following User Says Thank You to Galt For This Useful Post:
carlwebb (04-25-2019)
Old 04-25-2019, 09:20 PM   #3
Rewards Points: 1,583
An electrician’s pencil is a black sharpie marker.
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
Old 04-25-2019, 09:26 PM   #4
Rewards Points: 2,158
Not unless it would be from a electricial distributor or contractor.
My self I use a carpenters pencil or a first grader pencil and a Sharpie if I am doing rough in work. If I am working in a finished area the Sharpie does not get used except to label 4X4 or 4 11/16 covers. Larger boxes should be labeled with a label maker.
LC
Jmcstevenson likes this.
Old 04-25-2019, 09:29 PM   #5
Rewards Points: 2,952
I use red Sharpies.
Greg
Old 04-25-2019, 10:31 PM   #6
Rewards Points: 2,746
The Papermate 1.3mm lead pencil is the only one better for work than a carpenter's pencil.
Old 04-25-2019, 10:35 PM   #7
Rewards Points: 10,091
Yep, unless you’re drawing on a wall that’s to be painted.
I tried the Milwaukee ones that are supposed to write on anything. They’re marginally better than Sharpies but don’t live up to the hype.
Old 04-25-2019, 11:06 PM   #8
RSE Electrician
Incognito's Avatar
Rewards Points: 110
I use a .9mm mechanical pencil. (Most common are .5mm or .7mm).
Small enough to get accurate on the prints but tough enough to draw on drywall and wood studs without breaking.
2018 Ontario Electrical Code
Old 04-26-2019, 12:21 AM   #9
Rewards Points: 17,452
Are they three times the price of a Sharpie?
Southeast Power (04-26-2019)
Old 04-26-2019, 01:18 AM   #10
A Little Short's Avatar
Rewards Points: 716
$1 at my SH
Old 04-26-2019, 01:40 AM   #11
Originally Posted by A Little Short View Post
$1 at my SH
Oh that's cool, I haven't seen them here yet!
Old 04-26-2019, 09:28 AM   #12
Rewards Points: 710
Cheaper than Sharpies at our supply house. I think they are more durable also..I am addicted to red also.
tmessner is online now   Reply With Quote
Old 04-26-2019, 10:19 AM   #13
The one thing about the Milwaukee markers I have noticed is they seem to hold up better on concrete, you write on concrete with a sharpie, the tip is a little nub in no time. Same with a Milwaukee but not as fast.
Really the carpenter's pencil is far superior for marking on concrete.
Old 04-26-2019, 10:22 AM   #14
zac
Rewards Points: 812
Or running EMT.
Signal1 likes this.
Old 04-26-2019, 10:28 AM   #15
Rewards Points: 710
a Sharpie mark will fade out in a few months on an outside install. a pencil mark is forever on a box cover. Like for marking out push buttons on a control panel.
Old 04-26-2019, 11:46 AM   #16
Small Potatoes
flyboy's Avatar
Rewards Points: 2,948
I had these left over from catholic school. So I used them.
tmessner, splatz and MikeFL like this.
Old 04-26-2019, 01:06 PM   #17
Rewards Points: 1,872
Checkout sharpie mean streak. It's like a paint marker. I'm laying out on concrete and its waaaaay easier to see from afar and writes easily through dust.
Old 05-09-2019, 03:46 PM   #18
Rewards Points: 8
Best pencil is Pica dry. They make same style markers also in different colors.
Hobbit007 is offline   Reply With Quote
Journeymen Electrician Needed samedayservices Looking To Hire 2 01-23-2019 09:49 AM
Electrician or Electrical Engineering Technologist? electricalET Electrician Apprentice Forum 6 01-14-2018 09:49 AM
Becoming electrician westbeachsurfrat General Electrical Discussion 4 12-03-2016 09:52 PM
